Solved Problem setting up core XY
@Veti G1 X25 Y250
G1 H0 X25 Y250
H1
H2
AND
G0 X25 Y250These are some of the formats I've tried and I have not used the H3.
@william3d said in Problem setting up core XY:
G0 X25 Y250
This is the correct one.
For movement tests with positions leave out the H part completely
Post the output of M669
@mmartin said in Problem setting up core XY:
Does Cura automatically use my bed leveling mesh or do I need to run it in the starting Gcode?
You need to load the saved mesh or re-probe the entire bed before the print is started. This means adding G29 S1 to the slicer start gcode after the G28 that homes the printer.
here is a crude fix for your belt problem.
run the belt through the hole from behind and have a loop out in front.
put a bolt (a large screw or something) through the loop to stop the belt from pulling out.here is a fix i did for this on the plastic parts
@Phaedrux
he posted in this thread by accident. -
@Veti said in Problem setting up core XY:
@Phaedrux
he posted in this thread by accident.Oh well, I still answered on purpose.
@Phaedrux is there a way to add bed heat before the homing and also bed probing? My sensor needs the bed to be heated to produce accurate results. I've been doing it manually but it would be nice to automate this process as well.
@mmartin
please dont hijack other peoples threads with different probems. -
@Veti ummmm ok...
it gets confusing.
as you can see you already confused @mrehorstdmd -
My original reply was within context of his post about the bed origins. Regardless have a good one!
@Veti M669
Kinematics is CoreXY, matrix:
1.00 1.00 0
1.00 -1.00 0
0 0 1.00 -
can you move any of the belts by hand while the motors are energised ?
@Veti When the motors are on After homing and energized I cannot move by hand
I'm easily confused.
The belt angles don't look so bad from above.
What are the motor specs?
X Moves correctly
Y Moves correctlyThe web controller shows example X25 Y25 I move to X25 Y200 The web controller shows X25 Y200 but You can tell X has moved to 150 and Y is at 200.
i am also getting confused as this does not match
could you please restate your problem.
stating exactly which command you are issuing. -
M92 X160.00 Y160.00
a normal blv setup has 16 tooth pulley which would give you X200 Y200
are you sure both motors are 0.9 degrees? if one is 1.8 that could give very strange results.
@mrehorstdmd
Electrical Specification
Bipolar/Unipolar Bipolar
Holding Torque(Ncm) 46
Holding Torque(oz.in) 65.1
Inductance(mH) 3
Phase Resistance(ohm) 1.4
Rated Current(A) 2
Step Angle(°) 0.9
Physical Specification
Body Length(mm) 48
Frame Size(mm) 42 x 42
Single Shaft/Dual Shaft Single Shaft
Shaft Type D-Cut
Shaft Diameter(mm) 5
Shaft Length(mm) 24
No. of Lead 4
Lead Length(mm) 500
Weight(g) 400 -
Shaft Type D-Cut
blv require full d-cut shafts. could the pulleys be slipping?
@Veti You could be onto something the two motors on X and Y Part numbers are different and I think it means one is .9 and one is 1.8 Looking up and trying to verify right now.
17HS19-2004S2
17HS19-2004S1
