    Logic Level shifter for 12864 display on Duet 2 Wifi
    200
    16.5k
      dc42 administrators @pixelpieper
      @pixelpieper said in Logic Level shifter for 12864 display on Duet 2 Wifi:
      @seraser this is not maestro specific - the lcd reset pin of the mini 12864 has to be somehow pulled high in order to have the display leave its reset.
      @dc42 from the firmware side: when configured as M918 P2, are we guaranteed that the then not functional active high chip select on the maestro display connector stays always high? I.e. is it safe to use as the reset pin?
      Yes, it should be.
      • seraserundefined
        seraser
        @Schmart now is working fine but no enter key detected when press encoder, what can I check?
        Rotate work.
        Thank you.
          A Former User @seraser
          @seraser said in Logic Level shifter for 12864 display on Duet 2 Wifi:
          thats just a switch wired to EncoderPinSw so check the wiring and or voltage on the signal with the key pressed and not pressed?
          seraserundefined 1 Reply Last reply Reply Quote 0
          • seraserundefined
            seraser @A Former User
            @bearer will check this night, thank you.
            • seraserundefined
              seraser
              @bearer thank you swaped beep with enc_sw and now LCD work fine but no sd card detected, checked and checked and checked wires and all are fine for sure and m122 only reports sdcard0.
              • seraserundefined
                seraser @seraser
                Cs, miso, mosi and csk are fine connected and with 3v3 volts, tomorrow I will check trafic with my oscilloscope.
                • seraserundefined
                  seraser @seraser
                  @pixelpieper your LCD detect sdcard?
                  Maybe the problem is related to CD(card detect) pin 2.4 exp2 in LCD with no way to duet.
                  Schmartundefined pixelpieperundefined 2 Replies Last reply Reply Quote 0
                  • Schmartundefined
                    Schmart @seraser
                    @seraser I don't think the card detect is the problem. From the Fysetc schematic, it's just a simple switch without other connections and the Duet doesn't need a card detect signal.
                    If you have SPI traffic correctly coming out the Duet, maybe try a high quality SD card or use shorter or twisted cables for the connection to the display.
                    Also, you mention using 3.3V as supply voltage? I think you need to use 5V. There should be a voltage regulator on the display PCB that converts the 5V supply voltage to 3.3V. There's even a 74HC4050 buffer that protects the SD card's inputs.
                    Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
                    • seraserundefined
                      seraser @Schmart
                      @Schmart power supply is 5v.
                      Tested three sdcards.
                      Short dupont connections, checked fine.
                      Maybe with initial bad connections 74HC4050 is damaged.
                      • pixelpieperundefined
                        pixelpieper @seraser
                        @seraser I haven't tried, did not even wire it up and I don't know whether I would bother since I don't use sneakernet to get my gcode onto the printer 😉
                        Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                        Voron V0.250 / Duet 2 Maestro
                        • seraserundefined
                          seraser
                          Replaced 74HC4050 and same here so stoping because I think is software related sd no detection.
                          Schmartundefined 1 Reply Last reply Reply Quote 0
                          • Schmartundefined
                            Schmart @seraser
                            @seraser you mentioned wanting to check traffic with your oscilloscope, and I mentioned checking SPI traffic coming from the Duet board first as well. I hope you did that before replacing chips? What was the outcome? I think only then we can look for other suspects like the firmware.
                            • seraserundefined
                              seraser @Schmart
                              @Schmart finally, with relax, checked fine with my ancient hameg, miso, csk and cs are high at 3v3 with and without sdcard but no variations when insert sdcard so this signals are dead an mosi is down with 0v and dead constantly with or without sdcard.
                              Tested in fysetc 1.2 and fysetc 2.1 because 2.1 works but no light and I can see content.
                              • seraserundefined
                                seraser
                                @Schmart @dc42 we need cs low for set miso high and begin comunication, right? I do not know for sure if duet work with this condition.
                                  dc42 administrators @seraser
                                  Are you talking about communication with the SD card or with the display?
                                  • seraserundefined
                                    seraser @dc42
                                    @dc42 sdcard, display work fine but sdcard is not detected.
                                      Have you checked that the MISO signal is connected correctly between the display and the Duet, and that CS0 on the Duet is connected to SD card CS on the display?
                                      Is it a known good SD card?
                                      SD card socket on PanelDue works, so it's unlikely to be a firmware problem IMO.
                                      • seraserundefined
                                        seraser @dc42
                                        @dc42 yes, checked fine all connections and try with three sdcards working fine.
                                        I will test in other duet.
                                        Thank you.
                                        • Schmartundefined
                                          Schmart @seraser
                                          @seraser I've no personal experience with what is necessary to get an external SD card reader working in RRF, since I print via the network, but since there is no card detect pin, have you tried an M21 P1 "Initialize SD card" or a M39 P1 S2 command yet?
                                            dc42 administrators @Schmart
                                            @Schmart said in Logic Level shifter for 12864 display on Duet 2 Wifi:
                                            To clarify: the M21 P1 command is needed to initialise the external SD card after it has been inserted; however, DWC will issue this command automatically if you try to list jobs on the external SD card.
                                            seraserundefined 1 Reply Last reply Reply Quote 1
