Werid slicer problems
I have a werid problem. If I use prusaslicer the first layer is at the right height but with simplified3d is starts to high. What could cause this? I have checked settings no offsets are being added.
Share the starting g-code of both? S3D has to be doing something different
simplified3d
G28 ; home all axes
G1 X5 Y10 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X160 E15 F600 ; prime nozzle
G1 X180 F5000 ; quick wipePrusaslicer
M107
M190 S60 ; set bed temperature and wait for it to be reached
M104 S210 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S210 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0 -
I think he means he wants you to share some of the actual gcode file you are printing and not just the start gcode. One thing to note is it is best to use relative extrusion and not absolute extrusion with the duet boards.
@JamesM what would relative gcode look like?
@nightmare90gt said in Werid slicer problems:
Are you off by 0.2mm height?
Post the a full sliced gcode from each so we can see how the start of the print and first layer plays out. The start gcode is part of it, but we need to see more.
Relative extrusion versus absolute extrusion is a bit complex and unrelated to your problem here, but here's a break down that explains it well since it's worth knowing anyway.
https://www.sublimelayers.com/2017/10/to-extruder-relative-or-not-to-extrude.html
I will verify tomorrow and report back.
xyzCalibration_cube (Prusa).gcode xyzCalibration_cube (simp).gcode
simplified I have to adjust the baby set to .160mm to get a clean first layer.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 02 2020 09:51:53 GMT+0200 (Central European Summer Time); General preferences
M550 P"Ender 5 Plus CoreXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable TelnetM671 X-20:370 Y150:150 S3.0 ; leadscrews at left (connected to Z) and right (connected to E2) of X axis
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S1 ; physical drive 4 goes forwards
M569 P5 S0 ; physical drive 5 goes backwards
M584 X0 Y1 Z2:5 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1050 Y1050 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 P"zstop+e2stop" ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X30.814 Y17.505 Z1.663 ; set Z probe trigger value, offset and trigger height
M557 X50:320 Y15:350 S50 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P0 S"E0" D0 H1 F0 ; define tool 0
M563 P1 S"E1" D1 H2 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings
M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled; Miscellaneous
M501 ; load stored settings
T0 ; select first tool -
This post is deleted! -
I changed both to relative and they both seem to be off by .160mm per baby stepping. I have tried raising and lowering the probe height but just doesn't seem to work.
The gcode for each of those is completely different. Prusa slicer is using a first layer height of 0.35 and simplify is using 0.15. Simplify is using mesh compensation with G29, and Prusa slicer is not.
Simplify:
G90 M83 M106 S0 M140 S60 M190 S60 M104 S210 T0 M109 S210 T0 G28 ; home all axes G29 ; mesh bed level G1 X5 Y10 Z0.2 F3000 ; get ready to prime G1 X160 E15 F600 ; prime nozzle G1 X180 F5000 ; quick wipe ; process PLA Ender 5 ; layer 1, Z = 0.150 T0 G1 E-1.0000 F2400 ; feature skirt ; tool H0.150 W0.720 G1 Z0.150 F1002
Prusa Slicer:
M107 M190 S60 ; set bed temperature and wait for it to be reached M104 S210 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S210 ; set temperature and wait for it to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; Filament gcode G1 Z0.350 F10800.000
prusa slicer
; Filament gcode
G1 Z0.350 F10800.000s3d
; feature skirt
G1 Z0.150 F1002your prusa settings
; first_layer_height = 0.35
