    rehome.g not found
    2.5k
    • Marco Bonaundefined
      Marco Bona
      @Phaedrux, sending the video link while I start a printout. As you can see it is practically impossible to work this way. When I run M98 P-"start.g" from the DWC console, machine is functioning correctly, no rehome.g is performed when running the command.
      https://www.youtube.com/watch?v=T0eO3SE1cW8&t=182s
      "What happens if you step through the start.g manually command by command?"
      You mean some kind of single block? I ask why I don't know, how do I execute every single command?
        Phaedrux Moderator @Marco Bona
        @Marco-Bona said in rehome.g not found:
        Copy each line and paste it into the gcode console and execute them one at a time.
          Marco Bona
          @Phaedrux, I tried to run command by command but I don't see anything strange. The machine behaves correctly and the rehome.g file is not invoked. I remain of the idea that there is something in cura that creates some error
            Phaedrux Moderator @droftarts
            @droftarts said in rehome.g not found:
            ; If the printer hasn't been homed, home it if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28
            Can you test your start.g with this conditional section removed? As it is right now it will always home because the command before it turns off the V motor, so it will show as unhomed anyway.
            T2 P0 ;
            You also have a tool call in there. Can you post your tool files? Tpre tpost, etc
              I don't see anything in the slicer start gcode that looks out of place.
              ;FLAVOR:RepRap
              ;TIME:1692
              ;Filament used: 1.00837m, 0m
              ;Layer height: 0.15
              ;MINX:-9.255
              ;MINY:-35.116
              ;MINZ:0.15
              ;MAXX:9.259
              ;MAXY:34.982
              ;MAXZ:14.4
              ;POSTPROCESSED
              ;Generated with Cura_SteamEngine mb-master-20200822
              T0
              M82 ;absolute extrusion mode
              ;Sliced at: Sun 06-09-2020 12:09:56
              M104 T0 S175
              M190 S50
              M109 S205
              T0
              G21
              G90
              G92 E0
              G1 X-50 Z2.5 E20 F1500
              G92 E0
              G1 X50  Z0.15 F1000
              M117 Printing...
              ;T0                             ;switch to extruder 1
              ;G92 E0                      ;reset extruder distance
              ;G1 F2000 E93           ;load filament
              ;M104 S205
              M83 ;relative extrusion mode
              G10
              ;LAYER_COUNT:96
              G92 E0
              ;LAYER:0
              M107
              M204 T1000
              M566 X600 Y600
              G0 F2400 X6.196 Y0.892 Z0.15
              M204 P500
              ;TYPE:SKIRT
              G11
              Were you able to capture a video?
                Marco Bona
                @Phaedrux, I tried to remove the part of code you indicated but nothing has changed compared to before.
                The video of the problem I encountered I published in a previous post. here is the link
                Any changes made to start.g and files did not lead to any changes, result is always what you see in the video.
                I publish files related to tool change:
                tpre2.g tpost2.g tfree2.g
                  The video link is set to private and I can't see it.
                    Marco Bona
                    @Phaedrux, sorry, it's now set to public, it should be visible
                      So just to make sure I understand what I'm seeing. You're starting a print, and it goes to do it's homing process and it keeps detecting erroneous stall conditions and rehoming?
                      But you get no stall detections like this any other time?
                        Marco Bona
                        @Phaedrux , No, it occurs during the probing of the bed (G32) befoee printing. On other occasions it works fine, I mean if I run start.g from dwc as a test, not before printing. Is it possible that the problem arises from the lack of M204 in config.g?
                        In this case where does it get the acceleration values ​?
                          droftarts administrators @Marco Bona
                          @Marco-Bona From your video, it looks like the homing is happening 3 times. Is that correct? Or does it just go on repeating?
                          Lack of M204 shouldn't matter, it will just be set to default. Send M204 on it's own to see the set values, eg mine is not set in config.g, reports
                          M204
                          Maximum printing acceleration 10000.0, maximum travel acceleration 10000.0
                            Marco Bona
                            @Phaedrux, @droftarts, The homing works correctly, in the video starting from 40 seconds leadscrew leveling (M671) is performed and then probing for mesh compensation with G32 is performed. As you can see from the video, a stall is detected at 40 seconds even before starting to probe.
                            The really strange thing is that after adding M204 in config.g the frequency with which the wrong stall detection occurs has decreased.
                            • BoAundefined
                              BoA
                              If homing is correct, and stall is only in print, isn't that print uses faster travel speeds and acceleration than homing? From my experience this can trigger stall detection if sensitivity is too high (too low S param value).
                                Marco Bona
                                @BoA , This is correct, but I don't understand why if I run start.g from dwc, the commands are executed correctly while if start.g is called when starting the print motors keep stalling. I didn't find much explanation on setting the S value so I went a bit random (now it's set to 6) but occasionally when starting print an incorrect stall is detected.
                                BoAundefined 1 Reply Last reply Reply Quote 0
                                • BoAundefined
                                  BoA @Marco Bona
                                  @Marco-Bona Shortcut would be to disable stall detection action by setting R0 instead of R3 (sensorless homing still works)
                                  On my printer I have 2 macros with different speed/acceleration limits - one for homing - more sensitive setting lower speeds, and second for normal print to avoid false stall detection.
                                  Perhaps there are some commands in print gcode that change aceleration etc.
                                    Marco Bona
                                    @BoA ,I'm not using sensorless homing, I have normal optical sensors as limit switches, I use stall detection to prevent the motors from losing steps or the head colliding during printing.
                                    • BoAundefined
                                      BoA @Marco Bona
                                      @Marco-Bona OK then. I would just increase S level until no false stall detection occurs.
                                      And just a stupid question - do You actually have rehome.g in sys folder ?
                                        Marco Bona
                                        @BoA , Sorry for the confusion, initially for wrong name, rehome.g was not found (there was a space after the g), then the problem became that an incorrect motor stall is detected. In all honesty I don't know what to feel anymore because I have inconsistent data.
                                        • BoAundefined
                                          BoA
                                          Ok, What is Your current M915 configuration?
                                            Marco Bona
                                            @BoA , this is the one with which I found myself best
                                            M915 X Y  T20000 S6 H51 F1 R3
