Solved Problem setting up core XY
@mrehorstdmd said in Problem setting up core XY:
if it's right, I suggest you demand your money back!
the original blv had a slight problem with that. but in this kit its very bad.
there is an original metal kit
https://www.aliexpress.com/item/1005001323243487.html
that does not have that problem -
@Veti I was wondering if there was a problem with the parts I purchased from a supplier in China BLV Does not promote that supplier anymore.
Does @mmartin == @william3d or are there two different machines/problems/people here?
A lot of great comments and information and I appreciate the time that everyone is put into helping me solve this issue. I'm continuing to read through and try everything everyone said I am continuing to have the same issue where I cannot move either X or Y By themselves The web controller shows example X25 Y25 I move to X25 Y200 The web controller shows X25 Y200 but You can tell X has moved to 150 and Y is at 200.
@william3d
can you post a picture of the x carriage from the side. -
@mrehorstdmd Just me and my core XY cube build
@william3d said in Problem setting up core XY:
I move to X25 Y200
what is the exact command you issued?
@Veti G1 X25 Y250
G1 H0 X25 Y250
H1
H2
AND
G0 X25 Y250These are some of the formats I've tried and I have not used the H3.
G0 X25 Y250
This is the correct one.
For movement tests with positions leave out the H part completely
Post the output of M669
@mmartin said in Problem setting up core XY:
Does Cura automatically use my bed leveling mesh or do I need to run it in the starting Gcode?
You need to load the saved mesh or re-probe the entire bed before the print is started. This means adding G29 S1 to the slicer start gcode after the G28 that homes the printer.
here is a crude fix for your belt problem.
run the belt through the hole from behind and have a loop out in front.
put a bolt (a large screw or something) through the loop to stop the belt from pulling out.here is a fix i did for this on the plastic parts
@Phaedrux
he posted in this thread by accident. -
@Veti said in Problem setting up core XY:
@Phaedrux
he posted in this thread by accident.Oh well, I still answered on purpose.
@Phaedrux is there a way to add bed heat before the homing and also bed probing? My sensor needs the bed to be heated to produce accurate results. I've been doing it manually but it would be nice to automate this process as well.
@mmartin
please dont hijack other peoples threads with different probems. -
@Veti ummmm ok...
it gets confusing.
as you can see you already confused @mrehorstdmd -
My original reply was within context of his post about the bed origins. Regardless have a good one!
@Veti M669
Kinematics is CoreXY, matrix:
1.00 1.00 0
1.00 -1.00 0
0 0 1.00
