    BL Touch
    126
    7.2k
    • Gost101undefined
      Gost101
      I completely replaced my gcode just in case i was doing something weird. Im rocking Firmware 2.03 (2019-06-13b2). The BL touch is mounted to the side of the Bondtech DDS system here is a picture for reference from the site: alt text
      I get the following error when z is independently homed and when homing all.
       G28 Z
      Error: M280: Invalid servo index 7 in M280 command
      Error: Z probe already triggered at start of probing move
      Error: Homing failed
      Here is my config.g :
      ;config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:26 GMT-0600 (Mountain Daylight Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"A.C.E."                                     ; set printer name
      M669 K0                                            ; select Cartesian mode
      M551 P"My password would be here"                         ; set password
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0 S1                                         ; X physical drive 0 goes forwards
      M569 P1 S1                                         ; Y physical drive 1 goes forwards
      M569 P2 S0                                         ; Z physical drive 2 goes backwards
      M569 P3 S0                                         ; E physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E415                     ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203X9000.00 Y9000.00 Z180.00 E6000.00             ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X500 Y500 Z500 S0                             ; set axis maxima
      M574 X1 Y1 S1                                      ; set active high endstops
      M574 Z1 S2                                         ; set endstops controlled by probe
      ; Filament runout sensor
      ;M591 D0 P1 C3 S1 instead
      M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T9000                              ; set Z probe type to bltouch and the dive height + speeds
      M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z0                                  ; set Z probe trigger value, offset and trigger height
      M557 X15:485 Y15:485 S20                           ; define mesh grid
      M305 P0 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S75                                        ; set temperature limit for heater 0 to 75C
      M305 P1 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 1
      M143 H1 S560                                       ; set temperature limit for heater 1 to 560C
      M106 P0 S1.0 I0 F500 H1 T50                        ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0.0 I0 F500 H-1                           ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0.0 I0 F500 H-1                           ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1                         ; define tool 1
      G10 P0 X0 Y0 Z0                            ; set tool 0 axis offsets
      G10 P0 R0 S45                              ; set initial tool 0 active and standby temperatures to 45C
      ; Automatic power saving
      ; Other settings
      ;G29 S1                                             ; Enable automatic bed mesh compensation
      ;M572 D0 S0.16                                      ; Enable pressure-advance
      ;M915 X Y S10 F1 R1                                ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only
      ;M915 Z S0 F1 R1                                   ; Enable stall detection for Z axis with a sensitivity of 10 and report only
      ;M501                                               ; Load saved parameters from non-volatile memory
      home all gcode:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time)
      G1 H2 Z5 F9000          ; lift Z relative to current position
      G1 H1 X-505 Y-505 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F9000       ; go back a few mm
      G1 H1 X-505 Y-505 F600  ; move slowly to X and Y axis endstops once more (second pass)
      G90                     ; absolute positioning
      G1 X15 Y15 F9000        ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      ;G91                    ; relative positioning
      ;G1 Z5 F150             ; lift Z relative to current position
      ;G90                    ; absolute positioning
      home z gcode:
      ; homez.g
      ; called to home the Z axis
      G1 X15 Y15 F9000 ; go to first probe point
      and bed gcode:
      ; bed.g
      G29  ; probe the bed and enable compensation
      • fcwiltundefined
        fcwilt
        So did you try other values in the M280 commands to determine what is the correct value?
        • Gost101undefined
          Gost101
          @fcwilt Lol, i dont even know what the M280 command is.
          • Gost101undefined
            Gost101
            I fixed the first error however now im getting this:
            G28 Z
            • fcwiltundefined
              fcwilt @Gost101
              @Gost101 said in BL Touch:
              Well you should have system files deployprobe.g and retractprobe.g
              deployprobe.g should have something like
              M280 P0 S10 ; servo setting to drop pin on BLTouch v3.0
              retractprobe.g should have something like
              M280 P0 S00 ; servo setting to retract pin on BLTouch v3.0
              The P parameter needs to be changed to match your setup.
              Also do you have a G31 command somewhere else besides config.g?
              The one there is strange. The P parameter should be 25 for the BL Touch.
              The X and Y are likely not 0 - that would indicate the pin of the probe is exactly where the tip of the nozzle is.
              The Z is likely not zero - that would indicate that when the probe triggers the Z position is Z=0.
              My G31 looks like
              G31 P24 X0 Y24.5 Z2.80
              Yours needs to be updated to match your setup.
              Gost101undefined 1 Reply Last reply Reply Quote 0
              • peter247undefined
                peter247 @Gost101
                @Gost101 Post your M122 result and show which version of the firmware you have installed .
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-95BLL-N6PSS-6JTD6-3SJ6K-K0UZJ
                Used output buffers: 3 of 24 (20 max)
                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                • Gost101undefined
                  Gost101
                  @peter247 said in BL Touch:
                  M122
                  Here is the code you requested:
                  If your willing I have a disocrd that we could talk through at https://discord.gg/8RVDzx
                  4:15:21 AMM122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-917DA-G4MS8-6J1F4-3SN6S-1TV38
                  Used output buffers: 1 of 24 (8 max)
                  Static ram: 25680
                  Dynamic ram: 93724 of which 0 recycled
                  Exception stack ram used: 388
                  Never used ram: 11280
                  Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 00:01:04 ago, cause: software
                  Last software reset at 2020-09-28 04:14, reason: User, spinning module GCodes, available RAM 11280 bytes (slot 2)
                  Error status: 0
                  Free file entries: 10
                  MCU temperature: min 27.7, current 27.9, max 28.3
                  Supply voltage: min 12.0, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 84/586
                  Driver 1: standstill, SG min/max 83/615
                  Date/time: 2020-09-28 04:15:19
                  Cache data hit count 235992943
                  Slowest loop: 4.17ms; fastest: 0.07ms
                  Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 34339ms
                  === DDARing ===
                  Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  Segments left: 0
                  Movement lock held by null
                  http is ready with "M122 " in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 15.42ms; fastest: 0.00ms
                  HTTP sessions: 2 of 8
                  - WiFi -
                  Network state is running
                  WiFi firmware version 1.23
                  WiFi MAC address ec:fa:bc:25:b8:10
                  WiFi Vcc 3.46, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 23552
                  WiFi IP address 10.0.0.209
                  WiFi signal strength -46dBm, reconnections 0, sleep mode modem
                  • Gost101undefined
                    Gost101 @fcwilt
                    @fcwilt
                    Heres my deploy and retract code:
                    Deploy:
                    M280 P3 S10 ; servo setting to drop pin on BLTouch v3.0
                    Retract:
                    M280 P3 S00 ; servo setting to retract pin on BLTouch v3.0
                    Config after some changes:
                    ;config.g
                    M551 P"SpaceForceHu2020!!"                         ; set password
                    M558 P9 H5 F100 T2000                              ; set Z probe type to bltouch and the dive height + speeds
                    G31 P25 X0 Y24.5 Z2.80                             ; set Z probe trigger value, offset and trigger height
                    ; Other settings
                    Home All:
                    Bed:
                    fcwiltundefined peter247undefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @Gost101
                      @Gost101
                      Hi.
                      You cannot use my values - they are specific to my hardware.
                      You have to determine values that are correct for your hardware.
                      The X parameter has to be the distance from the tip of your nozzle to the pin of the BL Touch along the X axis.
                      The Y parameter has to be the distance from the tip of your nozzle to the pin of the BL Touch along the Y axis.
                      The Z parameter has to be the Z position when the BL Touch triggers.
                      • Gost101undefined
                        Gost101
                        @fcwilt I roughly measured the X distance with calipers. the Y axis controls the bed going forward and backwards. How can I determine the Z value?
                        • peter247undefined
                          peter247 @Gost101
                          @Gost101
                          Have you tried moving to a different heater pin ?.
                          I could not get heater 3 working , so moved to heater 7.
                          • Gost101undefined
                            Gost101
                            Ill move to heater 7, standby for code changes and status
                            • Gost101undefined
                              Gost101
                              @peter247 I moved to heater 7, no change
                              peter247undefined 1 Reply Last reply Reply Quote 0
                              • peter247undefined
                                peter247 @Gost101
                                @Gost101
                                Are you getting power and self test when you first give it power ?
                                • Gost101undefined
                                  Gost101
                                  The pin does not drop or retract the bl touch is still blinking red while status code:
                                  G28 Z
                                  • Gost101undefined
                                    Gost101 @peter247
                                    @peter247 Power and self test?
                                    • peter247undefined
                                      peter247 @Gost101
                                      still blinking red
                                      That is a important bit to tell !!!!!
                                      • Gost101undefined
                                        Gost101
                                        This post is deleted!
                                        • peter247undefined
                                          peter247 @peter247
                                          @peter247
                                          Self test is when you first switch on the machine / give it power , the pin will deploy than retract and go solid red.
                                          • Gost101undefined
                                            Gost101 @peter247
                                            @peter247 It hasn't done that yet so far even after multiple reboots.
