BL Touch
Why not sure create a config file set from the config tool for your board type and firmware version and compare to what you have now. It's going to depend on your firmware version and how you have it hooked up, which you haven't mentioned.
https://configtool.reprapfirmware.org/Start
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
I completely replaced my gcode just in case i was doing something weird. Im rocking Firmware 2.03 (2019-06-13b2). The BL touch is mounted to the side of the Bondtech DDS system here is a picture for reference from the site:
I get the following error when z is independently homed and when homing all.G28 Z Error: M280: Invalid servo index 7 in M280 command Error: M280: Invalid servo index 7 in M280 command Error: Z probe already triggered at start of probing move Error: M280: Invalid servo index 7 in M280 command Error: Homing failed
Here is my config.g :
;config.g ; Configuration file for Duet WiFi (firmware version 2.03) ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:26 GMT-0600 (Mountain Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"A.C.E." ; set printer name M669 K0 ; select Cartesian mode ; Network M551 P"My password would be here" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; X physical drive 0 goes forwards M569 P1 S1 ; Y physical drive 1 goes forwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P3 S0 ; E physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Filament runout sensor ;M591 D0 P1 C3 S1 instead ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height M557 X15:485 Y15:485 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S75 ; set temperature limit for heater 0 to 75C M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S560 ; set temperature limit for heater 1 to 560C ; Fans M106 P0 S1.0 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P1 S0.0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S0.0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0:1 ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S45 ; set initial tool 0 active and standby temperatures to 45C ; Automatic power saving M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; Other settings ;G29 S1 ; Enable automatic bed mesh compensation ;M572 D0 S0.16 ; Enable pressure-advance ;M915 X Y S10 F1 R1 ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only ;M915 Z S0 F1 R1 ; Enable stall detection for Z axis with a sensitivity of 10 and report only ; Miscellaneous ;M501 ; Load saved parameters from non-volatile memory
home all gcode:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time) G91 ; relative positioning G1 H2 Z5 F9000 ; lift Z relative to current position G1 H1 X-505 Y-505 F3600 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F9000 ; go back a few mm G1 H1 X-505 Y-505 F600 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X15 Y15 F9000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F150 ; lift Z relative to current position ;G90 ; absolute positioning
home z gcode:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time) G91 ; relative positioning G1 H2 Z5 F9000 ; lift Z relative to current position G90 ; absolute positioning G1 X15 Y15 F9000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F150 ; lift Z relative to current position ;G90 ; absolute positioning
and bed gcode:
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:26 GMT-0600 (Mountain Daylight Time) M561 ; clear any bed transform G29 ; probe the bed and enable compensation
So did you try other values in the M280 commands to determine what is the correct value?
@fcwilt Lol, i dont even know what the M280 command is.
I fixed the first error however now im getting this:
G28 Z Error: Z probe already triggered at start of probing move Error: Homing failed
Well you should have system files deployprobe.g and retractprobe.g
deployprobe.g should have something like
M280 P0 S10 ; servo setting to drop pin on BLTouch v3.0
retractprobe.g should have something like
M280 P0 S00 ; servo setting to retract pin on BLTouch v3.0
The P parameter needs to be changed to match your setup.
Also do you have a G31 command somewhere else besides config.g?
The one there is strange. The P parameter should be 25 for the BL Touch.
The X and Y are likely not 0 - that would indicate the pin of the probe is exactly where the tip of the nozzle is.
The Z is likely not zero - that would indicate that when the probe triggers the Z position is Z=0.
My G31 looks like
G31 P24 X0 Y24.5 Z2.80
Yours needs to be updated to match your setup.
@Gost101 Post your M122 result and show which version of the firmware you have installed .
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later Board ID: 08DGM-95BLL-N6PSS-6JTD6-3SJ6K-K0UZJ Used output buffers: 3 of 24 (20 max)
M122
Here is the code you requested:
If your willing I have a disocrd that we could talk through at https://discord.gg/8RVDzx4:15:21 AMM122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later Board ID: 08DGM-917DA-G4MS8-6J1F4-3SN6S-1TV38 Used output buffers: 1 of 24 (8 max) === RTOS === Static ram: 25680 Dynamic ram: 93724 of which 0 recycled Exception stack ram used: 388 Never used ram: 11280 Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:01:04 ago, cause: software Last software reset at 2020-09-28 04:14, reason: User, spinning module GCodes, available RAM 11280 bytes (slot 2) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 27.7, current 27.9, max 28.3 Supply voltage: min 12.0, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 84/586 Driver 1: standstill, SG min/max 83/615 Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-09-28 04:15:19 Cache data hit count 235992943 Slowest loop: 4.17ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 34339ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is ready with "M122 " in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.42ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 2 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address ec:fa:bc:25:b8:10 WiFi Vcc 3.46, reset reason Turned on by main processor WiFi flash size 4194304, free heap 23552 WiFi IP address 10.0.0.209 WiFi signal strength -46dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0
@fcwilt
Heres my deploy and retract code:
Deploy:M280 P3 S10 ; servo setting to drop pin on BLTouch v3.0
Retract:
M280 P3 S00 ; servo setting to retract pin on BLTouch v3.0
Config after some changes:
;config.g ; Configuration file for Duet WiFi (firmware version 2.03) ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:26 GMT-0600 (Mountain Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"A.C.E." ; set printer name M669 K0 ; select Cartesian mode ; Network M551 P"SpaceForceHu2020!!" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; X physical drive 0 goes forwards M569 P1 S1 ; Y physical drive 1 goes forwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P2 S0 ; Z physical drive 2 goes backwards M569 P3 S0 ; E physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Filament runout sensor ;M591 D0 P1 C3 S1 instead ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P25 X0 Y24.5 Z2.80 ; set Z probe trigger value, offset and trigger height M557 X15:485 Y15:485 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S75 ; set temperature limit for heater 0 to 75C M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S560 ; set temperature limit for heater 1 to 560C ; Fans M106 P0 S1.0 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P1 S0.0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S0.0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0:1 ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S45 ; set initial tool 0 active and standby temperatures to 45C ; Automatic power saving M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; Other settings ;G29 S1 ; Enable automatic bed mesh compensation ;M572 D0 S0.16 ; Enable pressure-advance ;M915 X Y S10 F1 R1 ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only ;M915 Z S0 F1 R1 ; Enable stall detection for Z axis with a sensitivity of 10 and report only ; Miscellaneous ;M501 ; Load saved parameters from non-volatile memory
Home All:
Bed:
Hi.
You cannot use my values - they are specific to my hardware.
You have to determine values that are correct for your hardware.
The X parameter has to be the distance from the tip of your nozzle to the pin of the BL Touch along the X axis.
The Y parameter has to be the distance from the tip of your nozzle to the pin of the BL Touch along the Y axis.
The Z parameter has to be the Z position when the BL Touch triggers.
@fcwilt I roughly measured the X distance with calipers. the Y axis controls the bed going forward and backwards. How can I determine the Z value?
Have you tried moving to a different heater pin ?.
I could not get heater 3 working , so moved to heater 7. -
Ill move to heater 7, standby for code changes and status
@peter247 I moved to heater 7, no change
Are you getting power and self test when you first give it power ?
The pin does not drop or retract the bl touch is still blinking red while status code:
@peter247 Power and self test?
This post is deleted! -
Self test is when you first switch on the machine / give it power , the pin will deploy than retract and go solid red.
