    thermistor bad reading
    760
    • ninniundefined
      ninni @droftarts
      This post is deleted!
      • ninniundefined
        ninni @droftarts
        @droftarts ; Drives
        M569 P1 S0 ; physical drive 1 goes forwards
        M92 X200.00 Y200.00 Z800.00 E873.08 ; set steps per mm
        M566 X600.00 Y600.00 Z18.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z240.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
        M84 S30 ; Set idle timeout
        M208 X230 Y210 Z210 S0 ; set axis maxima
        M574 X1 S1 P"xstop" ; configure active-low endstop for high end on X via pin xstop
        M574 Y1 S1 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        M557 X0:22 Y0:22 S20 ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M143 H0 S250 ; set temperature limit for heater 0 to 120C
        M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
        M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
        M106 P1 S1 H1 T1 ; set fan 1 value. Thermostatic control is turned on
        M563 P1 D0 H1 F0 ; define tool 1
        T1 ; select first tool
          Phaedrux Moderator @ninni
          @ninni said in thermistor bad reading:
          @Phaedrux sorry i dont understand
          veti said me that semitec-104nt o pt1000 is very ood sensor
          I linked you to the E3D Semitec-104GT thermistor cartridge which is what I think Veti was referring to. I don't think you'll find a better or easier to obtain thermistor with known values and appropriate form factor.
          ninniundefined 1 Reply Last reply Reply Quote 0
          • ninniundefined
            ninni @Phaedrux
            @Phaedrux ok tu so Much
              Does your hotend heat block take a cartridge thermistor or a glass bead?
              • ninniundefined
                ninni @Phaedrux
                @Phaedrux block thermistor
                  Does it look like the little metal tube in the E3D link above, or does it look like a little glass bead?
                  • ninniundefined
                    ninni @Phaedrux
                    @Phaedrux small metal tube
                      Then that E3D thermistor is the one you want.
                      • Vetiundefined
                        Veti
                        https://de.aliexpress.com/item/32859917151.html
                        this is the alternative pt1000
                        • ninniundefined
                          ninni @Veti
                          @Veti ok we Will see
                          • ninniundefined
                            ninni
                            also I would like to report a bug. when the endstop is positioned upwards for the z axis the platter stops when it touches the endstop but if you give the command again it continues to rise ignoring that the limit switch was already pressed
                            ; homeall.g
                            ; called to home all axes
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:33:30 GMT+0200 (Ora legale dell’Europa centrale)
                            G91 ; relative positioning
                            G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                            G1 H1 X-235 ; home X axis
                            G1 H1 Y-215 ; home Y axis
                            G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y-215 ; then move slowly to Y axis endstop
                            G1 H1 Z205 F360 ; move Z up stopping at the endstop
                            G90 ; absolute positioning
                            G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
                            ;G91 ; relative positioning
                            ;G90 ; absolute positioning
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:34:47 GMT+0200 (Ora legale dell’Europa centrale)
                            G1 H1 Z205 F1800 ; move Z up until the endstop is triggered
                            config.g
                            M208 X0 Y0 Z-200 S1 ; set axis minima
                            M208 X230 Y210 Z0 S0 ; set axis maxima
                            M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                            droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              droftarts administrators @ninni
                              Not a bug; you have put in strange values for Z axis minima and maxima. Firmware expects all moves to be in the positive range; no CAM/ slicer outputs negative absolute coordinates.
                                dc42 administrators @ninni
                                The reason for that is the G1 H2 Z5 command in your homez.g file. That command tells the firmware to raise Z by 5mm, but that isn't appropriate when homing to max Z. You should probably remove the one in homeall.g too.
