    New firmware bundle 3.2beta2
    Beta Firmware
    21
    49
    2.7k
      deckingman @T3P3Tony
      @T3P3Tony said in New firmware bundle 3.2beta2:
      @deckingman yes, this is mini 5+ support for the existing can expansion boards
      That doesn't really answer my question which is, does the list of firmware limitations stated here https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
      also apply to the mini 5 CAN expansion?
      Or to put it another way, when you say "Supports Duet 3 Mini version 0.4 prototypes including CAN expansion", does that mean fully supported expansion boards or only partly supported as is the case with existing Duet3 and expansion boards?
      • Stephen6309undefined
        Stephen6309
        What happened to viewing the Height Map?
          Phaedrux Moderator @Stephen6309
          @Stephen6309 said in New firmware bundle 3.2beta2:
          From the release notes: The Height Map has been moved to a built-in plugin (see Settings -> General -> Plugins)
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
            Stephen6309 @Phaedrux
            @Phaedrux It would be the one I didn't read far enough. 🙂
            • GrodanBundefined
              GrodanB
              Do not know if related to above but I cannot get any change in extrudes amount when sending
              M221 S120.0 D1
              or
              M221 S100.0 D1
              This is my calibration script. I measure 120 mm and put a marker on the filament run this script asking for 100mm extrusion... and the difference is put in the filament config file...
              This has worked fine in 2.x
              T0                      	; Select first hot end
              G21                     	; Metric
              G90                     	; Absolute positioning
              M83                     	; Relative extrusion
              M118 S"Homing Axis."    	; Output progress message
              G28                     	; Home all axis
              M118 S"Docking Printhead."	; Output progress message
              G1 X70 Y200 F3000       	; Move first in front of docking notch
              G1 X70 Y235 F3000       	; Dock print head
              T1                      	; Select second hot end
              M116						; Wait until all set tempteratures are reached
              G92 E0                  	; Set Position of extruder to zero
              G1 E100 F200            	; Extrude 100mm
              M118 S"100mm Extruded."    	; Output progress message
              G1 X70 Y0 F3000         	; Move to front to make it easier to measure amount extruded
                dc42 administrators @GrodanB
                @GrodanB said in New firmware bundle 3.2beta2:
                The bed temp reaches 85 and when the heater PT element reports 223.8 (reading the documentation this is the expected behaviour that now M701 call is done and M703 shall be run) my printer resets and all temperatures are set to 0 and tool 1 is set to inactive.
                If you can reproduce that, please run M122 immediately after the uncommanded reset and post the result here.
                GrodanBundefined 2 Replies Last reply Reply Quote 0
                  M221 no longer affects extruder-only moves.
                  • GrodanBundefined
                    GrodanB
                    @dc42 said in New firmware bundle 3.2beta2:
                    Why?
                    And just for my curiosity when does it affect the extrusion?
                    This was so great to have in my config and keep my e-steps for the extruder constant.
                    Is there an alternative?
                    Did miss that completely when upgrading.
                    • GrodanBundefined
                      GrodanB @dc42
                      @dc42 Yes, I'll test that ASAP. Just printing a my first larger part on 3.2 and after that I'll try.
                      So ASAP is probably very late or tomorrow...
                      So far everything else is working great.
                      • Luke'sLaboratoryundefined
                        Luke'sLaboratory
                        I've been having similar issues - when it goes to pick up the tools when I start a print, it tells me that my there isn't any heaters or anything on Board 1 (3hc, where I have my tools) and cancels and forces (via webpage) a reset of the whole printer. I'm unable to pull a M122 from the web, so I'll have to give it a shot via a different utility to get better diagnostic data.
                        M122
                        RepRapFirmware for Duet 3 MB6HC version 3.2-beta2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                        Board ID: 08DGM-9T66A-G63SJ-6J1DG-3SD6K-9V0MA
                        Used output buffers: 1 of 40 (14 max)
                        Static ram: 157532
                        Dynamic ram: 138164 of which 44 recycled
                        Exception stack ram used: 528
                        Never used ram: 96948
                        Tasks: Linux(ready,20) HEAT(blocked,278) CanReceiv(blocked,873) CanSender(blocked,352) CanClock(blocked,353) TMC(blocked,20) MAIN(running,1208) IDLE(ready,20)
                        Owned mutexes: HTTP(MAIN)
                        Last reset 02:55:36 ago, cause: software
                        Last software reset at 2020-10-06 18:29, reason: User, Platform spinning, available RAM 97344, slot 0
                        Software reset code 0x0000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task Linu
                        Error status: 0x00
                        MCU temperature: min 40.0, current 41.8, max 44.7
                        Supply voltage: min 23.8, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                        Driver 0: position 49600, standstill, reads 53251, writes 27 timeouts 0, SG min/max 0/349
                        Driver 1: position 46400, standstill, reads 53252, writes 27 timeouts 0, SG min/max 0/365
                        Driver 2: position 24000, standstill, reads 53256, writes 23 timeouts 0, SG min/max 0/65
                        Driver 3: position 12300, standstill, reads 53257, writes 23 timeouts 0, SG min/max 0/294
                        Driver 4: position 0, standstill, reads 53257, writes 23 timeouts 0, SG min/max 0/284
                        Driver 5: position 0, standstill, reads 53258, writes 23 timeouts 0, SG min/max 0/284
                        Date/time: 2020-10-06 21:25:17
                        Slowest loop: 7274.81ms; fastest: 0.21ms
                        === Storage ===
                        Free file entries: 10
                        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 2570081ms
                        === MainDDARing ===
                        Scheduled moves: 43, completed moves: 43, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP* is ready with "M122" in state(s) 0
                        Telnet is idle in state(s) 0
                        File* is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty.
                        === CAN ===
                        Messages sent 42212, send timeouts 42212, longest wait 2ms for type 6013, free CAN buffers 48
                        === SBC interface ===
                        State: 0, failed transfers: 0
                        Last transfer: 18ms ago
                        RX/TX seq numbers: 44751/16533
                        SPI underruns 0, overruns 0
                        Number of disconnects: 0
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v3.2.0-beta2
                        Code buffer space: 4096
                        Full transfers per second: 32.68
                        Luke
                        http://lukeslab.online
                          Why?
                          So that adjusting the extrusion factor doesn't affect the retract or reprime length, or filament loading/unloading. The extrusion factor affects moves with simultaneous XY motion and extrusion.
                          GrodanBundefined 1 Reply Last reply Reply Quote 0
                          • Nuramoriundefined
                            Nuramori @dc42
                            I’m not sure what changed, but I went from a well functioning printer (blv cube) to a hot mess of bed crashes and inability to properly probe the bed for leveling using the bltouch. Nothing changed in hardware or config.sys. I was only able to get it working again by fully reverting to 3.1.1. The bed probing did double probes, the movement from probe point to probe point would be erratic with a strange pause and slow movement, and almost always would at the third probe point, return to 0,0 then go back to probing. It would never really finish the bed mesh probe. It would probe the three mount points (independent three z-axis) but wouldn’t adjust the bed level. I nearly wrecked the thing on one probe where it just drove itself into the bed and then slide to the back to home the y axis.
                            The bltouch is on a toolboard 0.6 if it matters. Yes I had updated the firmware on the toolboard. I have a panel due but that was not updated.
                            This was a bad release and I am nervous about trying another beta at this point.
                            oozeBotundefined 1 Reply Last reply Reply Quote 0
                            • oozeBotundefined
                              oozeBot @Nuramori
                              @Nuramori said in New firmware bundle 3.2beta2:
                              I experienced nearly the same thing with a Duet3/RPi and a toolboard. I was only able to resolve it by rolling back to 3.2b1.. but, I spent a bit of time on it again this morning only to realize that rrf hadn't been properly updated. Can you validate yours has been updated? I wasn't able to reproduce the issue you described after running M997 again and validating rrf was properly updated on my Duet 3..
                              • Nuramoriundefined
                                Nuramori
                                I had double checked that it was updated, using M115 and M122 for both the board and tool board. I'm hesitant to try it again, but I can if it will help. I upgraded via "apt update" followed by "apt upgrade.' I have the source.list for the duet repository set to unstable prior to this, and had changed it to stable after reverting.
                                oozeBotundefined 2 Replies Last reply Reply Quote 0
                                • oozeBotundefined
                                  oozeBot @Nuramori
                                  @Nuramori this morning, as a safeguard after rolling forward, I uploaded the 3.2b2 firmware through DWC.. and I haven’t seen the issue again. I don’t think I screwed the upgrade up, but yeah.. I dunno. It was doing all sorts of strange things- G30 would probe once, lift way too high, and fail on the second pass. Or it wouldn’t deploy the probe at all and dive into the bed.. I plan on rolling back and forth a few more times to see if I can recreate it, but I think I must have somehow not properly upgraded the firmware.
                                  • seraserundefined
                                    seraser
                                    Duetwifi, tested fysetc mini 12864 version 1.2 and 2.1 and dont work, only backlight in version 1.2 nothing in version 2.1, rotate encoder and restart in two versions, connected direct exp1 mini to LCD exp and exp2 mini to sd exp.
                                    Tested many M918 configurations but if rotate encoder restart duet is not config related.
                                    Maybe bad pin asignement in firmware?
                                    Thank you.
                                    • GrodanBundefined
                                      GrodanB @dc42
                                      Why?
                                      Ahh, ok I see... This could explain my improved print quality on my start and stops in RRF3.2...
                                      But that makes calibration harder then.
                                      Would it be possible to have some sort of "force/apply compensation" feature to use in the calibration?
                                      (I guess no slicer will use this...) Because I would like to make sure I applied the correct calibration.
                                      My workflow for a new filament is to do this controlled extrusion, check the error, enter the compensation, verify that the compensation is correct... if not start over until correct amount is extruded.
                                      For now I need to either use e-steps (so I can verify but then I guess I get back my start stop issues) or hope that I did not miscalculate and blindly use the value. I think I'll use the value blindly even if I'll risk that not seeing any mistake until the part is done.
                                      achrnundefined 1 Reply Last reply Reply Quote 0
                                      • GrodanBundefined
                                        GrodanB @dc42
                                        Easy to reproduce but M122 seems to do nothing... Or I do something wrong...
                                        But I there is a failure message I previously missed... may be a hint at least.
                                        update... seemed I was to quick... resend M122 gave this:
                                        M122
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.0 or 1.01 + DueX5
                                        Board ID: 08DAM-999TL-MQ4SD-6J9F0-3S86T-14A7Y
                                        Used output buffers: 3 of 24 (24 max)
                                        Static ram: 24028
                                        Dynamic ram: 101188 of which 44 recycled
                                        Exception stack ram used: 264
                                        Never used ram: 5548
                                        Tasks: NETWORK(ready,139) HEAT(blocked,308) DUEX(blocked,36) MAIN(running,451) IDLE(ready,19)
                                        Owned mutexes: WiFi(NETWORK)
                                        Last reset 00:06:14 ago, cause: software
                                        Last software reset at 2020-10-08 10:07, reason: AssertionFailed, GCodes spinning, available RAM 5196, slot 0
                                        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN
                                        Stack: 0000059e 004716a8 00450849 00000008 ffffffff 20000e10 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4
                                        Error status: 0x04
                                        MCU temperature: min 22.5, current 23.0, max 23.3
                                        Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                        Driver 0: position 0, standstill, SG min/max not available
                                        Driver 1: position 0, standstill, SG min/max not available
                                        Driver 2: position 0, standstill, SG min/max not available
                                        Driver 3: position 0, standstill, SG min/max not available
                                        Driver 4: position 0, standstill, SG min/max not available
                                        Driver 5: position 0, standstill, SG min/max not available
                                        Driver 6: position 0, standstill, SG min/max not available
                                        Driver 7: position 0, standstill, SG min/max not available
                                        Driver 8: position 0, standstill, SG min/max not available
                                        Driver 9: position 0, standstill, SG min/max not available
                                        Driver 10: position 0
                                        Driver 11: position 0
                                        Date/time: 2020-10-08 10:14:18
                                        Cache data hit count 620253408
                                        Slowest loop: 19.32ms; fastest: 0.17ms
                                        === Storage ===
                                        SD card 0 detected, interface speed: 12.0MBytes/sec
                                        SD card longest read time 1.4ms, write time 6.1ms, max retries 0
                                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Heater 0 is on, I-accum = 0.0
                                        Heater 1 is on, I-accum = 0.0
                                        Segments left: 0
                                        HTTP is idle in state(s) 0
                                        File is idle in state(s) 0
                                        Trigger is idle in state(s) 0
                                        === Network ===
                                        Slowest loop: 201.84ms; fastest: 0.11ms
                                        HTTP sessions: 1 of 8
                                        - WiFi -
                                        Network state is active
                                        Failed messages: pending 0, notready 0, noresp 1
                                        WiFi firmware version 1.24beta2-05b1
                                        WiFi MAC address 5c:cf:7f:2b:e6:9b
                                        WiFi Vcc 3.31, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 25184
                                        WiFi IP address 192.168.1.15
                                        WiFi signal strength -47dBm, reconnections 0, sleep mode modem
                                        Clock register 00002002
                                        Socket states: 0 4 0 0 0 0 0 0
                                        === DueX ===
                                        Read count 0, 0.00 reads/min
                                        TCundefined 1 Reply Last reply Reply Quote 0
                                          A Former User
                                          Is it not an idea to use the Mk1 eyeball while printing a small test piece to allow you to adjust the extrusion factor for that particular material on the fly ?
                                            T3P3Tony administrators @deckingman
                                            @deckingman the work on the can support for mini 5+ did not change the functionality on any of the expansion boards.
