help to setup M557 Mesh size
@Phaedrux said in help to setup M557 Mesh size:
uncheck only retract when crossing open spaces, check force retraction between layers, enable minimum travel for retraction, 3mm is fine, and uncheck wipe extruder for outer-most perimeters.
I meant these specifically.
yes i have changed this
I'm going to sleep now, good luck on your test print.
thanks mate !
have a good sleep -
is it possible to save the pressuere advance ?
M572 D0 S0.04because i send everytime when i turn on printer the M572 Command
thanks
put it in your config.g
somewhere in the config.g ?
i have mine at the end after tool definition
Hi
after i solved the issues above i have problem with G29 my bed is not flat or is it ok ?
my bltouch setup in config.g:
M558 P9 C"^zprobe.in" T8000 A5 R0.5 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch G31 P25 X41.2 Y4.5 Z2.096 ; set Z probe trigger value, offset and trigger height M557 X41.2:221.2 Y4.5:219.5 S20 ; define mesh grid
my results in hightmap.csv:
RepRapFirmware height map file v2 generated at 2020-10-06 10:18, min error -0.078, max error 0.066, mean -0.019, deviation 0.031 xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum 41.20,221.20,4.50,219.50,-1.00,20.00,20.00,10,11 0.053, 0.040, 0.066, 0.051, 0.025, 0.042, 0.046, 0.021, -0.008, 0.004 0.003, -0.012, 0.030, 0.025, 0.002, 0.012, 0.016, -0.013, -0.048, -0.025 -0.022, -0.022, 0.020, 0.018, -0.004, -0.000, 0.001, -0.028, -0.060, -0.037 -0.053, -0.057, -0.008, -0.007, -0.035, -0.030, -0.021, -0.044, -0.075, -0.053 -0.060, -0.060, -0.021, -0.019, -0.044, -0.037, -0.019, -0.043, -0.066, -0.042 -0.078, -0.075, -0.028, -0.033, -0.053, -0.038, -0.018, -0.037, -0.063, -0.033 -0.068, -0.065, -0.024, -0.032, -0.054, -0.034, -0.016, -0.033, -0.058, -0.028 -0.041, -0.051, -0.017, -0.022, -0.052, -0.040, -0.018, -0.030, -0.052, -0.015 -0.024, -0.041, -0.007, -0.014, -0.033, -0.020, -0.002, -0.017, -0.035, -0.014 -0.034, -0.046, -0.012, -0.014, -0.028, -0.009, 0.008, -0.000, -0.025, 0.008 -0.012, -0.024, 0.015, 0.018, 0.010, 0.043, 0.041, 0.013, -0.008, 0.017
It would be easier for us to tell if you posted an image of the height map as displayed by DWC.
thats no problem
That looks good enough to print on to me!
ok i will give a try
bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
Here's a good first layer test pattern.
Try it once with G29 S1 enabled, and once without.
