New Duet 2 extruder not working
@Phaedrux reprapi3d.aliexpress.com offficial reprap store ali express .. under electrical parts. motherboards you find the "latest" ethernet board
Thanks. Definitely a clone.
@GG
here you can see the list of genuine resellers
https://www.duet3d.com/GenuineResellers -
@Phaedrux Cheers for that, ru still able to help me or do I have to buy genuine aarticle GG
@GG
did you make the changes pheadrux told you to do? -
Of course we will still try to help you. We just can't provide any hardware warranty, but I don't think you have a hardware problem.
@Phaedrux Thanks for that much appreciated. Yes Iv e now changed the M203 z to 600 and that made it work well. I can now home all 3 axis on dwc, consistently, but seems like panel due is reading a different config. Also setting z 0 offset tutorial says save z0 in config g In G31 command, I dont have a G31, do I just create one. My dwc version doesnt have system editor either ?? cause it says to use this to save Z0 reading, is mine later or earlier version ?
@GG said in New Duet 2 extruder not working:
i would advise you to make any big changes in the online configurator and upload all files again after the changes. introducing a probe makes a lot of changes in the config, especially the homing.
my dwc version doesnt have system editor either ?? cause it says to use this to save Z0 reading, is mine later or earlier version ?
which version of dwc are you running? as far as i know all versions have an editor.
I think some screen shots or videos are in order so we can see what's happening.
From previous experience, the clone boards come with something like version 2.02 of RRF and can be near impossible to upgrade without using BOSSA. They also tend to come with DWC 1.
I would suggest using BOSSA to bring the firmware up to at least 2.05.1. After that, upgrading through system works fine. -
Ah yes we never did get the output of M122.
Regardless of what 2.x version, updating should be as easy as uploading the full zip file for 2.05.1 as is (don't extract first) to the sys folder in DWC.
@Phaedrux it should be but I've had 2 cloned boards and neither would upgrade that way
Thats interesting; unless the sd card contents of 2.02 is missing the iap file for 2.02 its very strange the update wouldn't work, unless the microcontroller is a dodgy clone as seen on some arduinos with "atmega328" - but thats perfectly possible i guess.
either that or they've locked the firmware in a way that can only be overwritten by BOSSA.
And no manner of combined firmware files or anything would work. Nothing in console to say why. The firmware updates just weren't applied.
All very odd. -
@jay_s_uk said in New Duet 2 extruder not working:
locked the firmware
thats possible, could be interesting to see the output from the info button before writing a new firmware with bossa.
@Phaedrux This is the response to M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later
Board ID: 0JD0M-9K662-MGPSS-6J9DG-3S86M-KBVYZ
Used output buffers: 1 of 24 (14 max)
Static ram: 25712
Dynamic ram: 92884 of which 296 recycled
Exception stack ram used: 320
Never used ram: 11860
Tasks: NETWORK(ready,764) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:10 ago, cause: power up
Last software reset at 2020-10-12 17:34, reason: User, spinning module GCodes, available RAM 11700 bytes (slot 1)
Error status: 0
Free file entries: 10
MCU temperature: min 24.2, current 25.1, max 25.2
Supply voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-10-13 10:32:25
Cache data hit count 138625344
Slowest loop: 1.31ms; fastest: 0.08ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 3.89ms; fastest: 0.06ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex
=== Filament sensors ===
Extruder 0 sensor: ok
10/13/2020, 10: -
@Phaedrux said in New Duet 2 extruder not working:
So it looks like you have 2.05 installed, which is fine. Upload that zip file I linked above and see if it will install 2.05.1 and DWC 2.0.7 correctly.
@Phaedrux Tried to upload that zip file through the "upload system files " tab in dwc it shows them uploading but then the upload button circular indicator just keeps circling and no changes made even after reboot. I just need to know how to put my z offset "7.45mm" into the config. Definitely something strange with paneldue, when I try to home x it moves diagonally to the x endstop then when I home y it completes the z homing to bed centre. attached screen shot of dwc.as you can see all three axis homed from Paneldue but in a totally different way to DWC homing ?? also screen shot of system dwc showing no" system editor"
You have a sys folder inside of your sys folder. That's probably the cause of the problem.
When youve selected the system tab on the left the folder you see is the /sys folder on the SD card so if you've been putting files into another sys folder they aren't being accessed there.
@Phaedrux Yes you are right and looking at the date it is one I somehow created, however when I right click on the folder and try to delete it comes back with, " Failed to delete system, please make sure this .directory is empty,, also
Error:Failed to delete file0: /sys/sys
