    New Duet 2 extruder not working
    4.3k
      I think some screen shots or videos are in order so we can see what's happening.
        jay_s_uk
        From previous experience, the clone boards come with something like version 2.02 of RRF and can be near impossible to upgrade without using BOSSA. They also tend to come with DWC 1.
        I would suggest using BOSSA to bring the firmware up to at least 2.05.1. After that, upgrading through system works fine.
          Ah yes we never did get the output of M122.
          Regardless of what 2.x version, updating should be as easy as uploading the full zip file for 2.05.1 as is (don't extract first) to the sys folder in DWC.
          jay_s_ukundefined GGundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
            jay_s_uk @Phaedrux
            @Phaedrux it should be but I've had 2 cloned boards and neither would upgrade that way
              A Former User
              Thats interesting; unless the sd card contents of 2.02 is missing the iap file for 2.02 its very strange the update wouldn't work, unless the microcontroller is a dodgy clone as seen on some arduinos with "atmega328" - but thats perfectly possible i guess.
                jay_s_uk
                either that or they've locked the firmware in a way that can only be overwritten by BOSSA.
                And no manner of combined firmware files or anything would work. Nothing in console to say why. The firmware updates just weren't applied.
                All very odd.
                  A Former User
                  @jay_s_uk said in New Duet 2 extruder not working:
                  locked the firmware
                  thats possible, could be interesting to see the output from the info button before writing a new firmware with bossa.
                  • GGundefined
                    GG @Phaedrux
                    @Phaedrux This is the response to M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later
                    Board ID: 0JD0M-9K662-MGPSS-6J9DG-3S86M-KBVYZ
                    Used output buffers: 1 of 24 (14 max)
                    Static ram: 25712
                    Dynamic ram: 92884 of which 296 recycled
                    Exception stack ram used: 320
                    Never used ram: 11860
                    Tasks: NETWORK(ready,764) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:01:10 ago, cause: power up
                    Last software reset at 2020-10-12 17:34, reason: User, spinning module GCodes, available RAM 11700 bytes (slot 1)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 24.2, current 25.1, max 25.2
                    Supply voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
                    Date/time: 2020-10-13 10:32:25
                    Cache data hit count 138625344
                    Slowest loop: 1.31ms; fastest: 0.08ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                    === DDARing ===
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 3.89ms; fastest: 0.06ms
                    HTTP sessions: 1 of 8
                    Interface state 5, link 100Mbps full duplex
                    === Filament sensors ===
                    Extruder 0 sensor: ok
                    10/13/2020, 10:
                      Phaedrux Moderator @Phaedrux
                      @Phaedrux said in New Duet 2 extruder not working:
                      @GG said in New Duet 2 extruder not working:
                      So it looks like you have 2.05 installed, which is fine. Upload that zip file I linked above and see if it will install 2.05.1 and DWC 2.0.7 correctly.
                      GGundefined 2 Replies Last reply Reply Quote 0
                      • GGundefined
                        GG @Phaedrux
                        @Phaedrux Tried to upload that zip file through the "upload system files " tab in dwc it shows them uploading ![alt text](image url)but then the upload button circular indicator just keeps circling and no changes made even after reboot. I just need to know how to put my z offset "7.45mm" into the config. Definitely something strange with paneldue, when I try to home x it moves diagonally to the x endstop then when I home y it completes the z homing to bed centre. attached screen shot of dwc.as you can see all three axis homed from Paneldue but in a totally different way to DWC homing ?? also screen shot of system dwc showing no" system editor"20201013_115419.jpg
                          You have a sys folder inside of your sys folder. That's probably the cause of the problem.
                          When youve selected the system tab on the left the folder you see is the /sys folder on the SD card so if you've been putting files into another sys folder they aren't being accessed there.
                          • GGundefined
                            GG @Phaedrux
                            @Phaedrux Yes you are right and looking at the date it is one I somehow created, however when I right click on the folder and try to delete it comes back with, " Failed to delete system, please make sure this .directory is empty,, also
                            Error:Failed to delete file0: /sys/sys
                              jay_s_uk @GG
                              @GG you can't delete folders that have something in through DWC.
                              Go into the folder and delete all the files first. then you can delete the folder
                                If the files you've been editing are in that second /sys folder, you should move those files into the root /sys folder rather than deleting the files.
                                Another way would be to pop your SD card into a PC and edit the folder structure that way.
                                It should look like this: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                                GGundefined 1 Reply Last reply Reply Quote 0
                                • GGundefined
                                  GG @Phaedrux
                                  @Phaedrux Thanks folks, I got rid of that sys folder within system folder but the paneldue still behaves strangely, If I try to home x with paneldue, it homes slowly diagonally to the x home position then tells me error G0/G1: insufficient axis homed, then if I press print to clear the error page, and press home y, it homes all very slowly. Back to previous question, how to put my Z offset into config g I guess the slicer will need this, do I just enter g31 and the offset . Chers
                                    Ok now that you've got that sorted, please post your homex, homey, homez, and homeall files from the system folder that remains. Also your config.g from there as well.
                                    The z offset for the probe is set in G31 in config.g
                                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                    • GGundefined
                                      GG
                                      I will as soon as I get dwc back it seems to have dropped off after deleting those folders. maybe this is relevant?
                                        I think you should put the SD card in a PC and compare the folder structure to the link I posted earlier.
                                        • GGundefined
                                          GG @Phaedrux
                                          ; homex.g
                                          ; called to home the X axis
                                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 16:21:04 GMT+0800 (中国标准时间)
                                          G91               ; relative positioning
                                          G1 H2 Z5 F6000    ; lift Z relative to current position
                                          G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 H2 X5 F6000    ; go back a few mm
                                          G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
                                          G1 H2 Z-5 F6000   ; lower Z again
                                          G90               ; absolute positioning;
                                          homey.g
                                          ; called to home the Y axis
                                          G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 H2 Y5 F6000    ; go back a few mm
                                          G1 H1 Y-215 F360  ; move slowly to Y axis e; homez.g
                                          ; called to home the Z axis
                                          G1 X150 Y150;     move probe to bed centre
                                          G30 ;        Probez0
                                          G1 X0 Y0;      return to home position
                                          ;G91              ; relative positioning
                                          ;G1 Z5 F100       ; lift Z relative to current position
                                          ;G90              ; absolute positioning
                                          ; homeall.g
                                          ; called to home all axes
                                          G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 H2 X5 Y5 F6000       ; go back a few mm
                                          G1 H1 X-235 Y-215 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                          G30;                  probe z0
                                          G1 X0 Y0 ;            return to home pos
                                          G90                                             ; send absolute coordinates...
                                          M83                                             ; ...but relative extruder moves
                                          M550 P"My Printer"                              ; set printer name
                                          M669 K1                                         ; core xy mode
                                          M555 P2                                         ; set output to look like marlin
                                          G21                                             ; work in mm,s
                                          M552 S1                                         ; enable network
                                          M586 P0 S1                                      ; enable HTTP
                                          M586 P1 S0                                      ; disable FTP
                                          M586 P2 S0                                      ; disable Telnet
                                          M569 P0 S1                                      ; physical drive 0 goes forwards
                                          M569 P1 S1                                      ; physical drive 1 goes forwards
                                          M569 P2 S0                                      ; physical drive 2 goes backwards
                                          M569 P3 S1                                      ;  physical drive 3 goes backwards
                                          M569 P4 S0                                      ; physical drive 4 goes backwards
                                          ;Dual Z
                                          M584 X0 Y1 Z2:4 E3                              ;
                                          M671 X-100:415 Y160:160 S2.0 ;
                                          M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z400.00 E396.00      ; set steps per mm
                                          M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
                                          M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                                          M906 X800 Y800 Z800 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30                                         ; Set idle timeout
                                          M208 X-100 Y-30 Z0 S1                                ; set axis minima
                                          M208 X310 Y310 Z380 S0                          ; set axis maxima
                                          M574 X1 Y1  S0                                ; set active low and disabled endstops
                                          ;Filament Run Out Sensor
                                          M591 D0 P1 C4 S1;                              Filament run out sensor for extruder E0 on E1 end stop input P1 = signal HIGH .
                                          M574 Z1 S2;
                                          M558 P1 H5 F600 T6000 A10 S0.03  I1                        ; disable Z probe but set dive height, probe speed and travel speed
                                          M557 X15:215 Y15:195 S20                        ; define mesh grid
                                          M305 P0 T100000 B3950 R4700                     ; set thermistor + ADC parameters for heater 0
                                          M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
                                          M305 P1 T100000 B3950 R4700                     ; set thermistor + ADC parameters for heater 1
                                          M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
                                          M305 P2 T100000 B3950 R4700                     ; set thermistor + ADC parameters for heater 2
                                          M143 H2 S280                                    ; set temperature limit for heater 2 to 280C
                                          M106 P0 S0 I0 F500 H-1                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                          M106 P1 S1 I0 F500 H1:2 T45                     ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M563 P0 D0 H1 S"Extruder"                              ; define tool 0
                                          G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
                                          G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
                                          T0;
                                          M302 P1
                                          M575 P1 S1 B57600;                               Enable paneldue
                                          Also the paneldue comes up with error M21 Cannot initialise SD card1 Card is unusable. I assume this is refering to Micro sd on the duet
                                            How do you have the PanelDue connected? 4-wire or 10-pin flat?
                                            Do you have an SD card in the PanelDue?
                                            Can you post the results of M122 again?
                                            Do you get any error messages if you send M98 P"config.g" ?
