    Duet 3 Expansion looses Connection
    duet 3 expansion
    779
    • vali3dundefined
      vali3d
      I am running the version: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HC
      Yes, it is allways the same board and the fault moves with the board.
        jay_s_uk @vali3d
        @vali3d I would suggest you look at moving to 3.1.1 for the main board and 3.1.0 for the expansion boards first.
        • vali3dundefined
          vali3d
          Ok, I have updated it now. This was quite some troubble, I had to completly redo the sd card. I will see if that helped in the next few days/weeks.
          Thanks
            Thanks. If that doesn't fix it, I will provide beta firmware for you to try. It turned out that the released firmware runs one of the PLLs in the chip out-of-specification, which could explain a difference between two boards even if neither is faulty.
            • botundefined
              bot
              Slightly off topic, but I really like the electronics cabinet you have (and that power supply looks nice too). Do you recall where/what model you purchased for the cabinet?
              *not actually a robot
              vali3dundefined 1 Reply Last reply Reply Quote 0
              • vali3dundefined
                vali3d @bot
                @bot https://www.dold-mechatronik.de/AE-Kompakt-Schaltschrank-Abmessung-waehlbar
                • vali3dundefined
                  vali3d
                  the expansion lost connection multiple times over the past weeks. According to my obsevations, this happens only under a load on the extruder motors (which are connected to the expansion).
                  Valentin
                    Can you send M122 Bx where X is the board number?
                    • vali3dundefined
                      vali3d @Phaedrux
                      @Phaedrux When the connection was lost or in normal operation?
                      • vali3dundefined
                        vali3d
                        I have checked the M122 B1/2 comand. The firmeware update I installed in September, didn´t install the firmeware to the expansions, only to the mainboard. Now I manualy installed the 3.2beta to expansions (with the M997 B1/2) an the mainboard. I keep you updated.
                        • vali3dundefined vali3d referenced this topic
                        • vali3dundefined vali3d has marked this topic as solved
