Solved Tool setup: Motor, Extruder & Heater mapping
@kroybal said in Tool setup: Motor, Extruder & Heater mapping:
"Error response too long"
Send from the gcode console window itself.
Have you set the address of your toolboards?
https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Commissioning_a_new_Tool_Board
Error: Bad command: H143 H3 S300
I'm not sure if it matters, but I notice you are definining heaters 2 and 3 before you define heaters 0 and 1. I suggest rearranging that to start with 0 and move up from there.
@Phaedrux said in Tool setup: Motor, Extruder & Heater mapping:
I sent "M98 P"config.g" as a command through the Console tab using the DWC and it still reports "Response too long, see Console". I am pretty certain I am sending the command through the gcode console window, unless there is another prompt which I can send code.
Check later for an updated edit. I will work on addressing the toolboards now.
EDIT: according to the section
https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Buttons_and_LEDs
I am not seeing a flashing red LED whatsoever, which would suggest sync between the board and my Duet3. I do have the Vin LED fired up indicating power. Perhaps there is a common wiring issue that can occur here?Describing my setup I have an RJ11 wire going straight through to my distribution board, and on my tool distribution board I have jumpers across the CAN out standoff. I also have jumpers across the bypass standoffs on T2 and T3 ports (I am planning to only use T0 & T1.) Currently the distribution board is grabbing 24V & 15A. I have two CAN-FD cables running straight through from the distribution board to my two separate toolboards.
@kroybal as you describe this it should work.
to help with diagnosis can you try one tool board at a time. (with the jumper to bypass the other). Also its worth checking the continuity between the Duet 3 CAN header and the tool distribution board CAN header (you can do this with a multimeter with the power turned off)
As well as the blue VIN LED on the tool board being lit when you apply VIN power, is the red 5V LED next to it lit?
@T3P3Tony I have yet to check for continuity I will get to that when I reinstall the boards. I have reduced the setup to just the one toolboard for now and will add the other once its properly commissioned.
EDIT: I checked for continuity from one end of the JST ZH to the opposite and each pin had continuity across. I did the same for the RJ11 cable that I am using. every wire/pin being used is in operating condition.
@dc42 I did not see the 5V lit, I was wondering why it failed to turn on. The only light indication is the Vin blue LED. I have removed the setup from my black box to get a clearer image of the setup.
Assume the RJ11 is connected to the CAN_out on the duet3 I also have a heater, and a motor connected via molex. Pardon the image quality, however, the jumpers seem to be appropriately placed. I am grabbing 24V 15A from a power supply to my distribution board. Does anything stand out as to why the board doesn't show the 5V red LED or cannot be addressed using M115 B121/B10?
@dc42 When you brought the 5V LED to question I had checked the power supply and it was not operating as expected. My issues stem from the most trivial solution. Does it have power
glad you found the problem!
