    Werid slicer problems
    464
    • nightmare90gtundefined
      nightmare90gt
      I have a werid problem. If I use prusaslicer the first layer is at the right height but with simplified3d is starts to high. What could cause this? I have checked settings no offsets are being added.
        A Former User
        Share the starting g-code of both? S3D has to be doing something different
          nightmare90gt
          simplified3d
          G28 ; home all axes
          G1 X5 Y10 Z0.2 F3000 ; get ready to prime
          G92 E0 ; reset extrusion distance
          G1 X160 E15 F600 ; prime nozzle
          G1 X180 F5000 ; quick wipe
          Prusaslicer
          M107
          M190 S60 ; set bed temperature and wait for it to be reached
          M104 S210 ; set temperature
          G28 ; home all axes
          G1 Z5 F5000 ; lift nozzle
          M109 S210 ; set temperature and wait for it to be reached
          G21 ; set units to millimeters
          G90 ; use absolute coordinates
          M82 ; use absolute distances for extrusion
          G92 E0
          • JamesMundefined
            JamesM
            I think he means he wants you to share some of the actual gcode file you are printing and not just the start gcode. One thing to note is it is best to use relative extrusion and not absolute extrusion with the duet boards.
            nightmare90gtundefined 1 Reply Last reply Reply Quote 0
              nightmare90gt @JamesM
              @JamesM what would relative gcode look like?
                Phaedrux Moderator @nightmare90gt
                @nightmare90gt said in Werid slicer problems:
                Are you off by 0.2mm height?
                Post the a full sliced gcode from each so we can see how the start of the print and first layer plays out. The start gcode is part of it, but we need to see more.
                Relative extrusion versus absolute extrusion is a bit complex and unrelated to your problem here, but here's a break down that explains it well since it's worth knowing anyway.
                https://www.sublimelayers.com/2017/10/to-extruder-relative-or-not-to-extrude.html
                  nightmare90gt
                  I will verify tomorrow and report back.
                    nightmare90gt
                    xyzCalibration_cube (Prusa).gcode xyzCalibration_cube (simp).gcode
                    simplified I have to adjust the baby set to .160mm to get a clean first layer.
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 02 2020 09:51:53 GMT+0200 (Central European Summer Time)
                    M550 P"Ender 5 Plus CoreXY" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M671 X-20:370 Y150:150 S3.0 ; leadscrews at left (connected to Z) and right (connected to E2) of X axis
                    M569 P0 S0 ; physical drive 0 goes backwards
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M569 P4 S1 ; physical drive 4 goes forwards
                    M569 P5 S0 ; physical drive 5 goes backwards
                    M584 X0 Y1 Z2:5 E3:4 ; set drive mapping
                    M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
                    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                    M906 X1050 Y1050 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X320 Y350 Z400 S0 ; set axis maxima
                    M574 Z1 S2 P"zstop+e2stop" ; configure Z-probe endstop for low end on Z
                    M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X30.814 Y17.505 Z1.663 ; set Z probe trigger value, offset and trigger height
                    M557 X50:320 Y15:350 S50 ; define mesh grid
                    M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                    M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
                    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                    M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                    M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
                    M563 P0 S"E0" D0 H1 F0 ; define tool 0
                    M563 P1 S"E1" D1 H2 F0 ; define tool 1
                    ; Custom settings
                    M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                    M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled
                    M501 ; load stored settings
                    T0 ; select first tool
                      nightmare90gt
                      This post is deleted!
                        nightmare90gt
                        I changed both to relative and they both seem to be off by .160mm per baby stepping. I have tried raising and lowering the probe height but just doesn't seem to work.
                          The gcode for each of those is completely different. Prusa slicer is using a first layer height of 0.35 and simplify is using 0.15. Simplify is using mesh compensation with G29, and Prusa slicer is not.
                          Simplify:
                          G90
                          M83
                          M106 S0
                          M140 S60
                          M190 S60
                          M104 S210 T0
                          M109 S210 T0
                          G28 ; home all axes
                          G29 ; mesh bed level
                          ; process PLA Ender 5
                          ; layer 1, Z = 0.150
                          T0
                          G1 E-1.0000 F2400
                          ; feature skirt
                          ; tool H0.150 W0.720
                          G1 Z0.150 F1002
                          Prusa Slicer:
                          M107
                          G28 ; home all axes
                          G92 E0
                          ; Filament gcode
                          G1 Z0.350 F10800.000
                          • Vetiundefined
                            Veti
                            prusa slicer
                            ; Filament gcode
                            s3d
                            ; feature skirt
                            G1 Z0.150 F1002
                            your prusa settings
                            ; first_layer_height = 0.35
