    PanelDueFirmware 3.2-RC1 released
    PanelDue
    14
    48
    2.6k
    • wilrikerundefined
      wilriker @BoA
      @BoA Is that before or after the tool has been active at least once?
      Manuel
      My Tool Collection
      BoAundefined 1 Reply Last reply Reply Quote 0
      • BoAundefined
        BoA @wilriker
        @wilriker After. I can cycle through all 3 state from DWC. From panel only active<->stby, but from DWC all 3.
        Just testem with new FW and it works for heatbed. Buttons go gray when heatbed put to off state.
        • wilrikerundefined
          wilriker @BoA
          @BoA Starting to feel a bit stupid here but how do you get the tool to go back into the off state via DWC?
          Also for bed and chamber heaters that's something different because these are heaters. Tools have a state separate from their heater's state.
          Manuel
          My Tool Collection
          BoAundefined 3 Replies Last reply Reply Quote 0
          • BoAundefined
            BoA @wilriker
            @wilriker OK. Nevermind. All You wrote is true. Tool does no goes back to off. only heater does.
              jay_s_uk
              @wilriker when the tool is in standby, click it again and it goes to off
              • BoAundefined
                BoA @jay_s_uk
                @jay_s_uk On heater - heater will go to off, but clicking on tool switches between stby and active
                • BoAundefined
                  BoA @wilriker
                  @wilriker This is perhaps small issue with RRF not paneldue, but putting M116 P0 in tpost0.g seems to block refreshing tool status (and temperature refreshing) until temperature is reached.
                  wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @BoA
                    @BoA oh yea, i forget you can click both. ignore my previous comment
                    • BoAundefined
                      BoA @wilriker
                      @wilriker And one small thing - When setting screensaver timeout I can not "unclick" the button to close selection like with i.e. Info Timeout
                      • wilrikerundefined
                        wilriker @BoA
                        @BoA said in PanelDueFirmware 3.2-RC1 released:
                        I tried but I cannot reproduce this. Will have to look some more into that.
                        That's basically for all of the selection. Click on "Setup" on the bottom right to close it.
                        EDIT: I put it on the list for the next release to auto-close it.
                        Manuel
                        My Tool Collection
                        • BoAundefined
                          BoA @wilriker
                          @wilriker My scenario details:
                          • tool is off/stby
                          • set active temperature like 200*C
                          • put tool to active to start heating
                          Then refreshing stops until temp is reached.
                          • wilrikerundefined
                            wilriker @BoA
                            @BoA Thanks for being so precise that always helps!
                            I will most likely only get back to it next week, though.
                            Did the new build fix the other reported issues?
                            Manuel
                            My Tool Collection
                            • BoAundefined
                              BoA @wilriker
                              @wilriker Works like a charm 😄
                              • wilrikerundefined
                                wilriker @BoA
                                @BoA Thanks for confirming.
                                Manuel
                                My Tool Collection
                                • BoAundefined
                                  BoA @wilriker
                                  @wilriker Well... I do not how to say this... Moving head from panel does nothing 😞 tool active or not - does not matter. All axes homed.
                                    dc42 administrators @BoA
                                    That's an issue we already know about. It will require a change to RRF.
                                      A Former User @dc42
                                      @dc42 said in PanelDueFirmware 3.2-RC1 released:
                                      Those of you with older version 1 and version 2 PanelDues, please note that we do not expect this release to work on old PanelDue boards that use the ATSAM3S2B chip, due to lack of RAM. However, we do expect it to work on later version 2 PanelDues using the ATSAM3S4B chip. If you have a PanelDue using the ATSAM3S2B chip, we suggest you replace the board by a version 3 PanelDue board, which can drive your existing LCD.
                                      I really hope this is a joke and not real?
                                      In which reality did any sane person think that such a firmware "upgrade" which is going to require certain users of already purchased equipment to make a further purchase a good idea.
                                      I can understand that control board hardware evolves by a large degree but the display hardware...
                                      Users of older display equipment are left with two choices: buy an upgrade to said hardware or continue to use older firmware.
                                      I'm almost speechless with disbelief.
                                      Phaedruxundefined elmoretundefined 2 Replies Last reply Reply Quote -3
                                        Phaedrux Moderator @A Former User
                                        @CaLviNx said in PanelDueFirmware 3.2-RC1 released:
                                        What is the alternative? Halt development of paneldue features entirely? Do you still use your old 486 from 92 or did you upgrade that as well?
                                        Almost, but not quite.
                                        • elmoretundefined
                                          elmoret @A Former User
                                          How is this unlike literally any other software/hardware situation?
                                          You cannot run iOS 14 on a iPhone 3.
                                          You cannot run Windows 10 on a 286.
                                          You cannot flash the firmware of a 4k HDTV onto a 720p HDTV.
                                          Etc...
                                          • wilrikerundefined
                                            wilriker @BoA
                                            I have a slight idea what the reason could be although the code looks good. Will need to test and verify later.
                                            Again thanks for reporting.
                                            Manuel
                                            My Tool Collection
