    Nozzle probes off bed.
    2.8k
    • Borgtribbleundefined
      Borgtribble @Turbo
      @Turbo bed is 220 220 250 , you can go as high as 235 ish on both x and y.
        Borgtribble @Turbo
        @Turbo The bed pick is perfect if you flip it so the offset volume is on the left when facing it.
          Borgtribble @Turbo
          @Turbo OK my bad, setup calls for a - 48 (which going through the many configurations of petsfang I found this -->>Right BLT...............................X....+48................Y.....-2) which should be positive 48. So by switching the - to a + the machine works with my setup now, just the points are not in a clockwise rotation. (For note I did switch the - to + but I posted here, but at that point I had other issues causing the problems.) SOOOOoooo this is my new offset xy bltouch bedmesh
          225-48=177-2(-2 for bedstartpoint)=175/5 =x35
          227-2=225-15(-15 for bedstartpoint)=210/5 =y42
          G31 P25 X+48 Y-2
          M557 X2:177 Y15:227 S35:42
          This will give me a 5x5 which I need to map out in a ccw pattern. What changes do I need to make to my bed.g file? I found this on the forum
          ""1. A sequence of 3, 4 or 5 G30 commands with coordinates. This is the old way of doing it. You are limited to just 5 points, and you can specify trigger height corrections for those points.
          1. A G29 command to do mesh leveling. You don't get to choose individual points (just the grid) and you can't specify trigger height corrections. But you can have a lot more points.""
          If I'm running 25 point check I need to delete out the old G30 command lines and replace it with a G29?
            Borgtribble @Turbo
            @Turbo ALL FIXED got it working so I'm all good! I'm using G29 in the bed.g and got the first bed mesh mapped out. Currently my resin printer is making a mount to go on the left side. This will allow me to probe more of the bed :). I learned quite a bit since I botched this probe offset, with the new knowledge I plan on make the best bed mesh I can. Again thanks for all the help everyone, and Turbo you did a lot here so I'm going to name my Printer "Turbo" (Hopefully no more issues from here!)
            • Turboundefined
              Turbo
              Glad you got it! Its really weird at first, but it makes a lot of sense when it clicks ya know. If youve got any more issues lemme know
              Cant stop tuning wont stop tuning.
              Dbot, Custom i3, Voron 0&2
              Borgtribbleundefined 1 Reply Last reply Reply Quote 1
                Borgtribble @Turbo
                @Turbo Thanks, I'm hoping with the touch mounted on the left I can get most of the bed mapped out. (Since the probe can move more to right of the hotbed)
                • Damienundefined
                  Damien
                  Can anybody explain how to do the above when you’re bed origin is at the Centre?
                  I’m using a induction sensor with a special print bed top. My printer is an Ender 5 pro, with a duet 2 maestro board.
                  My probe offset is -60(x) and -12(y).
                  What’s the formula you should use to figure out what to program your settings to so my probe doesn’t go off the bed?
                  Thank you so much for your hell with this!
                    @Damien it should be very much the same since it's still just a cartesian X Y coordinate system. The only difference with having 0,0 in the center is that the low ends will be negative.
                    What are your M208 limits?
                    • Damienundefined
                      Damien
                      @Phaedrux right now it’s
                      M208 X-110 Y-110 Z0 S1
                      M208 X110 Y85(Due to the HeroMe Gen5 duct installed) Z300 S0
                      Damienundefined 1 Reply Last reply Reply Quote 0
                      • Damienundefined
                        Damien @Damien
                        I was thinking of putting together an Excel Spreadsheet and sharing it so it figures out min/max values automatically.
                        Thank you for your help, by the way! 😁
                          Alright, so the M557 would as far as you want on the low side because your probe offsets are to the low side, and on the high side it would only be able to reach as far as x110 - x60 and Y85 - y12
                            Phaedrux Moderator @Damien
                            @Damien The easiest way to find the ideal M557 for me in practice is to just jog the print head around so that the probe is where I want it and take those XY coordinates.
                            • Damienundefined
                              Damien
                              Ok....I am still so confused! 😆
                              So I took you suggestion about jogging head around to find what I can work with based on my mods.
                              As a result, my min/Max axis has changed.
                              Below is my config. What calculations should I use to figure out how to define the grid again? 😣
                              Thank so much in advance!!
                              ; Configuration file for Duet Maestro (firmware version 3)
                              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 22:55:16 GMT-0500 (Colombia Standard Time)
                              M550 P"Damiens Ender 5 Pro" ; set printer name
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S1 ; enable Telnet
                              M569 P2 S0 ; physical drive 2 goes backwards
                              M350 X64 Y64 Z64 E128 I1 ; configure microstepping with interpolation
                              M92 X320.00 Y320.00 Z3200.00 E747.59 ; set steps per mm
                              M566 X900.00 Y900.00 Z60.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                              M84 S30 ; Set idle timeout
                              M208 X-110 Y-110 Z0 S1 ; set axis minima
                              M208 X105 Y92 Z300 S0 ; set axis maxima
                              M558 P5 C"!^zprobe.in" H5 A1 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                              G31 P200 X-60 Y-12 Z5.98 ; set Z probe trigger value, offset and trigger height
                              M557 X-110:110 Y-110:110 S10 ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                              M307 H0 A140.3 C627.1 D0.2 S1.00 V22.9 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                              M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                              M307 H1 A340.0 C140.0 D5.5 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit
                              M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                              M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
                              M563 P0 D0 H1 F0:2 ; define tool 0
                              M501
                                Maybe it would help if you created a diagram of your bed like this one.
                                By the way, 60mm in the x direction is quite a bit. Is that really the closest you can get the probe to the nozzle?
                                • Damienundefined
                                  Damien
                                  Thank you for this. I'll fill in and see if it helps. I'll post image if I still can't work it out.
                                  In the meantime, here are some pics of my setup. With the Induction sensor I have, this is the closest I could get it...
                                  • Damienundefined
                                    Damien
                                    Ok, here it is....What do you think?
                                    • Damienundefined
                                      Damien @Damien
                                      @Phaedrux When I input the ranges of the green the probe still goes over the edge. Any pointers?
                                        What's the coordinate of the nozzle that keeps your probe on the bed?
                                        • Damienundefined
                                          Damien @Phaedrux
                                          @Phaedrux all the coordinates you see in the green are ones where the sensor stays over the bed. But, so some reason when I put my M557 x-110:55 Y-110:82 S10 other first probe starts at x-50 y-98. 🤨
                                          Then it proceeds to keep probing until off the bed on the x axis, which I then have to emergency kill it.
                                          • Damienundefined
                                            Damien
                                            Ok, I just tried adding the probe offset on one side of the green coordinates and minus’’Ed on the other and that seems to have done the trick.
                                            So my coordinates for M557 is now X-170:-5 Y-122:94. Probing is perfect now. 😁
