Duet 2 Ethernet no connection
2.0k
    camposm7
    I have a Duet 2 that stopped connecting to the network via ethernet and will not take commands over usb via YAT or Pronterface. Everything was working fine then suddenly I couldn't web into it. Any ideas or suggestions?
      A Former User
      not a whole lot of info there, might start with
      https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        camposm7
        What additional info should I include? I can't pull any info from the board. I turned on the printer, the LCD indefinitely displays connecting . When I connect it via USB, my computer recognizes the board, it seems to connect to YAT but when I send commands I get no response.
        I've tried erasing the board via the erase pins, nothing. Please let me know if there is any specify and pertinent information I may have left out.
        undefined undefined ? 3 Replies Last reply 6 Oct 2020, 19:51 Reply Quote 0
          Stephen6309 @camposm7
          @camposm7 Since you erased the firmware, you need to put it back on.
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
          Did you try a different ethernet cable?
          undefined 1 Reply Last reply 7 Oct 2020, 16:07 Reply Quote 0
            Phaedrux Moderator @camposm7
            @camposm7 said in Duet 2 Ethernet no connection:
            Well how far along do you get when following this document?
            It sounds like you should try flashing the board with recent firmware using bossa as described.
            undefined 1 Reply Last reply 7 Oct 2020, 16:43 Reply Quote 0
              camposm7 @Stephen6309
              @Stephen6309 Yes, I've tried several ethernet cables, as well as USB cords.
                camposm7 @Phaedrux
                @Phaedrux @Stephen6309 I've tried all steps in that document. When I try to flash with Bossa, it completes the flash, and it verifies. The board is still unresponsive though.
                  A Former User @camposm7
                  well, that link does tell yo do check a whole lot of things, we're not psychics..
                  that happens if the erase jumper is left in place or the board is not reset after flashing, i find the command line version bossac easier because -R flag to the command automatically reset the board.
                  undefined 1 Reply Last reply 7 Oct 2020, 18:17 Reply Quote 0
                    camposm7 @A Former User
                    @bearer When I try to run Bossac the windows briefly flashes then closes. Is there another download for windows somewhere?
                    ? 1 Reply Last reply 7 Oct 2020, 18:20 Reply Quote 0
                      its a command line version, i.e you start a command line window and type in the command (after changing to the appropriate path as required)
                      search and yee shall find
                      https://forum.duet3d.com/search/?term=bossac.exe&in=titlesposts
                        camposm7
                        I think I was able to flash the firmware successfully. Windows device manager didn't recognize the board until I reset it a few times.
                        Still no response in YAT when I throw M115 at it. Maybe I am missing a step in configuring YAT!
                        ? 1 Reply Last reply 7 Oct 2020, 18:23 Reply Quote 0
                          prey tell; what does it recognize it as? if it shows up as a bossa device then its not flashed properly; if it shows up as a duet then you're good, if it shows up as something else then check the usb device id or install the correct drivers.
                          undefined 1 Reply Last reply 7 Oct 2020, 18:47 Reply Quote 0
                            @beare It does indeed show up as bossa device.
                              Ok well at least it's showing up as something. Since it's showing as a bossa device it means it doesn't have firmware on it.
                              Please carefully go through the bossa flashing procedure here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
                              undefined 1 Reply Last reply 7 Oct 2020, 19:21 Reply Quote 0
                                camposm7 @Phaedrux
                                @Phaedrux The directions say Check boxes Erase all, Lock, and Boot from Flash. However there is no boot to flash check box. Am I supposed to check boot to flash?
                                  Can you show a screenshot of the bossa window? If you're on windows you should be able to press alt-print screen and then cntrl-v in the post window to paste a screenshot.
                                  undefined 1 Reply Last reply 7 Oct 2020, 19:39 Reply Quote 0
                                    camposm7 @Phaedrux
                                      yes I think boot to flash and boot from flash are meant to be the same.
                                      What version of bossa is that?
                                        camposm7
                                        v. 1.9.1
                                          Ok, so does it write and verify correctly?
                                          Did you follow the instructions on removing the jumper before flashing?
                                          Remove the erase jumper as soon as the Diag LED lights up. This means you are successfully in programming mode.
                                          Once flashed, power cycle the board and you should now have a port to connect with YAT.
                                          8 out of 44
