    thermistor bad reading
    757
      Phaedrux Moderator @ninni
      @ninni said in thermistor bad reading:
      @Phaedrux sorry i dont understand
      veti said me that semitec-104nt o pt1000 is very ood sensor
      I linked you to the E3D Semitec-104GT thermistor cartridge which is what I think Veti was referring to. I don't think you'll find a better or easier to obtain thermistor with known values and appropriate form factor.
      ninniundefined 1 Reply Last reply Reply Quote 0
      • ninniundefined
        ninni @Phaedrux
        @Phaedrux ok tu so Much
          Does your hotend heat block take a cartridge thermistor or a glass bead?
          • ninniundefined
            ninni @Phaedrux
            @Phaedrux block thermistor
              Does it look like the little metal tube in the E3D link above, or does it look like a little glass bead?
              • ninniundefined
                ninni @Phaedrux
                @Phaedrux small metal tube
                  Then that E3D thermistor is the one you want.
                  • Vetiundefined
                    Veti
                    https://de.aliexpress.com/item/32859917151.html
                    this is the alternative pt1000
                    • ninniundefined
                      ninni @Veti
                      @Veti ok we Will see
                      • ninniundefined
                        ninni
                        also I would like to report a bug. when the endstop is positioned upwards for the z axis the platter stops when it touches the endstop but if you give the command again it continues to rise ignoring that the limit switch was already pressed
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:33:30 GMT+0200 (Ora legale dell’Europa centrale)
                        G91 ; relative positioning
                        G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X-235 ; home X axis
                        G1 H1 Y-215 ; home Y axis
                        G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
                        G1 H1 Y-215 ; then move slowly to Y axis endstop
                        G1 H1 Z205 F360 ; move Z up stopping at the endstop
                        G90 ; absolute positioning
                        G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
                        ;G91 ; relative positioning
                        ;G90 ; absolute positioning
                        ; homez.g
                        ; called to home the Z axis
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:34:47 GMT+0200 (Ora legale dell’Europa centrale)
                        G1 H1 Z205 F1800 ; move Z up until the endstop is triggered
                        config.g
                        M208 X0 Y0 Z-200 S1 ; set axis minima
                        M208 X230 Y210 Z0 S0 ; set axis maxima
                        M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                        droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          droftarts administrators @ninni
                          Not a bug; you have put in strange values for Z axis minima and maxima. Firmware expects all moves to be in the positive range; no CAM/ slicer outputs negative absolute coordinates.
                            dc42 administrators @ninni
                            The reason for that is the G1 H2 Z5 command in your homez.g file. That command tells the firmware to raise Z by 5mm, but that isn't appropriate when homing to max Z. You should probably remove the one in homeall.g too.
