    Can't get part cooling fans running :(
    1.2k
    • holco62undefined
      holco62 @Phaedrux
      @Phaedrux
      Yes 2 cooling fans (original Predator) in parallel connected to the FAN-0 connector, fans and the PSU are 24V.
      Don't know about PWM frequency of Q24000, I copied the setup from someone on this forum (honestly doesn't know who anymore), maybe he didn't use the original fans.
      Deleted M106
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 538C
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N8PS4-6J9F4-3S46T-1UVVN
      Used output buffers: 3 of 24 (11 max)
      Static ram: 27980
      Dynamic ram: 93212 of which 60 recycled
      Exception stack ram used: 264
      Never used ram: 9556
      Tasks: NETWORK(ready,404) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:24 ago, cause: power up
      Last software reset at 2020-10-12 21:12, reason: User, spinning module GCodes, available RAM 9316 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 29.4, current 34.6, max 34.7
      Supply voltage: min 24.7, current 24.9, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-10-13 00:29:14
      Cache data hit count 137051482
      Slowest loop: 6.77ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.9ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.91ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address f4:cf:a2:6e:87:5c
        WiFi Vcc 3.36, reset reason Unknown
        WiFi flash size 4194304, free heap 25192
        WiFi IP address 192.168.1.20
        WiFi signal strength -71dBm, reconnections 0, sleep mode modem
        Socket states: 4 0 0 0 0 0 0 0
        === Filament sensors ===
        Extruder 0 sensor: ok
      Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
      • holco62undefined
        holco62
        I changed M950 to Q500, fans still not spinning.
        M950 F0 C"fan0" Q500
        • fcwiltundefined
          fcwilt @holco62
          @holco62 said in Can't get part cooling fans running 😞:
          How did you test the fans? What command did you issue?
            Phaedrux Moderator @holco62
            Deleted M106
            Don't delete the whole M106, just the F65535 part.
            Try this:
            M106 C"PartCoolingFan" P0 S0 H-1 B1 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500 ;HOTEND FAN create fan 1 on pin fan1 and set its frequency
            M106 C"HotendFAN" P1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
            holco62undefined 2 Replies Last reply Reply Quote 0
            • holco62undefined
              holco62 @Phaedrux
              @Phaedrux Thanks, I will try it this evening.
              Btw, all the lines 1>5
              • holco62undefined
                holco62 @Phaedrux
                @Phaedrux said in Can't get part cooling fans running 😞:
                Deleted M106
                Try this:
                @Phaedrux
                It's working now, many thanks for your help 👍 👍 👍
                Is it also possible to start the cold-end fan at a nozzle temp of 50 degrees on the fan01 connector?
                • holco62undefined
                  holco62
                  I see it now 😊 line 4 and 5 is for the hotend fan that triggers on 45 degree, I only have to put the connector on the FAN1 output which is now connected on a always on output 🙄
                  Have a lot to learn about G-code 😀
                  • holco62undefined
                    holco62
                    Still needed some tuning, but a week ago I did not expect to have a working printer already 😎
                    https://youtu.be/CeavMw9Q42I
                    • holco62undefined
                      holco62
                      With a Z axis calibration I sometimes see the number 1000 in red in the status box at sensors Z-probe, but usually it stays at 0 (not in red).
                      What does that mean?
                        It's showing that the probe is triggered. What it shows and how long it shows it will depend on the type of probe.
                        holco62undefined 1 Reply Last reply Reply Quote 0
                        • holco62undefined
                          holco62 @Phaedrux
                          @PhaedruxOk, but why don't I see the number 1000 in red every time the probe triggers during a calibration?
                            What probe do you have?
                            • holco62undefined
                              holco62
                              The stock Predator probe with a micro switch
                              • holco62undefined
                                holco62
                                • holco62undefined
                                  holco62
                                  I changed M558 H30 to H35 in the config.g, but that hasn't changed anything, but the calibration is going damn slow now 🤔
                                    Well the switch is only going to show triggered when it's depressed, so in normal use it would be very brief.
                                    M558 H is the dive height.
                                    You should consider posting a new thread with your probing issues as it's not related to your initial problem which was solved.
                                    • holco62undefined
                                      holco62
                                      Ok thanks, I will create a new topic.
