    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.1k
    • wilrikerundefined
      wilriker @SAtech
      @SAtech said in Duet 2 Ethernet and SBC:
      The only thing that is a little troublesome is sometimes the movement is quite jerky. Like in a long travel move it will just stop for a few ms and resume, as if the duet is choking on step generation. I don't think this is happening, but that's how I can best describe it.
      If that persists please open a new thread (since this one is getting very long and a bit hijacked 😉 ) and include your config.g as well as the M122 output that @bearer mentioned and a sample GCode file.
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker
        @smoki3 After what felt like ages (sorry for that) I finally got to rig up a Duet 2 + DueX5 + SBC. It's just a bench setup but at least I attached steppers, a thermistor and a PT1000. I intentionally ran all stepper wires over the SPI wires but I cannot see a single checksum error or any problems at all.
        Did you retest with latest RRF 3.2-beta2? If you still experience your problems please provide me with your full 0:/sys directory contents as well as all possibly other required macros and a GCode file so I can try to reproduce it.
        Manuel
        My Tool Collection
        smoki3undefined jlipavsky79undefined 2 Replies Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @wilriker
          @wilriker I have only tested with 3.2 beta 1.
          Have you tried stall detection on a core xy? The tool changer has 6 axis and all are homed with stall detection.
          If I find some time I will assemble my duet Ethernet again to check if its fixed on beta 2.
          • wilrikerundefined
            wilriker @smoki3
            @smoki3 As you can see it's simply something cobbled together on my desk. It is configured as a simple 3 axis Cartesian and is only pseudo-homed using G92 XYZ. So maybe that is the problem already. If possible you could test if it works for you if you use G92 as well. Maybe it's just stallDetect that fails.
            Manuel
            My Tool Collection
            smoki3undefined 1 Reply Last reply Reply Quote 0
            • smoki3undefined
              smoki3 @wilriker
              @wilriker said in Duet 2 Ethernet and SBC:
              As far I remember homing was one of the main issue. But let me check again with beta 2. I will come back to you
              • seraserundefined
                seraser
                Can anybody explain me advantages of sbc attached to duet?
                A Former User? arhiundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 0
                • wilrikerundefined
                  wilriker @smoki3
                  @smoki3 said in Duet 2 Ethernet and SBC:
                  I tried stallGuard as endstop now (manually blocking the motor shafts) and still no problems. So maybe putting the LinuxInterface into its own FreeRTOS task solved it eventually. Looking forward to your feedback.
                  Manuel
                  My Tool Collection
                    A Former User @seraser
                    @seraser said in Duet 2 Ethernet and SBC:
                    for now not much more than being able to run DWC on a hdmi touch screen instead of paneldue (and more flexible networking as you'll have both wifi and ethernet).
                    but as plugins are added to DSF it will offer added functionality (and of course its easier to develop your own stuff on the pi rather than in the reprap firmware)
                    • arhiundefined
                      arhi @seraser
                      none attm
                      probbly "plugins" in future, plugins that will be capable of modifying g-code real time while printing (like octoprint for e.g.)
                      • seraserundefined
                        seraser
                        Thank you @bearer and @arhi so I will not play with my rasp4.
                          jay_s_uk @seraser
                          @seraser the wifi is much better using an SBC than the wifi onboard. That's about it
                          seraserundefined arhiundefined 2 Replies Last reply Reply Quote 0
                          • seraserundefined
                            seraser @jay_s_uk
                            @jay_s_uk I know WiFi is weak in duetwifi so I've installed wifi repetier near for three printers with duetwifi, thank you.
                            • arhiundefined
                              arhi @jay_s_uk
                              @jay_s_uk rpi's wifi is not that good neither 😄
                              • smoki3undefined
                                smoki3 @wilriker
                                @wilriker so I assembled again my duet 2 ethernet/sbc today to my tool changer. I tried beta 2 and self compiled version from today. Both are not working. Still not able to home my axis. The printer is hanging for ever.
                                I still get some of these in my console:
                                	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                                Please find attached the macros and config
                                https://drive.google.com/file/d/1FoRAUD1e0sretY_o9-dE64mefawPdo6K/view?usp=sharing
                                https://drive.google.com/file/d/1e9l60tG5hqTCH676g0_RTc9dDypd09Uk/view?usp=sharing
                                jay_s_ukundefined arhiundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @smoki3
                                  @smoki3 that error pretty much always points to a wiring issue.
                                  We get that a lot on the LPC/STM port when new users first start out so I would go back to inspecting your wiring.
                                  smoki3undefined 1 Reply Last reply Reply Quote 1
                                  • arhiundefined
                                    arhi @smoki3
                                    @smoki3 are you using duex too? if I remember correctly duet2+sbc is not working if you use duex too ... I might be wrong
                                    • gloomyandyundefined
                                      gloomyandy
                                      @smoki3 "Warning: Lost connection to Duet" may mean that the firmware has stopped responding. Are you getting any sort of firmware reset/crash?
                                      • smoki3undefined
                                        smoki3 @arhi
                                        @arhi said in Duet 2 Ethernet and SBC:
                                        We try to debug it. As you read this thread completely... This was the reason for starting of this thread. It never was about the hardware/pcb design
                                        • smoki3undefined
                                          smoki3 @jay_s_uk
                                          @jay_s_uk doesn't seems to be any wiring issue. As you read in the thread I already tested all of different wirings...
                                          • smoki3undefined
                                            smoki3 @gloomyandy
                                            @gloomyandy said in Duet 2 Ethernet and SBC:
                                            Sometimes it crashes sometimes it hangs forever until I do a manual reset.
