    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    11.6k
    • arhiundefined
      arhi
      same thing only tad heavier 🙂 .. will work for this purpose
      JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
      • JohnOCFIIundefined
        JohnOCFII @arhi
        @arhi said in Inconsistent results with optical encoder wheel filament sensor:
        The encoder wheel in this design is so small -- just not sure how well any tape will work.
        I'm currently running the encoder wheel in the middle - 12 spokes.IMG_2013.jpeg
        • arhiundefined
          arhi
          should work ok with the middle one, glue the tape over the back side, then cut the "windows" open with a scalpel knife, should work like a charm
          JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
            JohnOCFII @arhi
            Thanks for the advice. I'll try a fresh blade and give that a shot -- likely tomorrow.
              JohnOCFII @arhi
              That wasn't as tricky as I thought it'd be. I do think I'll try it again with a fresh X-Acto blade.
              • arhiundefined
                arhi
                that should work like a charm, no transparency there now. the only question now is, will it provide a better readout now - was this transparency a problem or there's something else in play here.
                  JohnOCFII @arhi
                  I prepared the new axle and wheel with the copper tape. I used two coats of a black Sharpie to "paint" the shiny copper and installed the new axle. Sadly, the results are very similar. This is also from the vase mode print with no PA and no retraction.
                  Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 3.000mm/pulse, allowed movement 30% to 1500%, check every 10.0mm, measured sensitivity 0.581mm/pulse, measured minimum 70%, maximum 2543% over 1021.1mm
                  Next test will be in a few days when the new Saleae logic analyzer shows up - or if I decide to try the BitScope logic analyzer in a VM.
                  • arhiundefined
                    arhi @JohnOCFII
                    @JohnOCFII damn, so it was not transparency issue, damn, well, one idea out of the window 😞
                    dunno how to test for filament slipping on the tpu wheel
                      JohnOCFII @arhi
                      By removing the optical sensor, I can visually watch the wheel move during the test print I was using. As it was a vase mode cylinder, it was easy to confirm the wheel was moving continuously and (within the calibration of my MARK 1 EYEBALL) consistently. So, while it is possible during a "normal" print where I might have moves at 250mm/sec or other such changes in filament movement, I don't think that is an issue with this particular test.
                      Next will be to try to get a sense of what data is coming out of that sensor.
                      • arhiundefined
                        arhi @JohnOCFII
                        @JohnOCFII I'd still do that test without hotend
                        • remove hotend so you have only extrder drive and sensor
                        • disable "heating" in the g-code
                        • allow "cold extrusion" in the firmware
                        • do a print of a simple long extrusion g-code
                          JohnOCFII @arhi
                          Yes -- good idea. I will do that tomorrow.
                            JohnOCFII @arhi
                            I disconnected the extruder from the hot-end and set up some GCode to run so I could measure filament. I started with a test at 100mm, but M591 D0 is showing no data. Curious if not having the printer homed is causing the data collection to be ignored. Maybe I missed something.
                            Here's my GCode:
                            ; Test Extrusion
                            M302 P1                                            ; Allow cold extrusion
                            G92 X0Y0Z0                                         ; duet now assume we are homed
                            M82                                                ; extruder absolute position
                            G92 E0                                             ; reset extruder to 0
                            M591 D0 P7 C"connlcd.encb" S0 R50:1500 L1.2 E5 A1  ; config filament sensor
                            ; G1 E1000 F120                                     ; extrude 1000mm at 2mm/sec, so will be extruding around 8 minutes
                            G1 E100 F120                                       ; extrude 100mm at 2mm/sec, so will be extruding around 1.2 minutes
                            M591 D0                                            ; query filament sensor
                            Time for some yard work! Got to go rake leaves.
                            arhiundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                            • arhiundefined
                              arhi @JohnOCFII
                              @JohnOCFII you have to save that script as a file and make RRF print that file, you can't just execute the script as in that case filament monitor is disabled
                                JohnOCFII @JohnOCFII
                                @JohnOCFII said in Inconsistent results with optical encoder wheel filament sensor:
                                Here's my GCode:
                                ; Test Extrusion
                                Yes, I saved it as ColdExtrusioTest.g and "printed" it same as I would any other file.
                                There must be something else I'm missing. I'll have to think about it.
                                10/31/2020, 3:10:14 PM	M591 D0
                                Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no calibration data
                                10/31/2020, 3:07:37 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                                10/31/2020, 3:06:47 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                                File 0:/gcodes/Calibration/ColdExtrusionTest.g selected for printing
                                Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no data received
                                10/31/2020, 3:05:50 PM	M591 D0
                                10/31/2020, 3:03:59 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                                10/31/2020, 3:03:09 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                                  JohnOCFII
                                  I homed the printer, then ran this file while it was still homed - no change in output.
                                  • arhiundefined
                                    arhi
                                    @JohnOCFII and it passed those 100mm trough extruder and sensor and the wheel were rotating? that's rotating rather slow right, can you check the impulses with a multimeter maybe? analog one would work great?
                                      JohnOCFII @arhi
                                      Yes. Also, the optical sensor board has an LED that was blinking at regular intervals.
                                      Depending on the weather, I'm supposed to fly with a student tomorrow (weekend flight instructor). If not, I'll try this tomorrow.
                                      Saleae LA should arrive Monday or Tuesday. 🙂
                                      • arhiundefined
                                        arhi @JohnOCFII
                                        @JohnOCFII I'm more interested to see the levels you see on the duet board so measuring voltage between the signal pin (connlcd.encb) and gnd using voltmeter while slowly moving the encoder so to see what you have there for 0 (when that signal led is off) and what you have there for 1 (when that signal led is on) .. as I don't see a reason why would RRF detect these impulses for me and not for you unless there's something fishy with the voltage levels there ... how the cable is crymped etc etc..
                                          JohnOCFII
                                          So I've re-assembled the hot-end/extruder, and added some wiring extensions to connect to the Logic Analyzer. I was seeing incredibly strange outputs -- like this:
                                          Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, measured sensitivity 0.000mm/pulse, measured minimum 0%, maximum 1052141% over 46.6mm
                                          So I pulled the optical sensor off the case, and confirmed the encoder wheel is still moving as expected.
                                          So while the print was running, I started using a flat print to interrupt the sensor on a sort of regular basis, and started to get "more normal" results again. And by normal -- I mean normal for my recent results...
                                          Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 30% to 1500%, check every 10.0mm, measured sensitivity 0.386mm/pulse, measured minimum 0%, maximum 6059% over 372.6mm
                                          I'm starting to wonder about wiring issues, or something else more related to the DUET. One thing you suggested was to try a different port, as this CONNLCD might be treated differently than the other ports.
                                          (I've got more free time than expected today -- so will keep plugging at things today)
                                          • alankilianundefined
                                            alankilian @JohnOCFII
                                            @JohnOCFII Hey John, I've been trying to keep up with this thread and I have a question you may have answered already:
                                            How is the receiver part of your optical interruptor connected to your Duet?
                                            Do you have a pull-up or pull-down resistor on the signal that goes to the Duet?
                                            If you got the digital-only Saleae you won't be able to see if there's a level problem due to a missing or too-large pull-resistor.
