    Giant Delta printer Slow Homing issue.
    My Duet controlled machine
    8
    84
    3.7k
      M569 P1 P2 P3 are fine if those cause the motors to move those are the correct ones. It's just targeting those driver numbers.
      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M569_1_Stepper_driver_closed_loop_control
      sozkanundefined 1 Reply Last reply Reply Quote 0
      • sozkanundefined
        sozkan @Phaedrux
        @Phaedrux
        I will definitely do and share the result by tomorrow.
        But I am sure there is no imperfection on hardware and wiring. Because motors are accurately working on illegal code, but creating horrible sound and incorrectly working on legal code. That's means I have done something working during the firmware upgrade?
        Because it is the latest stable update recently I messed up.
          And yes, reduce acceleration and jerk. That should help a bit.
          The motors are going to be loud. They are large and mounted to metal, but hopefully the adjusted timing and acceleration will make it a bit more bearable.
          @sozkan said in Giant Delta printer Slow Homing issue.:
          It's not illegal code if it works.
          • sozkanundefined
            sozkan @Phaedrux
            @Phaedrux said in Giant Delta printer Slow Homing issue.:
            It`s some how stable on motor step control, but with those settings, I cannot control Enable or disable the motor features as well as the direction due to the illegal numbering. Because event Mr. admin "dc42" suggests for the external motor drives the stepper breakout board legal codes P5,6,7,8. Somehow these legal settings only working enable and direction settings and unstable step signals for the motor.
            • sozkanundefined
              sozkan @Phaedrux
              Since it is not functioning other variables except stepping, also according to the Firmware developer it is illegal 🙂
              • sozkanundefined
                sozkan @sozkan
                Until I found a stable solution, I will continue with this achieved a motor enable issue by hardware and mechanical brake gearbox and right direction setup on external motor driver. I believe it might run G-codes sufficiently if there is no hidden failure.
                • sozkanundefined
                  sozkan @Phaedrux
                  M98 P"config.g"
                  I have just done your advise:
                  result :
                  10/23/2020, 4:31:32 PM M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta1 running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-917DA-G4MS8-6JTD4-3S86J-19SHA
                  Used output buffers: 3 of 24 (21 max)
                  Static ram: 23916
                  Dynamic ram: 98532 of which 120 recycled
                  Exception stack ram used: 544
                  Never used ram: 7960
                  Tasks: NETWORK(ready,125) HEAT(blocked,138) MAIN(running,328) IDLE(ready,20)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:03:52 ago, cause: power up
                  Last software reset at 2020-10-22 20:24, reason: User, GCodes spinning, available RAM 8036, slot 0
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0x028
                  MCU temperature: min 30.7, current 32.4, max 32.6
                  Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 276494, standstill, SG min/max not available
                  Driver 1: position 276494, standstill, SG min/max not available
                  Driver 2: position 276494, standstill, SG min/max not available
                  Driver 3: position 0, standstill, SG min/max not available
                  Driver 4: position 0, standstill, SG min/max not available
                  Driver 5: position 0
                  Driver 6: position 0
                  Driver 7: position 0
                  Driver 8: position 0
                  Driver 9: position 0
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2020-10-23 16:31:31
                  Cache data hit count 407671411
                  Slowest loop: 65.60ms; fastest: 0.15ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 1.0ms, write time 28.7ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 19, completed moves: 19, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 217.22ms; fastest: 0.09ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    Failed messages: pending 0, notready 0, noresp 2
                    WiFi firmware version 1.23
                    WiFi MAC address 80:7d:3a:3f:f6:73
                    WiFi Vcc 3.38, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 22848
                    WiFi IP address 192.168.43.196
                    WiFi signal strength -67dBm, reconnections 0, sleep mode modem
                    Clock register ffffffff
                    10/23/2020, 4:30:44 PM Error: Temperature reading fault on heater 1: sensor open circuit
                    Error: Temperature reading fault on heater 2: sensor open circuit
                    10/23/2020, 4:30:42 PM M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    Error: Driver 6 does not support x0 microstepping with interpolation
                    Driver 7 does not support x0 microstepping with interpolation
                    Driver 8 does not support x0 microstepping with interpolation
                    Driver 5 does not support x0 microstepping with interpolation
                    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 258C
                    Phaedrux Moderator @sozkan
                    I would say in your current situation of commissioning and tuning you should stick with firmware 3.1.1
                    Upload this zip file as is, don't extract it, to the system tab in the web interface.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                    M350 X0 Y0 Z0 E0 I1
                    I think you're going to need to specify a microstepping value. 0 won't work. Try 1.
                    • sozkanundefined
                      sozkan @Phaedrux
                      M350 X0 Y0 Z0 E0 I1
                      I will definitely try your advice soon. I was formating file structure, I can't connect web interface anymore now. I have backed up fully the SD card. Reverted back but still not connecting.
                        Your SD card needs a file structure like this: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                        The web interface files need be placed in the /www folder and come from here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
                        • sozkanundefined
                          sozkan @sozkan
                          M350 X0 Y0 Z0 E0 I1
                          I normally install the beta update using the web interface. The CSS and www folders appeared in the sys folder after that.
                            Did you upload the full zip file without extracting it first?
                            You must not extract the zip file.
                            • sozkanundefined
                              sozkan @Phaedrux
                              yes I did in the past with zip in beta version upgrade. But this case I cannot connect web interface. Panedue console says it connected to the IP : 192.168.1.200 but on my hotspot network it shows unknow IP connection. I have uploaded the firmware files in the SD card that you sent me now and reinstall firmware using the PaneDue interface with "M997 S0 to install the firmware" and "M997 S1 to install the WiFi module firmware" so successfully updated. After I send M115 to confirm the new firmware version it is still beta version remain and not connected.
                                It sounds like your /www folder may be missing still?
                                • sozkanundefined
                                  sozkan @Phaedrux
                                  I actually revert the backup which is previously connecting with no issue.
                                  This problem just appeared. I have tried to connect different SSID name, I could not save into controller gives error on the saving list. It seems like the controller relying on "config.json" keep connecting old parameters. By the way, I have reinstalled back beta firmware just to see if it will connect.
                                    config.json is just used by the online config tool
                                    Can you post a photo of what your SD card file structure looks like now?
                                    Since you have a PanelDue it may be a good idea to add some macros to your SD card macros folder to aid in diagnostics.
                                    https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3/macros/Diagnostics
                                    At the bottom of that list are 3 wifi macros which you can customize with your SSID name to make clearing and adding the wifi network easy from the paneldue.
                                    Sending M997 S1 should reflash the wifi server firmware in case something went wrong on the last update.
                                    If you send M122 from a USB connection you can see the wifi server status at the end. The response is too large for the PanelDue to display.
                                    sozkanundefined 2 Replies Last reply Reply Quote 0
                                    • sozkanundefined
                                      sozkan @Phaedrux
                                      Thanks. Macros help to reset the wifi module. I am in DWC now finally.
                                      • sozkanundefined
                                        sozkan @Phaedrux
                                        I have added files on the sys folder before downgrade to the stable 3.11 version. I will update using the web interface.
                                          I'm a little confused.
                                          Are you on 3.2 beta still, or 3.1.1?
                                          I think maybe some other files may be missing.
                                          You could try updating with 3.0 first, and then 3.1.1
                                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                          Remember to upload the entire intact zip file to the system tab. Don't extract.
                                          • sozkanundefined
                                            sozkan @Phaedrux
                                            @Phaedrux I have actually Upgraded to 3.0 at first. later 3.11 and latest beta. Presently I have downgraded to 3.1.1 using DWC .
                                            I have checked your previous recommendation Micro Stepping "1" it is still remain horrible sound ;
                                            M569 P5 S0 R0 T3:3:5:0         ; Extruder drive 0 goes Forward
                                            M569 P6 S1 R0 T2.5:2.5:6:6  ; X:A drive 1 goes Forward
                                            M569 P7 S1 R0 T2.5:2.5:6:6  ; Y:B drive 2 goes Forward
                                            M569 P8 S1 R0 T2.5:2.5:6:6  ; Z:C physical drive 3 goes Forward
                                            M584 X6 Y7 Z8 E5                                  			 ; set drive mapping
                                            M350 X1 Y1 Z1 E1 I1                                ; configure microstepping without interpolation
