    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    11.6k
    • JohnOCFIIundefined
      JohnOCFII @arhi
      @arhi said in Inconsistent results with optical encoder wheel filament sensor:
      that should work like a charm, no transparency there now. the only question now is, will it provide a better readout now - was this transparency a problem or there's something else in play here.
      I prepared the new axle and wheel with the copper tape. I used two coats of a black Sharpie to "paint" the shiny copper and installed the new axle. Sadly, the results are very similar. This is also from the vase mode print with no PA and no retraction.
      Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 3.000mm/pulse, allowed movement 30% to 1500%, check every 10.0mm, measured sensitivity 0.581mm/pulse, measured minimum 70%, maximum 2543% over 1021.1mm
      Next test will be in a few days when the new Saleae logic analyzer shows up - or if I decide to try the BitScope logic analyzer in a VM.
      • arhiundefined
        arhi @JohnOCFII
        @JohnOCFII damn, so it was not transparency issue, damn, well, one idea out of the window 😞
        dunno how to test for filament slipping on the tpu wheel
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          JohnOCFII @arhi
          By removing the optical sensor, I can visually watch the wheel move during the test print I was using. As it was a vase mode cylinder, it was easy to confirm the wheel was moving continuously and (within the calibration of my MARK 1 EYEBALL) consistently. So, while it is possible during a "normal" print where I might have moves at 250mm/sec or other such changes in filament movement, I don't think that is an issue with this particular test.
          Next will be to try to get a sense of what data is coming out of that sensor.
          • arhiundefined
            arhi @JohnOCFII
            @JohnOCFII I'd still do that test without hotend
            • remove hotend so you have only extrder drive and sensor
            • disable "heating" in the g-code
            • allow "cold extrusion" in the firmware
            • do a print of a simple long extrusion g-code
            JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
              JohnOCFII @arhi
              Yes -- good idea. I will do that tomorrow.
                JohnOCFII @arhi
                I disconnected the extruder from the hot-end and set up some GCode to run so I could measure filament. I started with a test at 100mm, but M591 D0 is showing no data. Curious if not having the printer homed is causing the data collection to be ignored. Maybe I missed something.
                Here's my GCode:
                ; Test Extrusion
                M302 P1                                            ; Allow cold extrusion
                G92 X0Y0Z0                                         ; duet now assume we are homed
                M82                                                ; extruder absolute position
                G92 E0                                             ; reset extruder to 0
                M591 D0 P7 C"connlcd.encb" S0 R50:1500 L1.2 E5 A1  ; config filament sensor
                ; G1 E1000 F120                                     ; extrude 1000mm at 2mm/sec, so will be extruding around 8 minutes
                G1 E100 F120                                       ; extrude 100mm at 2mm/sec, so will be extruding around 1.2 minutes
                M591 D0                                            ; query filament sensor
                Time for some yard work! Got to go rake leaves.
                arhiundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                • arhiundefined
                  arhi @JohnOCFII
                  @JohnOCFII you have to save that script as a file and make RRF print that file, you can't just execute the script as in that case filament monitor is disabled
                    JohnOCFII @JohnOCFII
                    @JohnOCFII said in Inconsistent results with optical encoder wheel filament sensor:
                    Here's my GCode:
                    ; Test Extrusion
                    Yes, I saved it as ColdExtrusioTest.g and "printed" it same as I would any other file.
                    There must be something else I'm missing. I'll have to think about it.
                    10/31/2020, 3:10:14 PM	M591 D0
                    Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no calibration data
                    10/31/2020, 3:07:37 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                    10/31/2020, 3:06:47 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                    File 0:/gcodes/Calibration/ColdExtrusionTest.g selected for printing
                    Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no data received
                    10/31/2020, 3:05:50 PM	M591 D0
                    10/31/2020, 3:03:59 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                    10/31/2020, 3:03:09 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                      JohnOCFII
                      I homed the printer, then ran this file while it was still homed - no change in output.
                      • arhiundefined
                        arhi
                        @JohnOCFII and it passed those 100mm trough extruder and sensor and the wheel were rotating? that's rotating rather slow right, can you check the impulses with a multimeter maybe? analog one would work great?
                          JohnOCFII @arhi
                          Yes. Also, the optical sensor board has an LED that was blinking at regular intervals.
                          Depending on the weather, I'm supposed to fly with a student tomorrow (weekend flight instructor). If not, I'll try this tomorrow.
                          Saleae LA should arrive Monday or Tuesday. 🙂
                          • arhiundefined
                            arhi @JohnOCFII
                            @JohnOCFII I'm more interested to see the levels you see on the duet board so measuring voltage between the signal pin (connlcd.encb) and gnd using voltmeter while slowly moving the encoder so to see what you have there for 0 (when that signal led is off) and what you have there for 1 (when that signal led is on) .. as I don't see a reason why would RRF detect these impulses for me and not for you unless there's something fishy with the voltage levels there ... how the cable is crymped etc etc..
                              JohnOCFII
                              So I've re-assembled the hot-end/extruder, and added some wiring extensions to connect to the Logic Analyzer. I was seeing incredibly strange outputs -- like this:
                              Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, measured sensitivity 0.000mm/pulse, measured minimum 0%, maximum 1052141% over 46.6mm
                              So I pulled the optical sensor off the case, and confirmed the encoder wheel is still moving as expected.
                              So while the print was running, I started using a flat print to interrupt the sensor on a sort of regular basis, and started to get "more normal" results again. And by normal -- I mean normal for my recent results...
                              Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 30% to 1500%, check every 10.0mm, measured sensitivity 0.386mm/pulse, measured minimum 0%, maximum 6059% over 372.6mm
                              I'm starting to wonder about wiring issues, or something else more related to the DUET. One thing you suggested was to try a different port, as this CONNLCD might be treated differently than the other ports.
                              (I've got more free time than expected today -- so will keep plugging at things today)
                              • alankilianundefined
                                alankilian @JohnOCFII
                                @JohnOCFII Hey John, I've been trying to keep up with this thread and I have a question you may have answered already:
                                How is the receiver part of your optical interruptor connected to your Duet?
                                Do you have a pull-up or pull-down resistor on the signal that goes to the Duet?
                                If you got the digital-only Saleae you won't be able to see if there's a level problem due to a missing or too-large pull-resistor.
                                  JohnOCFII @alankilian
                                  @alankilian said in Inconsistent results with optical encoder wheel filament sensor:
                                  The optical sensor is connected to pins 1,2,3 on the CONN_LCD connector. I'd previously used this connection for a basic physical endstop-type filament sensor. I've tried the optical sensor with, and without the pull-up as indicated by including the "^" in the configuration string, but didn't see a noticeable change in behavior.
                                  https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                                  I'm getting the Logic 8, which appears to have analog inputs. https://www.saleae.com
                                  Also - right now I've hooked up a BitScope Micro, which I ordered a few years ago, but never used. When I hook it up to GND and the signal pin, I see a bit of noise, but no change when I interrupt the optical sensor beam. On the sensor itself breaking the beam turns off an LED. Perhaps no data flows to the Duet when a print isn't running?
                                  I've never used a Logic Analyzer or O-Scope before, so this is all new to me.
                                    alankilian
                                    Both the LED-side and the receive-side of the interrupter need to be hooked up "in the right way"
                                    Can you post which connection on the Duet is connected to which connection on the optical interrupter?
                                    Also, can you post the name/number of the interrupter or a data sheet?
                                    It's pretty easy to get one side or the other backwards. AND it's pretty easy to fix!
                                    The new Logic 8 will be great.
                                    I have the very very old digital only Logic 8 as well as an old Logic 16 Pro that does both analog and Digital, so I can certainly help you setup and look at the signal when you get that.
                                      Duet Pin 1 (+3.3) <---> Pin labeled V on sensor
                                      Duet Pin 2 (GND) <--> Pin labeled G on sensor
                                      Duet Pin 3 (STOP 10 - ENC_B) <--> Pin labeled S on sensor
                                      The markings on the unit are 70T2. These are sensors I bought: https://www.ebay.com/itm/4-Pieces-Optical-Endstop-Limit-Switch-RAMPS-1-4-Board-3D-Printer-3Pin-Cable-A27/254260205504
                                      Excellent -- and thank you!
                                        alankilian
                                        Hmmmmm.
                                        How do you know if that's supposed to have 5 Volts or 3.3 Volts?
                                        And if it is supposed to pull the signal high or low?
                                        And if you need to add an extra resistor or not?
                                        (I'll do some googling and see if I can answer my own questions.)
                                          Hmmmmm.
                                          🙂 I don't. Just going off the recommendations of the guy who designed this filament sensor project: https://www.thingiverse.com/thing:4445504
                                          Good thing I consider this just a learning experience. Because even at the end of the day, Best case it seems I'll be stuck with a 20-40mm "window" of filament passage before it'll trigger an issue. Might just go back to the switch for "filament out". It won't catch jams, but it'll reliably catch the case of filament out.
                                          But first, I'd like to figure out why my results are so much worse than what @fractalengineer sees. 🙂
                                            JohnOCFII @arhi
                                            Voltage settles out at 3.2 when I pass a solid object between the optical sensor "arms." When nothing is between the arms, the voltage is not a clean, solid 0.0 but hovers in the 0.300-0.400 range.
                                            And also remember, this optical sensor board has an LED that is lit when there is no object breaking the beam, which turns off when the beam is broken.
                                            It seems like the sensor is sending what amounts to "on" or "off" but the Duet isn't dealing with it properly. This is firmware 3.1.1 on a Duet 2 Ethernet board.
                                            arhiundefined alankilianundefined 2 Replies Last reply Reply Quote 0
