    Giant Delta printer Slow Homing issue.
    My Duet controlled machine
    8
    84
    3.7k
    • sozkanundefined
      sozkan @Phaedrux
      @Phaedrux it could be. Thank you for your attention. I am still on the learning curve.
        You can see an example of the correct file structure here.
        https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
        Note that your /sys folder will also contain some .bin files for the firmware in addition to the listed .g config files.
        It may be easiest to put the SD card into a PC to edit the file structure.
        • sozkanundefined
          sozkan @Phaedrux
          @Phaedrux said in Giant Delta printer Slow Homing issue.:
          @sozkan said in Giant Delta printer Slow Homing issue.:
          Can you please provide the results of M122 and M98 P"config.g" ?
          I realize now, you want me to send a command to the machine right? I can do it by tomorrow.
            Yes, M122 will give us some diagnostic information including verifying what firmware version is installed. And M98 P"config.g" will execute the config.g file as a macro and echo back any error messages which are otherwise missed during power on. This would help eliminate any other syntax errors in config.g.
              This may not resolve your noisy motors, but it will at least ensure we're working with a correctly functioning setup.
              sozkanundefined 1 Reply Last reply Reply Quote 0
                M569 P1 P2 P3 are fine if those cause the motors to move those are the correct ones. It's just targeting those driver numbers.
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M569_1_Stepper_driver_closed_loop_control
                • sozkanundefined
                  sozkan @Phaedrux
                  @Phaedrux
                  I will definitely do and share the result by tomorrow.
                  But I am sure there is no imperfection on hardware and wiring. Because motors are accurately working on illegal code, but creating horrible sound and incorrectly working on legal code. That's means I have done something working during the firmware upgrade?
                  Because it is the latest stable update recently I messed up.
                    And yes, reduce acceleration and jerk. That should help a bit.
                    The motors are going to be loud. They are large and mounted to metal, but hopefully the adjusted timing and acceleration will make it a bit more bearable.
                    It's not illegal code if it works.
                    • sozkanundefined
                      sozkan @Phaedrux
                      It`s some how stable on motor step control, but with those settings, I cannot control Enable or disable the motor features as well as the direction due to the illegal numbering. Because event Mr. admin "dc42" suggests for the external motor drives the stepper breakout board legal codes P5,6,7,8. Somehow these legal settings only working enable and direction settings and unstable step signals for the motor.
                      • sozkanundefined
                        sozkan @Phaedrux
                        Since it is not functioning other variables except stepping, also according to the Firmware developer it is illegal 🙂
                        • sozkanundefined
                          sozkan @sozkan
                          Until I found a stable solution, I will continue with this achieved a motor enable issue by hardware and mechanical brake gearbox and right direction setup on external motor driver. I believe it might run G-codes sufficiently if there is no hidden failure.
                          • sozkanundefined
                            sozkan @Phaedrux
                            M98 P"config.g"
                            I have just done your advise:
                            result :
                            10/23/2020, 4:31:32 PM M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta1 running on Duet WiFi 1.02 or later
                            Board ID: 08DGM-917DA-G4MS8-6JTD4-3S86J-19SHA
                            Used output buffers: 3 of 24 (21 max)
                            Static ram: 23916
                            Dynamic ram: 98532 of which 120 recycled
                            Exception stack ram used: 544
                            Never used ram: 7960
                            Tasks: NETWORK(ready,125) HEAT(blocked,138) MAIN(running,328) IDLE(ready,20)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:03:52 ago, cause: power up
                            Last software reset at 2020-10-22 20:24, reason: User, GCodes spinning, available RAM 8036, slot 0
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                            Error status: 0x028
                            MCU temperature: min 30.7, current 32.4, max 32.6
                            Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 276494, standstill, SG min/max not available
                            Driver 1: position 276494, standstill, SG min/max not available
                            Driver 2: position 276494, standstill, SG min/max not available
                            Driver 3: position 0, standstill, SG min/max not available
                            Driver 4: position 0, standstill, SG min/max not available
                            Driver 5: position 0
                            Driver 6: position 0
                            Driver 7: position 0
                            Driver 8: position 0
                            Driver 9: position 0
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2020-10-23 16:31:31
                            Cache data hit count 407671411
                            Slowest loop: 65.60ms; fastest: 0.15ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 1.0ms, write time 28.7ms, max retries 0
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                            === MainDDARing ===
                            Scheduled moves: 19, completed moves: 19, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                            === AuxDDARing ===
                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 217.22ms; fastest: 0.09ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              Failed messages: pending 0, notready 0, noresp 2
                              WiFi firmware version 1.23
                              WiFi MAC address 80:7d:3a:3f:f6:73
                              WiFi Vcc 3.38, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 22848
                              WiFi IP address 192.168.43.196
                              WiFi signal strength -67dBm, reconnections 0, sleep mode modem
                              Clock register ffffffff
                              10/23/2020, 4:30:44 PM Error: Temperature reading fault on heater 1: sensor open circuit
                              Error: Temperature reading fault on heater 2: sensor open circuit
                              10/23/2020, 4:30:42 PM M98 P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Error: Driver 6 does not support x0 microstepping with interpolation
                              Driver 7 does not support x0 microstepping with interpolation
                              Driver 8 does not support x0 microstepping with interpolation
                              Driver 5 does not support x0 microstepping with interpolation
                              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 258C
                              Phaedrux Moderator @sozkan
                              I would say in your current situation of commissioning and tuning you should stick with firmware 3.1.1
                              Upload this zip file as is, don't extract it, to the system tab in the web interface.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                              M350 X0 Y0 Z0 E0 I1
                              I think you're going to need to specify a microstepping value. 0 won't work. Try 1.
                              • sozkanundefined
                                sozkan @Phaedrux
                                M350 X0 Y0 Z0 E0 I1
                                I will definitely try your advice soon. I was formating file structure, I can't connect web interface anymore now. I have backed up fully the SD card. Reverted back but still not connecting.
                                  Your SD card needs a file structure like this: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                                  The web interface files need be placed in the /www folder and come from here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
                                  • sozkanundefined
                                    sozkan @sozkan
                                    M350 X0 Y0 Z0 E0 I1
                                    I normally install the beta update using the web interface. The CSS and www folders appeared in the sys folder after that.
                                      Did you upload the full zip file without extracting it first?
                                      You must not extract the zip file.
                                      • sozkanundefined
                                        sozkan @Phaedrux
                                        yes I did in the past with zip in beta version upgrade. But this case I cannot connect web interface. Panedue console says it connected to the IP : 192.168.1.200 but on my hotspot network it shows unknow IP connection. I have uploaded the firmware files in the SD card that you sent me now and reinstall firmware using the PaneDue interface with "M997 S0 to install the firmware" and "M997 S1 to install the WiFi module firmware" so successfully updated. After I send M115 to confirm the new firmware version it is still beta version remain and not connected.
                                          It sounds like your /www folder may be missing still?
                                          • sozkanundefined
                                            sozkan @Phaedrux
                                            I actually revert the backup which is previously connecting with no issue.
                                            This problem just appeared. I have tried to connect different SSID name, I could not save into controller gives error on the saving list. It seems like the controller relying on "config.json" keep connecting old parameters. By the way, I have reinstalled back beta firmware just to see if it will connect.
