    Smart effector and trigger height (and a few new grey hairs)
    Smart effector for delta printers
    1.9k
    • BoAundefined
      BoA
      I belive You need to set Z probe offset to 0.21, not -0.21
      • janjohundefined
        janjoh
        Readin (7) and (9) here in the linked article, it says to use the reported height. It also says that the smart effector should have a negative ofset. So..
        You may be correct, but in that case the documentation is highly unclear.
        • BoAundefined
          BoA
          I will describe a certain picture.
          Assumption - nozzle has to be pushed a little to trigger Z
          And imagine what is going on when probing. Nozzle touches bed, but not triggered yet, goes to -0.21mm and then it is triggered.
          Which means nozzle is at -0.21 when Z trigger, and in other words, Z triggers 0.21 above the nozzle tip.
          So, Z probe offset should be above the nozzle level (+0.21mm).
          OR
          You can assume Z trigger is at 0.00, and set tool offset in Z to -0.21
          Hope this short description helps to understand what and why is going on
          janjohundefined A Former User? 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt
            For the smart effector a negative value is correct.
            What does your M558 command look like?
            In step 10 you use G30 S-0. I can find no documentation for an S-0 parameter. Did you try just G30?
            janjohundefined 1 Reply Last reply Reply Quote 0
            • janjohundefined
              janjoh @BoA
              @BoA That, however, goes against both the linked article, AND what is stated in the commissioning guide for the smart effector https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer
              Just a quick check, do you actually use the Smart Effector with a positive offset on your machine?
              • janjohundefined
                janjoh @fcwilt
                @fcwilt I meant S-1, same as in step 6. Good catch. Edited.
                M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000
                • fcwiltundefined
                  fcwilt @janjoh
                  @janjoh said in Smart effector and trigger height (and a few new grey hairs):
                  G30 S-1 reports the trigger height.
                  In Step 5 you correctly set Z to a known height.
                  In Step 10 you home which likely sets Z to an incorrect height.
                  Remove the S-1 and just have G30. See if that doesn't fix things.
                  janjohundefined 1 Reply Last reply Reply Quote 1
                  • janjohundefined
                    janjoh @fcwilt
                    @fcwilt Noooooooooooo... (or rather yes)....
                    Yeah, that's spot on... at Z0.32 I can now get a 0.30 feeler in. At Z0.28 I can not.
                    So, that was flipping silly of me..... Especially as this means that my start script was correct, but my manual testing was (really) flawed... Sigh.
                    Nothing to see here... move on... 🙂
                    Thank you.
                    BoAundefined 1 Reply Last reply Reply Quote 1
                    • BoAundefined
                      BoA @janjoh
                      @janjoh So is the offset negative or positive after all ?
                      fcwiltundefined janjohundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @BoA
                        @BoA said in Smart effector and trigger height (and a few new grey hairs):
                        Negative.
                        When the nozzle is just touching the bed that is Z=0.
                        For the smart effector a bit more movement is needed to trigger the sensor.
                        At the point Z will be negative.
                        • janjohundefined
                          janjoh @BoA
                          @BoA Negative, as per the documentation.
                          • BoAundefined
                            BoA
                            OK. When Im thinking about it now, You are right, as G31 takes not the offset, but trigger height (which is effectively offset * -1). My bad.
                            • NexxCatundefined
                              NexxCat
                              From someone who bashed their head into a wall about this before. Make sure you perform the Z-probe offset and all probing with the bed and hotend heated. I use 60C on the bed and 130C on the nozzle.
                                A Former User @BoA
                                OR
                                I'm sorry but (your logic) Is 100% flawed
                                BoAundefined 1 Reply Last reply Reply Quote 0
                                • BoAundefined
                                  BoA @A Former User
                                  @CaLviNx What do You mean ?
                                    A Former User @BoA
                                    Really?
                                    • BoAundefined
                                      BoA @A Former User
                                      @CaLviNx Yes. I would say the only mistake is caused by Z offset beeing not the same as Z trigger height, and G31 takes trigger height, which in this case is offset * -1
                                      Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
                                        Phaedrux Moderator @BoA
                                        Z offset = z trigger height
                                        • BoAundefined
                                          BoA @Phaedrux
                                          @Phaedrux OK. I stand corrected
                                            A Former User @BoA
                                            I would say the prime mistake is YOU providing INCORRECT info.
                                            BoAundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
