    NEJE-like Laser as CNC upgrade
    Laser Cutters
    11
    47
    3.5k
      droftarts administrators @radiomodell
      @radiomodell said in NEJE-like Laser as CNC upgrade:
      M452 C"exp.heater6" R500 S1 Q20000 ; laser uses heater3 pin, PWM frequency 100Hz;
      @radiomodell @FelixH @sh12 Please note 'Q' parameter is incorrect, it should be 'F' for PWM frequency. The example in the Gcode dictionary for M452 was incorrect, but has now been fixed, thanks to @Royassas (see https://forum.duet3d.com/post/168234)
      So @radiomodell, you're probably using a PWM frequency of 500Hz, which is the default!
      • radiomodellundefined
        radiomodell
        @droftarts said in NEJE-like Laser as CNC upgrade:
        Thanks a lot for the hint! Laser worked fine til now. I will correct M452 command before next use.
          radiomodell @sh12
          @sh12 As far as I know, expansion board pins are at 5V level. please check your documentation and use a level shifter to connet laser PWM-pin with 3.3 volt.
          When using Fan6-PWM Duex output pin following command should do initialization: M452 C"duex.fan6" R500 S1 F20000 . R- parameter sets 100% value of S-Parameter in M3 command. M3 S500 is 100%, M3 S250 is 50%. Dependent on source of G-code i adjust R-Parameter.
          My PWM signal input is connected to Heater6 pin on expansion connector of my Duet2. Thus I use this command M452 C"exp.heater6" R500 S1 F20000.
          sh12undefined 1 Reply Last reply Reply Quote 0
          • sh12undefined
            sh12 @radiomodell
            @radiomodell Thanks,
            Even though the specs on the laser says the pwm will work on 3.3 to 12v, I will connect it to a heater pin today and change the Q to F.
            radiomodellundefined 1 Reply Last reply Reply Quote 0
              radiomodell @sh12
              @sh12 PWM Vpp is 3,3V Check the link and scroll down: http://nejetool.com/module_20w.html
              • sh12undefined
                sh12 @radiomodell
                Thanks @radiomodell . If you go down a little further in the notes it says this:
                Is the power adjustable: PWM can be adjusted, PWM: 50KHz-20KHz / 3.3V-12V
                I had even contacted the seller to verify and he assured me that it was from 3.3 to 12.
                Anyway I duplicated your setup and YAY, it is working! So thanks again. Now to focus it and figure correct speed.
                Do you know if the firmware was ever updated to allow the laser to be on without the G1 command first for focusing purposes? I saw a thread where David was talking about that.
                  radiomodell @sh12
                  @sh12 Firmware fires laser only when moving by G-command. Thus for focus operation I terminate Laser Mode (M452 C"nil") and put a PWM signal manually. (M950... etc ).
                  M452 C"nil"                   ; Laser vom automatischen Einschalten bei Bewegung trennen
                  M950 P3 C"exp.heater6" R255 F20000 ; Laserleistung auf P3 umschalten
                  M42 P0 S255                   ; Laserpower einschalten
                  G04 P1000                     ; Pause, bis Laserpower stabilisiert ist
                  M42 P3 S0.01                  ; Laser mit 1% Leistung einschalten
                  Please be careful! Laser i continuously on and burning on one point!
                  After focusing laser I use following commands to switch back to normal laser mode:
                  M42  P3 S0                  ; Laser aus
                  G04 P500                    ; kurze Pause
                  M42 P0 S0                   ; Laserpower aus
                  M950 P3 C"nil"
                  M452 C"exp.heater6" R255 S1 F20000  ;
                  • sh12undefined
                    sh12
                    I was referring to this thread
                    https://forum.duet3d.com/topic/15826/behavior-of-m3-command-im-laser-mode-m452
                    where @dc42 said there was a request to have a laser mode available for focus. Was just wondering if it ever went anywhere.
                    Oh well, at least I have it working now. That was the major hurdle.
                    • g0rgundefined
                      g0rg
                      Hello and sorry for editing this topic but I'd like to ask to @FelixH or @sh12 or some kind friends here to help me with the same setup (workbee, duet2 wifi, neje 20w). I can't get rid of it knowing how to wire and how to change the right settings/macros or flashing to RRF3 or making the special inverter board.
                      Maybe on my personnal mail box or a new topic ?
                      what's the best way ?
                      Sorry but i come from Grbl world 😞 πŸ™‚
                      Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
                      FelixHundefined 1 Reply Last reply Reply Quote 0
                      • FelixHundefined
                        FelixH @g0rg
                        @g0rg to be honest, I have been incredible busy the last few months to even considering doing the upgrade... last thing I did was to design a small PCB to connect the laser. It is more or less the same as described in the Duet Wiki, but for through hole components. I shall be able to get into it in a couple of weeks. My setup is still the same: Workbee with Duet, running the latest Ooznest version of the firmware. I guess it is a standard RRF2, but I donβ€˜t know. I am guessing the folks at Ooznest only changed the Web Interface to make it more CNC-friendly, which makes me think if I should update to RRF3 or not.
                          Phaedrux Moderator @FelixH
                          @FelixH from what I gather Oozenest is working on a RRF3 update.
                          • FelixHundefined
                            FelixH @Phaedrux
                            @Phaedrux cool! Iβ€˜m looking forward to it. With some luck they will incorporate the autosquare feature, if I’m not mistaken it should be easier with RRF3
                              @bearer said in NEJE-like Laser as CNC upgrade:
                              a little OT, but M997 ignores M505 or is it just me?
                              Yes, M997 always looks in /sys, and uploads of .bin and .uf2 files always go into /sys.
                              • g0rgundefined
                                g0rg
                                @FelixH I already setup my workbee with autosquare on homing by adding a second switch on Y axis.
                                As a test purpose i updated a second duet wifi board with RRF3 and i still try to understand how to wire my laser and still try to understand how to spell the fan port i would like to use 😞 maybe a help from @sh12 πŸ™„
                                  The recommended way to drive an active-high laser PWM input is to use a 74HCT02 to invert one of the PWM signals on the expansion connector and gate it with +3.3V. However, if your Duet 2 is out of warranty, you could tap into one of the heater mosfet gate pins instead, if you are not using all three heater outputs.
                                  • FelixHundefined
                                    FelixH
                                    Hi all again,
                                    I am today trying to wire the laser but, before I do I have a doubt regarding the following diagram:
                                    https://duet3d.dozuki.com/Wiki/Laser_PWM_control
                                    in this diagram, what is exactly HEATER_3 ?? It is the heated bed, extruder 1 or extruder 2 ?? Also, I am assuming is the "negative" pin of said heater, right?
                                    • PopstarPorcupineundefined
                                      PopstarPorcupine
                                      I installed a similar NEJE laser ("30W" with ~7.5W optical) and got it working easier than expected after reading all the forum posts. Maybe having the Duex5 was key as it just plugs into +/- of servo plug. The TTL Board that comes with unit has 3 modes when you push the pwr button: Off, Manual PWM via board buttons, and PWM-input-controlled.
                                      I have been using Lightburn for Marlin with "inline" selected for "Laser Control Commands" to make gcode.
                                      ;Laser T6 Tool Definition
                                      M307 H6 A-1 C-1 D-1; disable heater6 channel
                                      M563 P6 D0 X3 ; Tool 6 Laser on U axis no heater or fan (change if on X axis)
                                      Tpre setup:
                                      M452 P6 R255 F10000 S1 I0 ; switch to laser mode Heater 6 PWM/servo to control the laser
                                      M42 P6 S0 ; Ensure Laser Off
                                      TFree setup:
                                      M451; Go back to FFF 3D print Mode
                                      • FelixHundefined
                                        FelixH
                                        @PopstarPorcupine thanks a lot for your info. I prepared the mentioned board and I used the heated-bed PWM port. I still have to bring it on-line, however. Not tried it yet. I've been really busy preparing a new electronics box for my Workbee with the Duet, the SuperPID and everything else... I think your snippets will be much uselfull. Thanks a lot again.
                                        EDIT: what about the Lightburn software? is it worth it? There are not many options for for mac users, Lightburn beign one of the few I found...
                                        • FelixHundefined
                                          FelixH
                                          Well just an update on my side. I finally finished upgrading my Workbee with a worthy electronics box where everything is well organized. I never liked it to have the controller board exposed and on the moving gantry.
                                          Anyway, I've been able to put my laser to work by following the indications here. I used the brake-out board suggested and it works just fine. Amazingly enough, it worked on the first try, which for my standards is amazing to say the least.
                                          I have a problem though when switching back to CNC mode and it is the following error:
                                          M98 P"0:/macros/Laser/Switch to CNC"
                                          CNC mode selected Error: G10: Attempt to set/report offsets and temperatures for non-existent tool: 999
                                          The macro I'm using to switch back to CNC mode is the following, which is a mix between what I've seen and what I found on my config.g file
                                          M106 P2 S0  ; turn off 12v PSU
                                          M453 ; Put the machine into CNC Modes
                                          M140 H-1 ; Disable heated bed
                                          M564 S1 H1 ; Disable jog commands when not homed
                                          M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
                                          M501 ; Load Stored Parameters
                                          M98 Pcustomconfig.g ; Execute custom config settings
                                          any clue in what is this about? it would be much appreciated!
                                            @FelixH said in NEJE-like Laser as CNC upgrade:
                                            M501 ; Load Stored Parameters M98 Pcustomconfig.g ; Execute custom config settings
                                            What do you have in config-override.g and customconfig.g?
