    Back with opnpnp again
    540
    • qlfecvundefined
      qlfecv
      I already have my machine configured with duet2 wifi with X, Y and Z axes and C and D rotary nozzles plus a few actuators.
      To finish I need to read the analog signal of 2 vacuum sensors, but I don't see how to read only the value.
      I have tried with:
      M308 S1 P "e0temp" Y "linear-analog" A "MySensor2" F1
      but reading it gives me this
      Sensor 1 (MySensor2) type Linear analog using pin e0temp, reading 99.9, last error: sensor not ready, filtered, range 0.0 to 100.0
      I just need to read only the value.
      Any idea how to do it?
      Jose
        The reading of 99.9 suggests that the analog input is at +3.3V. Have you measured the voltage on the input?
        • qlfecvundefined
          qlfecv
          The value is OK, but I only want to read 99.9
            dc42 administrators @qlfecv
            @qlfecv said in Back with opnpnp again:
            Please explain what you mean. What is the voltage on the analog input pin?
            Edit: Do you mean that you want a shorter response? You can get the value from the object model, for example using M409, or refer to it in a 'echo' command.
            • qlfecvundefined
              qlfecv
              Yes, I want shorter response.
              How work M409 with M308 sensor?
                echo sensors.analog[1].lastReading
                25.9
                • qlfecvundefined
                  qlfecv
                  Thanks @dc42,
                  • qlfecvundefined
                    qlfecv
                    @dc42 Is posible read digital value? (4095)
                      You could set the range in M308 to 0 to 4096 instead of 0 to 100. Then if you don't want any decimals, use the floor( ) function in the echo command to convert the reading to integer. Or you can stay with 0 to 100 and multiply by 4096.0/100 first. See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Expressions to see what expressions you can use within the echo command (and in lots of other places).
                      • qlfecvundefined
                        qlfecv
                        Thanks again 👍 👍
                        • qlfecvundefined
                          qlfecv
                          I don't understand that I'm doing wrong.
                          I have this configuration
                          M950 C"bedtemp" C"nil"
                          M308 S2 P"bedtemp" Y"linear-analog" A"V_Sen_H2" F1 L0 H4095
                          The pin is 0V I send this
                          echo sensors.analog[2].lastReading
                          0.0
                          Now pin 3.3v
                          100.0
                            @qlfecv, the M308 documentation for Linear Analog sensors was wrong. The min and max reading parameters are B and C, not L and H. So use B0 C4095.
                            qlfecvundefined 1 Reply Last reply Reply Quote 0
                            • qlfecvundefined
                              qlfecv
                              Ok, so I try it.
                              @dc42 what is the best option to add the sixth axis?
                              I don't like using additional hardware, but with duet2wifi I have no other solution.
                              When I can I will buy one " Duet 3 Main Board 6HC".
                                T3P3Tony administrators @qlfecv
                                @qlfecv where are you based?
                                • qlfecvundefined
                                  qlfecv
                                  In Barcelona, Spain
                                    @qlfecv ah cool. I think @dc42 will be in contact.
                                    • qlfecvundefined
                                      qlfecv @dc42
                                      @dc42 said in Back with opnpnp again:
                                      Working fine 👍
