    Tool setup: Motor, Extruder & Heater mapping
    687
      deckingman @kroybal
      @kroybal So your heater definitions looks about right at a glance. You have H0 as the bed, H1 as the chamber, and H2 and 3 being the two hot end heaters. But your tool definitions are wrong. For the left tool you have M563 P0 S"LEFT" D0 H3 but if you want to use heater 2, the you need to change that H3 to H2. Similarly, for the right tool you have M563 P1 S"RIGHT" D1 H4 but heater 4 does not exist and if you want it to be heater 3, then you need to change that H4 to H3.
      One other thing that leapt out at me (but is unrelated to heaters) is this
      M350 X16 Y16 Z16 U16 E16:16 E1.9:2.0
      That "E1.9:2.0" on the end makes no sense - remove it.
      Oh, and I don't see any M669 at the beginning of your config.g to define the kinematics type either. I guess that'll be OK if your kinematics happen to be the default which I think is Cartesian.
      kroybalundefined 1 Reply Last reply Reply Quote 0
      • kroybalundefined
        kroybal @deckingman
        ; ======={ Tools}==========================================
        M563 P0 S"LEFT" D0 H2 				; define tool 0
        G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
        G10 P0 R35 S150                                 ; set initial tool 0 active and standby temperatures to 0C
        M563 P1 S"RIGHT" D1 H3			        ; define tool 1
        G10 P1 X0 Y0 Z0                                 ; set tool 1 axis offsets
        G10 P1 R35 S150                                 ; set initial tool 1 active and standby temperatures to 0C
        With the updated corrections the DWC still shows that my Tool-0 and my Tool-1 have no assigned heaters.
        @deckingman said in Tool setup: Motor, Extruder & Heater mapping:
        RE: I removed it, I am pretty sure that just spat out from the configurator. I still have to calibrate once I get everything ready to move and heat.
        RE: It is being ran under a cartesian setup.
          Can you send M98 P"config.g" and report the results?
          • kroybalundefined
            kroybal @Phaedrux
            I have some wires not connected, such as AC the signal wire for the IDEC relay for both the bed and chamber. My hotends are capable of going above 400C from what I've been told.
            @Phaedrux
            9/30/2020, 4:02:14 PM Error: Response timeout: CAN addr 2, req type 6026, RID=18
            Error: Heater 3 not found
            Error: Bad command: H143 H3 S300
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
            9/30/2020, 4:02:12 PM Error: Response timeout: CAN addr 1, req type 6017, RID=14
            Response timeout: CAN addr 2, req type 6017, RID=15
            Error: bad grid definition: Too many grid points; suggest increase spacing to 21.2mm
            Error: Response timeout: CAN addr 1, req type 6026, RID=16
            Error: Heater 2 not found
            Error: Bad command: H143 H2 S300
            9/30/2020, 4:02:07 PM Error: Response timeout: CAN addr 1, req type 6021, RID=12
            Response timeout: CAN addr 2, req type 6021, RID=13
            Error: in file macro line 42 column 50: M203: array too long, max length = 2
            9/30/2020, 4:02:05 PM Error: Response timeout: CAN addr 2, req type 6018, RID=11
            9/30/2020, 4:02:04 PM Error: Response timeout: CAN addr 1, req type 6018, RID=10
            "Error response too long"
              Phaedrux Moderator @kroybal
              @kroybal said in Tool setup: Motor, Extruder & Heater mapping:
              Send from the gcode console window itself.
                Have you set the address of your toolboards?
                https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Commissioning_a_new_Tool_Board
                I'm not sure if it matters, but I notice you are definining heaters 2 and 3 before you define heaters 0 and 1. I suggest rearranging that to start with 0 and move up from there.
                • kroybalundefined
                  kroybal @Phaedrux
                  @Phaedrux said in Tool setup: Motor, Extruder & Heater mapping:
                  I sent "M98 P"config.g" as a command through the Console tab using the DWC and it still reports "Response too long, see Console". I am pretty certain I am sending the command through the gcode console window, unless there is another prompt which I can send code.
                  Check later for an updated edit. I will work on addressing the toolboards now.
                  EDIT: according to the section
                  https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Buttons_and_LEDs
                  I am not seeing a flashing red LED whatsoever, which would suggest sync between the board and my Duet3. I do have the Vin LED fired up indicating power. Perhaps there is a common wiring issue that can occur here?
                  Describing my setup I have an RJ11 wire going straight through to my distribution board, and on my tool distribution board I have jumpers across the CAN out standoff. I also have jumpers across the bypass standoffs on T2 and T3 ports (I am planning to only use T0 & T1.) Currently the distribution board is grabbing 24V & 15A. I have two CAN-FD cables running straight through from the distribution board to my two separate toolboards.
                  • kroybalundefined
                    kroybal
                      T3P3Tony administrators
                      @kroybal as you describe this it should work.
                      to help with diagnosis can you try one tool board at a time. (with the jumper to bypass the other). Also its worth checking the continuity between the Duet 3 CAN header and the tool distribution board CAN header (you can do this with a multimeter with the power turned off)
                        dc42 administrators @kroybal
                        As well as the blue VIN LED on the tool board being lit when you apply VIN power, is the red 5V LED next to it lit?
                        kroybalundefined 2 Replies Last reply Reply Quote 0
                        • kroybalundefined
                          kroybal @T3P3Tony
                          @T3P3Tony I have yet to check for continuity I will get to that when I reinstall the boards. I have reduced the setup to just the one toolboard for now and will add the other once its properly commissioned.
                          EDIT: I checked for continuity from one end of the JST ZH to the opposite and each pin had continuity across. I did the same for the RJ11 cable that I am using. every wire/pin being used is in operating condition.
                          • kroybalundefined
                            kroybal @dc42
                            @dc42 I did not see the 5V lit, I was wondering why it failed to turn on. The only light indication is the Vin blue LED. I have removed the setup from my black box to get a clearer image of the setup.
                            Assume the RJ11 is connected to the CAN_out on the duet3 I also have a heater, and a motor connected via molex. Pardon the image quality, however, the jumpers seem to be appropriately placed. I am grabbing 24V 15A from a power supply to my distribution board. Does anything stand out as to why the board doesn't show the 5V red LED or cannot be addressed using M115 B121/B10?
                            • kroybalundefined
                              kroybal @dc42
                              @dc42 When you brought the 5V LED to question I had checked the power supply and it was not operating as expected. My issues stem from the most trivial solution. Does it have power 😵
                                glad you found the problem!
