    Duet 2 Ethernet no connection
    2.1k
      A Former User @camposm7
      @camposm7 said in Duet 2 Ethernet no connection:
      I followed the instructions to the T, however my diag led is on even after removing the jumper and resetting.
      I think something got lost in translation to be honest, but that is why I suggested using the command line version with the -R flag as it removes the need for manually resetting the board.
      Maybe someone could file an issue on the bossa github to have the -R flag function added to the GUI version; would simplify things a little.
      • camposm7undefined
        camposm7 @Phaedrux
        @Phaedrux I was able to flash the firmware, and while I can now web into the board and shows connection established, my PanelDue contently displays Connecting. None of my macros are displayed on the panel although the web interface does display my macros. My extruder heaters are undefined. No thermistor readings. Some weird things happening. Even a simple M119 reports Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: at min stop
        I'm not even sure where to begin with this. It's like it isn't reading the config file properly. Using the same config I was previously using that was working fine before erasing the board and starting fresh
        • Vetiundefined
          Veti
          that sounds like you flashed rrf3.
          this requires some changes in the config. see
          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
          post your config.g
          camposm7undefined 1 Reply Last reply Reply Quote 0
            It may be helpful to create a fresh config set using the online configurator then you can compare it to your current config and see what's all changed.
            https://configtool.reprapfirmware.org/Start
            • camposm7undefined
              camposm7 @Veti
              @Veti
              What is the best method to post my config for ease of reading?
              • Vetiundefined
                Veti
                post the config.g file into the window here
                select it and press the code button
                • camposm7undefined
                  camposm7
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 05 2020 07:51:50 GMT-0800 (Pacific Standard Time)
                  G90                                             ; send absolute coordinates...
                  M83                                             ; ...but relative extruder moves
                  M550 P"S110 Tall"                               ; set printer name
                  M552 P0.0.0.0 S1                                ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1                                      ; enable HTTP
                  M586 P1 S0                                      ; disable FTP
                  M586 P2 S0                                      ; disable Telnet
                  M569 P0 S1                                      ; physical drive 0 goes forwards
                  M569 P1 S0                                      ; physical drive 1 goes forwards
                  M569 P2 S0                                      ; physical drive 2 goes forwards
                  M569 P3 S0                                      ; physical drive 3 goes forwards
                  M569 P4 S0                                      ; physical drive 4 goes forwards
                  M584 X0 Y1 Z2 E3:4                              ; set drive mapping
                  M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
                  M92 X400.00 Y400.00 Z400.00 E420.00:420.00      ; set steps per mm
                  M566 X700.00 Y700.00 Z212.00 E120.00:120.00     ; set maximum instantaneous speed changes (mm/min)
                  M203 X4000.00 Y4000.00 Z1000.00 E400.0:400.0  ; set maximum speeds (mm/min)
                  M201 X200.00 Y200.00 Z80.00 E250.00:250.00     ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E500:500 I50                ; set motor currents (mA) and motor idle factor in per cent
                  M84 S50                                         ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                ; set axis minima
                  M208 X210 Y260 Z500 S0                          ; set axis maxima
                  M574 X1 Y1 S1                                   ; set active high endstops
                  M574 Z1 S1                                      ; set endstops controlled by [probe] no, by microswitch 03/07/2020
                  Z-Probe
                  M307 H3 A-1 C-1 D-1                             ; disable heater on PWM channel for BLTouch
                  M558 P9 H1 F120 T5000                           ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X0 Y20 Z2.5                            ; set Z probe trigger value, offset and trigger height
                  M557 X10:200 Y10:200 S80                        ; define mesh grid
                  M305 P0 T100000 B4339 R4700                     ; configure PT1000 for heater 0
                  M143 H0 S100                                    ; set temperature limit for heater 0 to 100C
                  M305 P1 T500000 B4723 C1.196220e-7 R4700        ; set thermistor + ADC parameters for heater 1
                  M143 H1 S250                                    ; set temperature limit for heater 1 to 350C
                  M305 P2 T500000 B4723 C1.196220e-7 R4700        ; set thermistor + ADC parameters for heater 2
                  M143 H2 S250                                    ; set temperature limit for heater 2 to 350C
                  M307 H1:2 A250 c160 D5.5 B0 S0.3 		; set max heater power to 60% to reduce overshoot (DNC 03/12/2020)
                  M106 P0 S0 I0 F500 H-1                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1:2 T45                     ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S1 I0 F500 H1:2 T45                     ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                                ; define tool 0
                  G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
                  G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
                  M563 P1 D1 H2 F1                                ; define tool 1
                  G10 P1 X0 Y0 Z0                                 ; set tool 1 axis offsets
                  G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                  • Vetiundefined
                    Veti
                    did you do any manual changes in the config.
                    you could use the config.json (if you still have that) and use that as a starting point in the configurator.
                    • camposm7undefined
                      camposm7 @Veti
                      @Veti I ran a comparison of the two config files after generating a new one. I've taken over someone else project but luckily I did find the previously used json. Going to boot up and see what happens.
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 10 2020 12:16:23 GMT-0700 (Pacific Daylight Time)
                      M550 P"The Beast"                                        ; set printer name
                      M552 S1                                                   ; enable network
                      M569 P1 S1                                                ; physical drive 1 goes forwards
                      M569 P2 S1                                                ; physical drive 2 goes forwards
                      M569 P3 S1                                                ; physical drive 3 goes forwards
                      M569 P4 S1                                                ; physical drive 4 goes forwards
                      M566 X900.00 Y900.00 Z12.00 E120.00:120.00                ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00           ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 E250.00:250.00                ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E800:800 I30                          ; set motor currents (mA) and motor idle factor in per cent
                      M574 X1 S1 P"xstop"                                       ; configure active-high endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                                       ; configure active-high endstop for low end on Y via pin ystop
                      M574 Z1 S1 P"zstop"                                       ; configure active-high endstop for low end on Z via pin zstop
                      M950 S0 C"exp.heater3"                                    ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
                      M308 S0 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 0 as thermistor on pin e0temp
                      M950 H0 C"e0heat" T0                                      ; create nozzle heater output on e0heat and map it to sensor 0
                      M307 H0 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                      M308 S1 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e1temp
                      M950 H1 C"e1heat" T1                                      ; create nozzle heater output on e1heat and map it to sensor 1
                      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                      M308 S2 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 2 as thermistor on pin bedtemp
                      M950 H2 C"bedheat" T2                                     ; create bed heater output on bedheat and map it to sensor 2
                      M307 H2 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H2                                                   ; map heated bed to heater 2
                      M143 H2 S280                                              ; set temperature limit for heater 2 to 280C
                      M950 F0 C"fan0" Q500                                      ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 C"E0 Fan" S1 H1:2 T45                             ; set fan 0 name and value. Thermostatic control is turned on
                      M950 F1 C"fan1" Q500                                      ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 C"E1 Fan" S1 H1:2 T45                             ; set fan 1 name and value. Thermostatic control is turned on
                      M950 F2 C"fan2" Q500                                      ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 C"Layer Fan" S1 H-1                               ; set fan 2 name and value. Thermostatic control is turned off
                      M563 P0 S"Extruder 0" D0 H1 F0:2                          ; define tool 0
                      M563 P1 S"Extruder 1" D1 F0:2                             ; define tool 1
                      M575 P1 S1 B57600                                         ; enable support for PanelDue
                      • Vetiundefined
                        Veti
                        you will need the new retract and deploy scripts as well
                        • camposm7undefined
                          camposm7 @Veti
                          @Veti I have most of RR3 setup now, but I can not for the life of me get the BL Touch to deploy or retract or release it's alarm. I've been pulling my hair out over this.
                            Post your deploy and retract files.
                            M280 P0 S10 should work. If it does not, then perhaps you aren't using the pin you think you're using or the wire isn't making a connection.
                            M280 P0 S10 ; deploy BLTouch
                            M280 P0 S90 ; retract BLTouch
                            Are you sure you're connected to expansion heater pin 3?
                            • camposm7undefined
                              camposm7
                              I have the printer up and running now thanks to all your help. Couple more questions for you- I have a 5v layer fan that I'd like to use as fan2. Fan0 and Fan1 are my 24v hotend fans. I understand I can use this by using a jumper. I'm not sure which jumper and how I would need to modify the config file.
                              Second question is, is it possible to run a 5v servo motor
                              with only the duet2 or do I need an expansion board?
                                Phaedrux Moderator @camposm7
                                You won't be able to use the jumper in this case, because it would change all of the fan ports to 5v. What you COULD do however, is use the 5v pin on that jumper block to power the fan and have the negative wire go to the Fan2 negative terminal. The fans are switched on the negative side.
                                This is similar to how you would run 12v fan on 24v PSU.
                                https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
                                As for the 5v servo, I'm not sure. Would need more information on the servo. You may be able to do something similar with 5v power provided to the servo and then the negative side switched by a heater terminal.
                                https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins
                                • camposm7undefined
                                  camposm7
                                  So last week I fried my board while trying to get a reading with my multimeter. It actually fried the micro SD card which is a first for me. Lost my config file that I of course did not have backed up. Today I installed a new board but now I am having several issues...
                                  Firstly, my PanelDue 5i is not functioning at all and it is enabled in the config.
                                  Secondly my z end stop seems to be the only functioning end stop. It is the only switch that lights up the LED.
                                  Next, when trying to move an axis I am given the following error "Warning: motor phase B may be disconnected reported by driver(s) 2"
                                  Last thing I am noticing is that the BL Touch is not deploying and retracting when I boot the machine up.
                                  How about we just start with that. Where do I even begin??
                                    A Former User
                                    New board as in new Duet, and still having the problems listed?
                                    How is this being powered?
                                    • camposm7undefined
                                      camposm7 @A Former User
                                      @bearer Yes, new Duet2 Ethernet V 1.04c. The previous board was v1.04b
                                      It's being powered by a 24v Power supply
                                        What were you trying to get a read of? What was shorted?
                                        Any visible damage? Can you get a clear shot of the front of the board?
                                        • camposm7undefined
                                          camposm7 @Phaedrux
                                          @Phaedrux I'm not worried about the old board, but I shorted it out trying to read a fan voltage. It's definitely toasted. The new board, though, that isn't working straight out of the box. This is the board I referred to above.
                                            @camposm7 Would you be able to start a new thread for your new board? Let's leave your old thread behind. It took me a while to go through the whole thread to figure out where we are at.
                                            In your new thread, include your duet board type, the firmware version installed, the results of M122 and M98 P"config.g" and a copy of your config.g and homing files. If there is a specific piece of hardware not working include details about how you have it wired. Photos/videos are also helpful.
