    Can't get part cooling fans running :(
    1.2k
      Phaedrux Moderator @holco62
      @holco62 said in Can't get part cooling fans running 😞:
      Yes 2 cooling fans (original Predator) in parallel connected to the FAN-0 connector, fans and the PSU are 24V.
      Don't know about PWM frequency of Q24000, I copied the setup from someone on this forum (honestly doesn't know who anymore), maybe he didn't use the original fans.
      Deleted M106
      Don't delete the whole M106, just the F65535 part.
      Try this:
      M106 C"PartCoolingFan" P0 S0 H-1 B1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500 ;HOTEND FAN create fan 1 on pin fan1 and set its frequency
      M106 C"HotendFAN" P1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      holco62undefined 2 Replies Last reply Reply Quote 0
      • holco62undefined
        holco62 @Phaedrux
        @Phaedrux Thanks, I will try it this evening.
        Btw, all the lines 1>5
        Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
        • holco62undefined
          holco62 @Phaedrux
          @Phaedrux said in Can't get part cooling fans running 😞:
          Deleted M106
          Try this:
          @Phaedrux
          It's working now, many thanks for your help 👍 👍 👍
          Is it also possible to start the cold-end fan at a nozzle temp of 50 degrees on the fan01 connector?
          • holco62undefined
            holco62
            I see it now 😊 line 4 and 5 is for the hotend fan that triggers on 45 degree, I only have to put the connector on the FAN1 output which is now connected on a always on output 🙄
            Have a lot to learn about G-code 😀
            • holco62undefined
              holco62
              Still needed some tuning, but a week ago I did not expect to have a working printer already 😎
              https://youtu.be/CeavMw9Q42I
              • holco62undefined
                holco62
                With a Z axis calibration I sometimes see the number 1000 in red in the status box at sensors Z-probe, but usually it stays at 0 (not in red).
                What does that mean?
                  It's showing that the probe is triggered. What it shows and how long it shows it will depend on the type of probe.
                  holco62undefined 1 Reply Last reply Reply Quote 0
                  • holco62undefined
                    holco62 @Phaedrux
                    @PhaedruxOk, but why don't I see the number 1000 in red every time the probe triggers during a calibration?
                      What probe do you have?
                      • holco62undefined
                        holco62
                        The stock Predator probe with a micro switch
                        • holco62undefined
                          holco62
                          • holco62undefined
                            holco62
                            I changed M558 H30 to H35 in the config.g, but that hasn't changed anything, but the calibration is going damn slow now 🤔
                              Well the switch is only going to show triggered when it's depressed, so in normal use it would be very brief.
                              M558 H is the dive height.
                              You should consider posting a new thread with your probing issues as it's not related to your initial problem which was solved.
                              • holco62undefined
                                holco62
                                Ok thanks, I will create a new topic.
