    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
      T3P3Tony administrators
      can you post the video to a service that does not need an account to view it?
      oozeBotundefined 1 Reply Last reply Reply Quote 0
      • oozeBotundefined
        oozeBot @T3P3Tony
        @T3P3Tony my bad - I thought I had that worked out where it could be viewed without logging in. Here it is. Note the rattling is the cooling fan jerking around.. lol. I'm going to have to stiffen that part up!
        https://vimeo.com/464550220
          thanks, looking good! I think instagram used to let people without an account see posts but its asks me to login every time i go to a link now.
          • theruttmeisterundefined
            theruttmeister @oozeBot
            @oozeBot
            Remember that if you plan on selling that laser as a tool for the printer you will need to comply with the FDA guidelines on lasers.
            You can get a copy from their website, I highly recommend downloading it and reading it carefully.
            If someone blinds themselves with your product you don't want to be in court trying to defend non-compliance.
            The people selling them as parts are skirting the rules, making it part of your product makes you very clearly liable.
            Isolate, substitute, verify.
            • oozeBotundefined
              oozeBot @theruttmeister
              @theruttmeister good point! I don't think we'll ever sell them - just point people to OptLaser's website instead. And the tool holder will just be a part we'll make available. Not sure if that carries any liability or not, but we'll make certain we comply! Thanks for pointing this out!
              • oozeBotundefined
                oozeBot
                One more video of her running for today.. watch as she lays down a perfect honeycomb infill at 100mm/s!
                I just bumped the print speed to 100mm/s and am now down from 59m where I started this AM to 44m total print time! That's over 25% faster.. I'm quite pleased.
                And again, the rattling is the part cooling fan..
                https://vimeo.com/464558997
                • oozeBotundefined
                  oozeBot
                  Sneak peak at the enclosure I’ve been throwing together in my spare time for our latest prototype.. am getting excited to wrap this up!
                  • oozeBotundefined
                    oozeBot
                    The electronics are coming together!
                    • oozeBotundefined
                      oozeBot
                      Here's a quick pic of our latest prototype in the enclosure I just finished..
                      1 Reply Last reply Reply Quote 4
                        Just an FYI, the little button with the bent line and two dots under the P0 on the PanelDue display will run bed.g, which could save you a macro slot for Mesh Bed Level that could be used for something else.
                        • oozeBotundefined
                          oozeBot @Phaedrux
                          @Phaedrux just saw this.. thanks! but I am aware.. I actually don't even have 4 macros populating that just yet so I mocked those up for the picture.. lol
                          • oozeBotundefined
                            oozeBot
                            We just finished running a 300mm tall z-wobble test at 80mm/s and are very pleased with the results! It was done in ABS with a .6mm nozzle at .5mm layer height by .75 extrusion width in just a little over over 3 hours.
                            • oozeBotundefined
                              oozeBot
                              Here is the timelapse of it printing.
                              Note the bad spots in the rear as it prints (and the recovery!). Since this was in vase mode, I didn't use M400 in the timelapse script between layers. It was caused by the momentary stutter when the photos were triggered..
                              https://vimeo.com/469090014
                              • oozeBotundefined
                                oozeBot
                                I wanted to post a few photos of a Halloween "torture test" we recently completed. This was printed in ABS, with no supports, using a 1.2mm nozzle. Extrusion width was 1.8mm and layer height was .4mm. It is 300mm deep x 264mm wide x 244mm high, was printed in ~17 hours, and weighs right at 3.5lbs.
                                This was our first time using a 1.2mm nozzle and getting the retraction settings right to (mostly) control stringing was a challenge, but firmware retraction made the changes easy! There was some mid-air printing near the base, but that was in the design and it recovered beautifully..
                                1 Reply Last reply Reply Quote 5
                                  That's an impressive ABS print. well done.
                                    yeah really nice!
                                    • oozeBotundefined
                                      oozeBot
                                      Timelapse of the Cthulhu build.. You'll see the mid-air printing near the base as well as the stringing that we mostly got under control by about mid-way through the print.
                                      https://vimeo.com/473997293
                                      • doublec4undefined
                                        doublec4
                                        Been following on instagram for a while now. Once this thing gets released I'm going to convince my work place to get one. We currently do not have a printer for ABS and this looks like it puts out great prints.
                                        oozeBotundefined 1 Reply Last reply Reply Quote 1
                                        • oozeBotundefined
                                          oozeBot @doublec4
                                          @doublec4 Fun fact - we don't even own any PLA or PETG! When I got into 3DP years back, I decided to go straight to ABS. But that will have to change soon for testing purposes..
                                          The ele^gant is the accumulation of everything we learned and yearned for over the years.. and we are finally close to making our vision a reality, but are about to go heads down on one last round of significant changes before calling version 1.0 complete. I'm excited to show what we have in store! We'll be starting the build of our final prototype within the next few weeks.
                                          • Vetiundefined
                                            Veti @oozeBot
                                            @oozeBot said in oozeBot ele^gant:
                                            what about asa?
