    Prints stopping mid print and duet rebooting.
    1.9k
    • KeithWundefined
      KeithW
      Another one, wasn't even printing just preheating the bed on these 2.
      [[language]]
      M122
      Used output buffers: 2 of 32 (9 max)
      Static ram used: 45820
      Dynamic ram used: 39916
      Recycled dynamic ram: 280
      Stack ram used: 1088 current, 4440 maximum
      Never used ram: 7848
      Last reset 00:01:17 ago, cause: software
      Last software reset code 0x7000, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0042f00f, BFAR 0xe000ed38, SP 0xffffffff
      Spinning module during software reset: Platform, available RAM 7232 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 21.0MBytes/sec
      SD card longest block write time: 0.0ms
      MCU temperature: min 28.8, current 31.9, max 34.9
      Date/time: 2017-05-23 20:26:31
      Slowest main loop (seconds): 0.006279; fastest: 0.000099
      MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Free connections: 15 of 16
      Free transactions: 23 of 24
      Locked: 1, state: 4, listening: 0x20071b54, 0x0, 0x0
      === Webserver ===
      HTTP sessions: 1 of 8
      FTP connections: 0, state 0
      Telnet connections: 0, state 0
        That's the first time I've ever seen a software reset code of 0x70xx reported. Which firmware version are you running? Please upgrade to 1.18.1 if you are running an older version
        • elmoretundefined
          elmoret
          Could we get firmware version in the M122 code? Would help for these M122 dumps.
          • KeithWundefined
            KeithW
            I am already on 1.18.1, Is it worth reinstalling this version,? Is there anything else I can do? I initially thought it was a heat issue but these last 2 resets have happened within minutes of turning on the Printer and starting preheat of the bed so the CPU temp got to no more than 35c or so.
              I suggest you reinstall 1.18.1 just in case a flash cell is not fully programmed.
              Reset code 0x70xx indicates that a debug exception, SVCall or PendSV exception occurred. None of those should happen unless the firmware is corrupt, or the return stack has been corrupted. If the problem persists then I will change the firmware to give a stack dump for those exceptions like some other exceptions do. [Actually, I will probably do that anyway.]
              • KeithWundefined
                KeithW
                Ok thanks I'll do that tonight.
                • KeithWundefined
                  KeithW
                  Well I flashed the firmware but it is still resetting.
                  [[language]]
                  M122
                  Used output buffers: 2 of 32 (18 max)
                  Stack ram used: 1088 current, 4432 maximum
                  Never used ram: 7856
                  Last reset 00:04:10 ago, cause: software
                  Last software reset code 0x7003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0042f00f, BFAR 0xe000ed38, SP 0xffffffff
                  Spinning module during software reset: GCodes, available RAM 4908 bytes (slot 1)
                  Error status: 0
                  MCU temperature: min 50.4, current 51.0, max 54.4
                  Date/time: 2017-05-25 19:46:46
                  Slowest main loop (seconds): 0.004745; fastest: 0.000092
                  Segments left: 0
                  === Network ===
                  === Webserver ===
                  • KeithWundefined
                    KeithW
                    Do you think it might make a difference if I flash the firmware using Bossac rather than the web interface?
                    • KeithWundefined
                      KeithW
                      Well I have erased and reinstalled using Bossac and so far so good, Hope I don't jinx the print but it is halfway through a 2 hour print and is still going which is more than it has done for a while.
                      • KeithWundefined
                        KeithW
                        Well the print finished but when I went to upload a new file to print the Duet reset again.
                        M122
                        Used output buffers: 2 of 32 (30 max)
                        Stack ram used: 1088 current, 4408 maximum
                        Never used ram: 7880
                        Last reset 00:00:17 ago, cause: software
                        Spinning module during software reset: GCodes, available RAM 4956 bytes (slot 0)
                        Error status: 0
                        MCU temperature: min 42.8, current 45.3, max 47.7
                        Date/time: 2017-05-26 21:34:11
                        Slowest main loop (seconds): 0.018618; fastest: 0.000104
                        Segments left: 0
                        === Network ===
                        === Webserver ===
                        • KeithWundefined
                          KeithW
                          This is still happening almost every print.
                          [[language]]
                          14:02:05
                          M122
                          Stack ram used: 1088 current, 4804 maximum
                          Never used ram: 7484
                          Last reset 00:08:59 ago, cause: software
                          Last software reset code 0x7004, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0042f00f, BFAR 0xe000ed38, SP 0xffffffff
                          Spinning module during software reset: Move, available RAM 5228 bytes (slot 3)
                          Error status: 0
                          MCU temperature: min 40.1, current 41.9, max 47.7
                          Date/time: 2017-06-02 14:02:05
                          Slowest main loop (seconds): 0.006195; fastest: 0.000061
                          Heater 0 is on, I-accum = 0.0
                          Heater 1 is on, I-accum = 0.3
                          Segments left: 0
                          === Network ===
                          === Webserver ===
                            That software reset code indicates that the firmware was stuck in a spin loop for too long, and although it was executing Move module code at the time, the network lock was active and the firmware was trying to do USB output. Have you accidentally enabled debugging? To check, run M111 with no parameters. It should report that debugging is off.
