    PT100 sensor and Daughter Board issue
    1.0k
    • sozkanundefined
      sozkan @Phaedrux
      @Phaedrux said in PT100 sensor and Daughter Board issue:
      Please also send M115 to confirm you have firmware 3.1.1 installed.
      Also send M98 P"config.g" to see if there are any syntax errors in your config.g
      @Phaedrux
      This te response from :
      10/25/2020, 12:13:00 PM	M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      However M98 P"config.g" did not respond from the DWC interface. On the latest beta version was responding and this macro code was working.
      • sozkanundefined
        sozkan @A Former User
        @bearer said in PT100 sensor and Daughter Board issue:
        @sozkan said in PT100 sensor and Daughter Board issue:
        M308 S1 P"spi.cs1" Y"rtd-max31865" R4700 ; configure sensor 1 as PT100 on pin e0temp
        Remove R4700, but not sure it will cause a problem.
        Also the jumpers on the board is present?
        Thank you all! Temperature issue 99% is solved. 1% is the temperature difference. Which is actually a success. R4700 was the problem! However, in the Duet documentation, this "R4700 " was recommended!
        Heat bed and Hotend temperatures slightly different. I assume PT100 cable length resistance might cause the difference right?
        Here is the result :
        As feedback:
        "S" values sometimes represent the function and Hardware channel and "P" values the same. That is confusing. Am I wrong? There are similar problems with different solutions and it is also confusing.
        As you may look Dyze -Design Typhoon Hotend documentation gives wrong guiding as well...
        By the way, Is it worth upgrading to Board version 3? Because we have plans to integrate a camera onboard, a Realtime printed part simulation that shows work in progress in actual part viewed on-screen display interface using RasberyPi integrated ( if possible) with duet board resources.
        Kind Regards
        sozkanundefined A Former User? dc42undefined theruttmeisterundefined 4 Replies Last reply Reply Quote 0
        • sozkanundefined
          sozkan @sozkan
          @sozkan
          I will make a conclusion for newcomers especially PT100 or dyze-design Typhoon users.
          • Hardware: Duet 2 Wifi v1.04
          • Daughter Board: v1.1 (max31865)
          • Heat Bed Sensor: an NTC 100k Thermistor connected to the board heat bed connector.
          • Hotend Sensors: 2 Piece of 2 wire PT100 type sensors comes with Dyze-Design Typhoon HotEnd.
          Working Configuratuin Code :
          ; Bed Heater
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                            ; map heated bed to heater 0
          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
          ; HotEnd
          M308 S1 P"spi.cs1" Y"rtd-max31865"    		 	; configure sensor 1 as PT100 on pin e0temp
          M308 S2 P"spi.cs2" Y"rtd-max31865"             ; configure sensor 2 as PT100 on pin e1temp
          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
          M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H1 B0 S0.50                                   ; disable bang-bang mode for heater  and set PWM limit
          M307 H2 B0 S0.50                                   ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S480 ;Set temperature max temp:
          M143 H2 S480 ;Set temperature max temp:
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S1 H2:1 T45                                ; set fan 0 value. Thermostatic control is turned on
          M563 P0 D0 H1:2 F0 S"Typhoon"                      ; define tool 0
            A Former User @sozkan
            Only for pt1000? If not please point to where you found it so it can be corrected.
            Could be, use (3 or) 4 wire measurements to eliminate cable lenght as an issue
            sozkanundefined 1 Reply Last reply Reply Quote 0
            • sozkanundefined
              It is here in the DyzeDesign documentation:
              https://docs.dyzedesign.com/typhoon.html#reprap-firmware
              • Vetiundefined
                Veti
                that is not the official duet documentation.
                the official duet documentation says
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M308_Set_or_report_sensor_parameters
                Rnnn Series resistor value. Leave blank to use the default for your board.
                • sozkanundefined
                  sozkan @Veti
                  @Veti said in PT100 sensor and Daughter Board issue:
                  I believe it is Official documentations; R values for the Duet Wifi "R4700" But it did not work with our case. That`s what I mean.
                  https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_The_M305_M308_R_parameter
                  I don`t blame, that's just feedback from the user perspective.
                  • Vetiundefined
                    Veti @sozkan
                    that is true for the normal thermistor on the duet.
                    its not true for the dautherboard.
                      A Former User
                      I believe it is Official documentations; R values for the Duet Wifi "R4700" But it did not work with our case. Thats what I mean. https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_The_M305_M308_R_parameter I dont blame, that's just feedback from the user perspective.
                      but that does say PT1000 not PT100; different beasts.
                      in any case it should be ammended I guess as the current reccomendation is to leave out R unless you've modified the board or have a very early board. firmware will apply the correct value for a given board - maestro and duet 3 have different value to duet 2 wifi/ethernet
                      • sozkanundefined
                        @bearer The header starts with; "Connecting thermistors or PT1000 temperature sensors
                        The Duet series supports 4 types of temperature sensor: thermistor and PT1000, thermocouple, and PT100.
                        Since I don`t see specifically PT100 example, When I see this header, I consider this is a kind of group of sensors.
                        "This section describes how to connect thermistors or PT1000."
                        isn't it confusing?
                        However, it seems like my setup working on the ambient temperature as I share the conclusion, I don`t worry much about what it was saying.
                        Thanks for all your contribution.
                          dc42 administrators @sozkan
                          Where in the documentation did you see it recommended?
                          PT100 documentation is at https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors.
                          A Former User? sozkanundefined 2 Replies Last reply Reply Quote 0
                            A Former User @dc42
                            @dc42 said in PT100 sensor and Daughter Board issue:
                            maybe that could be re-written to something like
                            The Duet series supports 4 types of temperature sensor: PT1000, as well as PT100, NTC thermistor and thermocouple.
                            with links to the three other pages, maybe it would be clearer to those not intimately familiar with types of sensors.
                            • sozkanundefined
                              Right 🙂 Thanks.
                              • sozkanundefined
                                sozkan @dc42
                                Thank you very much. That`s exactly what I have done. It seems like working. I will share the youtube video on action.
                                • theruttmeisterundefined
                                  theruttmeister @sozkan
                                  Without knowing exactly where Dyze get their PT100 chips from (and hence what class they are)...
                                  RTD's (PT100 and PT1000's) are normally laser trimmed, platinum resistors. At room temperature they will typically be accurate to about 0.3 degrees of each other. And they are be read by a chip specifically designed to do that, so it can get better resolution across the usable range of an RTD.
                                  A Thermistor on the other hand is a much lower quality device, that will probably vary by 2-3 degrees even at room temp, and due to the way it changes resistance, has less resolution at room temp. (Its not unusual for thermistors to vary by up to 20 degrees at 220C).
                                  As @bearer said, 4 wire sensors would eliminate any error due to cable resistance, but for 3D printing you don't need that level of accuracy.
                                  The biggest advantage of an RTD is that if you ever replace one, you'll still get the same reading at the same temperature.
                                  Isolate, substitute, verify.
                                  sozkanundefined 1 Reply Last reply Reply Quote 1
                                  • sozkanundefined
                                    sozkan @theruttmeister
                                    @theruttmeister Thank you for informative writing.
                                    I have an extra 8-meter length after the hot end. However, try to make ohmic losses as low as possible by using 0.75 mm cable. It seems like working ( with a 2-3 celsius difference from the Thermistor on the heat bed at room temperature) I also think that`s not an issue.
                                    B. Regards.
