    PanelDueFirmware 3.2-RC1 released
    PanelDue
    14
    48
    2.6k
      dc42 administrators @BoA
      @BoA, please post your config.g file so that @wilriker can try to reproduce your configuration.
      • BoAundefined
        BoA
        config.g
        In dynamics_normal.g there is just this:
        M913 X100 Y100 Z100 E100 ; set XY motors current to 100%
        M566 X900.00 Y900.00 Z18.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z1200.00 ; set maximum speeds (mm/min)
        M201 X1500.00 Y1500.00 Z100.00 ; set accelerations (mm/s^2)
        M593 F36.5
        And before someone asks - uart speed has nothing to do. It behaves exactly the same at 57600 and 115200
          Those of you with older version 1 and version 2 PanelDues, please note that we do not expect this release to work on old PanelDue boards that use the ATSAM3S2B chip, due to lack of RAM. However, we do expect it to work on later version 2 PanelDues using the ATSAM3S4B chip. If you have a PanelDue using the ATSAM3S2B chip, we suggest you replace the board by a version 3 PanelDue board, which can drive your existing LCD.
          • wilrikerundefined
            wilriker @BoA
            @BoA said in PanelDueFirmware 3.2-RC1 released:
            Duet3 standalone, 3.2beta1 + PanelDue 3.2-RC1
            When I setup a tool0 (first extruder) temperature, it sets heatbed instead 🙂
            Also switching chamber active/stby resets temp settings for it.
            Chamber button is not switching colors for active/stby like others do, and does not deactivate chamber heater at all.
            Extruder buttons are yellow when switching tool from stby to off
            Heatbed button does not change colors at all.
            That is what I notice djust now.
            Thanks for reporting. I will look into this now.
            config.g
            Thanks for providing this information as well. 👍
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker @BoA
              These have all been fixed
              There is a misconception. A tool will never go to the "off" state after being activated for the first time. It will only toggle between active and standby. Only the tool's heaters can go back to off.
              Fixed as well.
              If you tell me which version of PanelDue you have I can provide you a build to test before doing another release.
              Manuel
              My Tool Collection
              BoAundefined 1 Reply Last reply Reply Quote 0
              • BoAundefined
                BoA @wilriker
                @wilriker Tools can go off from DWC, and button on panel is still yellow then.
                I use PanelDue 7i
                • wilrikerundefined
                  wilriker @BoA
                  @BoA Believe me, the tool itself is not off. You can check yourself by issuing
                  M409 K"tools[0].state"
                  will report standby.
                  At the same time
                  M409 K"heat.heaters[1].state"
                  might report off
                  You can find the new build at https://www.dropbox.com/sh/zbj590lu8udha8d/AADTx7RdBuGIhri8Xk18jNvua?dl=0
                  Manuel
                  My Tool Collection
                  • BoAundefined
                    BoA @wilriker
                    Looks like "off" to me 🙂
                    • wilrikerundefined
                      wilriker @BoA
                      @BoA Is that before or after the tool has been active at least once?
                      Manuel
                      My Tool Collection
                      • BoAundefined
                        BoA @wilriker
                        @wilriker After. I can cycle through all 3 state from DWC. From panel only active<->stby, but from DWC all 3.
                        Just testem with new FW and it works for heatbed. Buttons go gray when heatbed put to off state.
                        • wilrikerundefined
                          wilriker @BoA
                          @BoA Starting to feel a bit stupid here but how do you get the tool to go back into the off state via DWC?
                          Also for bed and chamber heaters that's something different because these are heaters. Tools have a state separate from their heater's state.
                          Manuel
                          My Tool Collection
                          BoAundefined 3 Replies Last reply Reply Quote 0
                          • BoAundefined
                            BoA @wilriker
                            @wilriker OK. Nevermind. All You wrote is true. Tool does no goes back to off. only heater does.
                              jay_s_uk
                              @wilriker when the tool is in standby, click it again and it goes to off
                              • BoAundefined
                                BoA @jay_s_uk
                                @jay_s_uk On heater - heater will go to off, but clicking on tool switches between stby and active
                                • BoAundefined
                                  BoA @wilriker
                                  @wilriker This is perhaps small issue with RRF not paneldue, but putting M116 P0 in tpost0.g seems to block refreshing tool status (and temperature refreshing) until temperature is reached.
                                  wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    jay_s_uk @BoA
                                    @BoA oh yea, i forget you can click both. ignore my previous comment
                                    • BoAundefined
                                      BoA @wilriker
                                      @wilriker And one small thing - When setting screensaver timeout I can not "unclick" the button to close selection like with i.e. Info Timeout
                                      • wilrikerundefined
                                        wilriker @BoA
                                        I tried but I cannot reproduce this. Will have to look some more into that.
                                        That's basically for all of the selection. Click on "Setup" on the bottom right to close it.
                                        EDIT: I put it on the list for the next release to auto-close it.
                                        Manuel
                                        My Tool Collection
                                        • BoAundefined
                                          BoA @wilriker
                                          @wilriker My scenario details:
                                          • tool is off/stby
                                          • set active temperature like 200*C
                                          • put tool to active to start heating
                                          Then refreshing stops until temp is reached.
                                          • wilrikerundefined
                                            wilriker @BoA
                                            @BoA Thanks for being so precise that always helps!
                                            I will most likely only get back to it next week, though.
                                            Did the new build fix the other reported issues?
                                            Manuel
                                            My Tool Collection
