Endstop problem DeltaWasp
@goodchrhere said in Endstop problem DeltaWasp:
M574 X0 Y0 Z0 S1 ; set active high endstopsI am not sure, but here you say that it has no endstops. Is this intended?
I'm not sure if the following are causing the X 0.6, Y 1.7 and Z 431 offset, but they should be changed:
M666 X0 Y0 ; put your endstop adjustments here, or let auto calibration find them
This should have your Z endstop offset in there, too, though currently just put in:
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M208 X0 Y0 Z0 S1 ; set minimum ZYou don't want to limit X and Y to 0, as Deltas home in the middle, so X and Y need to be able to go negative! The delta radius you set with M665 will limit X and Y. Use:
M208 Z0 S1 ; set minimum Z
M574 X0 Y0 Z0 S1 ; set active high endstopsThis is saying "no endstops on X, Y and Z". See M574. I'm surprised the axes stop at all when homing! Almost certainly you want:
; Endstops M574 X2 Y2 Z2 S1 ; Set active high endstops
M350 X256 Y256 Z256 E64 I0 ; configure microstepping without interpolation
You almost certainly DON'T need to be running with 256x microstepping. This can limit speed on a Delta. Set it to 16x with interpolation, and change your steps per mm.
In homedelta.g:
G1 S2 F6000 ; move down a few mm so that the nozzle can be centred
G90 S1 X0 Y0 Z430 ; absolute positioningThat G1 move has no coordinates, so there's no move.
That last line should just be 'G90' on it's own. G90 doesn't take any parameters.
I think it's a cut-and-paste error and should be:G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred > G90 ; absolute positioning
Edit: still in relative mode, so need to move Z down -5 from homed position. Or do the G90 first, then move to X0 Y0 Z425.
Edit: Use
G1 H#
rather thanG1 S#
, assuming you're using the latest version of the firmware.G1 S#
is deprecated for homing, though still works in RRF2.x. My homedelta.g on a shorter Delta:; homedelta.g ; called to home all towers on a delta printer ; G91 ; relative positioning G1 H1 X184 Y184 Z184 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F12000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F12000 ; move X+Y to the centre
Edited: saw extra mistake in homedelta.g
M201 X1000.00 Y1000.00 Z1000.00 E1600.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z1600 E1600 ; set motor currents (mA)Your accelerations are set quite low (mine are 4000, but it's a smaller, lighter Delta) and your motor currents set high; what motors are you using?
@droftarts I changed all the sequences and it works. thank you.
@droftarts It's nema 17 motors, you can using 1.68A on this motor, no problem
@droftarts I changed the value. I have the problem, the z is 5mm to high during the printing.
I changed the homed heigh from 430 to 435mm but i have g0/g1 error, target position not reachable from current position.
What is the problem?thanks for your help.
What M208 commands are you using, if any?
@dc42 I don't know, but i solved the problem.
If your motors are rated at 1.68A, they will get hot (+80ΒΊC) if you set the current to 1.6A. You should set the current at a maximum of 85% of rated current, so around 1.4A. This way you will still get close to maximum torque, but the motor shouldn't get more than warm. See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Rated_current
Hi ! I know you've solved the problem you initially asked about. I'm wondering it you could give my some info on how tricky putting a Duet board on a WASP delta was? I have a WASP 60100 (build 2017) and would love to upgrade it with a Duetboard and maybe a E3D Volcano hotend. But, I'm not really sure what I'm getting myself into
Would you mind me asking a couple of newbie questions about your process?
