    My quad carriage machine is failing on Tools. AGAIN.
    3.6k
    • MaracMBundefined
      MaracMB
      this is only a not so distant memory. The time i miss
      Click for pic
      • MaracMBundefined
        MaracMB
        the topic was first opened here:
        https://forum.duet3d.com/topic/19312/duet2-axies-and-tools-motor-mapping-mismatch/2?_=1604425183271
        • MaracMBundefined
          MaracMB
          11th stepper is external, simple expansion breakout board (just as shown somewhere in the Wikis...) with original watterott tmc2209 until i get something better. Set to 16/256 microsteps and adjusted the jumpers accordingly for configuring it. That, motor 10 runs extruder for T3.
          The tools do extrude correctly btw. If that helps. So only definitions/mapping for X carriages have gone crazy.
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @MaracMB
            @MaracMB That is an impressive machine and I can certainly see that debugging it won't be easy!
            Might help if you post your config-override too for completeness
            In your homeu and homew, you only step back by 4mm before doing the slow home, while everywhere else (homex, v, all) you step back by 10mm. Just wondering if that's not enough and you're getting some failed homings on U and W during your tool changes which is messing them up? Might also explain why it seems intermittent if you're just on the limit?
            I've noticed that in your homez file, you don't re-hide your A axis, you only re-assign driver 4 to Z:
            M584 Z1:4 P7				; combine Z and V and show only 6 axes in interface
            TBH, it could be over-complicating things as you don't need to split the axis to use multiple endstops for multiple motors in RRF3 any more:
            https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Axis_levelling_using_endstops
            Just thinking it will remove one layer of drive mapping/assignments, homing etc from the equation.
            Other unrelated thing, in your config, you have set you motor microstepping at 32 with interpolation, but the duet doesn't support this - it's only 16 with interpolation
            i3 clone with a bunch of mods
            MaracMBundefined 2 Replies Last reply Reply Quote 0
            • MaracMBundefined
              MaracMB @engikeneer
              @engikeneer this project really was just a space/machinecount optimization that went it’s own way... i have much cooler stuff ready for this. But first things first.
              On endstops i retreat only 4 mm because of optical endstops. Triggering that is perfect. 4 mm is more than enough. Config is working version so a lot is unfinnished. It still needs a lot work.
              Splitting the axes for the Z... yes, i am aware of that possibility to optimize that but didn’t consider it a thing that would needed to be done.
              The interpolation on 32 microsteps is on because it makes less whine. Not that i would need 256interpolation... 2660 arent the quietest of tmc’s.
              • MaracMBundefined
                MaracMB @engikeneer
                @engikeneer the P7 parameter for axis visibility is there because i, when this thing gets resolved, will hide second Z axis (A). For now, i just set it to all visible, yet left for later change back to P6
                • MaracMBundefined
                  MaracMB
                  RESOLVED
                  For anyone, that might experience such headache and stumbles upon this:
                  one maps the axes, not the motors to the tools. and you count the axes, not specify motors...
                    I'm glad you solved it! Have you any suggestions on how we can improve the documentation to help others to avoid the same issues?
                    MaracMBundefined 1 Reply Last reply Reply Quote 0
                    • MaracMBundefined
                      MaracMB @dc42
                      @dc42 well, it’s still RTFM thing i guess. But it may be nice to just copy paste that section with asigning axes to tools in “Creating a tool that uses just one carriage”.
                      The instructions later on, when defining ditto tools clearly state
                      ‘’’ Note that axes are mapped in the order XYZUVWABC, where X=0, Y=1, Z=2, U=3 etc, not by driver number, so X0:3 means 'map axis 0 (X) and 3 (U) to X'.’’’
                      But this is minor. The extent of frustration, optimization and learning one goes through may just be beneficial 😉
                      So tools definitions solved, and properly understood, i have to check homing reliability now. That may still be an issue.
                      I am stripping
                      m120
                      M84 Prime.g
                      M121
                      From my toolchange post scripts to see if that helps with tools homing reliability. That’s the only thing that’s left i guess. If it won’t, i’ll nag on.
                      • MaracMBundefined
                        MaracMB
                        i have re-set my toolchange scripts. It worked for a while.
                        After 2-3 hours, the 4th axies failed to home when tool was deselected.
                        Error G0/G1
                        M120
                        G91
                        G1 X50 F6000
                        G90
                        M121
                        Where does this come from ? This is not in my homing files, not in my toolchange files, nowhere.
                        My tfree file now look like :
                        G1 E-12 F3600 			; retract 12mm
                        G91 				; relative axis movement
                        G1 Z2 F360 			; up 2mm
                        G90 				; absolute axis movement
                        G28 X				; park the U carriage home - slow
                        M106 S0         		; turn off print cooling fan
                        My tpost look like:
                        M106 R2         	; restore print cooling fan speed
                        M116 P0 		; wait for tool 0 heaters to reach operating temperature
                        G91
                        G1 X1 H2
                        G90
                        G28 X
                        G1 E12 F1200 		; extrude 12mm
                        I thought it worked. But then it didn't. 😞
                        Also, when i homeall , all tools home normaly.
                        But when i homeall via gcode file (G28), second tool does not home correctly.
                        homeu.g :
                        G91              ; relative positioning
                        G1 Z2 F360 H2    ; lift Z relative to current position
                        G1 U320 F3600 H1 ; move quickly to X axis endstop and stop there (first pass)
                        G1 U-2 F600 H2    ; go back a few mm
                        G1 U4 F360 H1 	 ; move slowly to X axis endstop once more (second pass)
                        G1 Z-2 F360 H2   ; lower Z again
                        G90               ; absolute positioning
                        Homeall.g :
                        G1 X-400 Y-450 U400 V-400 W400 F3600 H1	; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 X5 Y5 U-5 V5 W-5 F3600 H2         	; go back a 5 mm
                        G1 Y-10 X-10 U10 V-10 W10 F360 H1 			; second pass
                        M98 Phomez.g			; call homing script for Z axes
                        G90
                        • MaracMBundefined
                          MaracMB
                            Is it the U and/or W axes that failed to home? If so, it is just one of those, or both of them?
                            Those endstop switches are the ones connected to the DueX5 board. Keeping those switches up to date relies on I2C communications between the Duet and the DueX along with an interrupt. A M122 report taken when this happens will provide data on the status of the I2C interface.
                              Phaedrux Moderator @MaracMB
                              @MaracMB said in My quad carriage machine is failing on Tools. AGAIN.:
                              What do you mean by this? G28 is homeall.g. How else are you homing all?
                              • MaracMBundefined
                                MaracMB
                                @dc42 would it help if i shorten the IDE cable in between them?
                                I do have to get the wiring in orderly lenghts and routes... it’s A LOT of wiring... 😂
                                So it’s basically just latency issue?
                                Can ,i in time i do wiring, insert some pauses into homing? Half a second here and there wouldn’t hurt for realiability.
                                  Can you post a photo of how you have the Duet and Duex wired together? Particularly the power?
                                  See the description and photo here for how it should be done.
                                  https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                  MaracMBundefined 3 Replies Last reply Reply Quote 0
                                  • MaracMBundefined
                                    MaracMB @Phaedrux
                                    @Phaedrux exactly.
                                    I think it’s latency as i interpret dc42’s explanation...
                                    And i thought off adding 5th and 6th carriage. Silly me.
                                    @dc42 would it help if i put all X carriages on one board and extruders on the other?
                                    • MaracMBundefined
                                      MaracMB @Phaedrux
                                      @Phaedrux that i can do in the morning (machine in the cave...)
                                      It’s powered from a 350w meanwell, AC bed. The VIN from PSU is 1.5mm i guess.. stock. And “the bridge” between the Duet and Duex is with 2.5mm2 high grade copper wires. Ferulle crimped.
                                      • MaracMBundefined
                                        MaracMB @Phaedrux
                                        @Phaedrux , @dc42
                                        I have rewired.
                                        Put all the X motors and Y on the Duet board, and Duex now holds both Z motors and all E motors.
                                        I have rewired the VIN. Just in case.
                                        I have reset the configs accordingly.
                                        State of art:
                                        Machine seems to home the X carriages reliably now, same goes for Y
                                        But now it fails on almost every or every second Z homing.
                                        If i home Z, it will probably home correct. If i go and commit home all, it will most definetly not home Z axes correctly.
                                        Machine needs independant Z motors to level the X gantries every single time, or this is just a very, very, very large paperweight.
                                        As suggested by @engikeneer, i have joint the Z axes. Is this now a problem?
                                        homez.g :
                                        G1 H2 Z5 F600
                                        G1 Z-405 F900 H1
                                        G1 Z2 F900 H2
                                        G1 Z-5 F360 H1
                                        G1 Z3 F900				; lift both Zs to 3
                                        homeall.g
                                        G90
                                        Mapping Z
                                        M584 X0 Y2 Z5:6 U1 V3 W4
                                        Endstops for Z:
                                        M574 Z1 S1 P"!duex.e2stop+!duex.e3stop"
                                        I have set the voltages for the Z motors as:
                                        M906 X950 Y1050 Z950:950 U950 V950 W950 I30
                                        Is this ok? not sure how else i can do it if two motors, same axis, two endstops...
                                        • MaracMBundefined
                                          MaracMB @Phaedrux
                                          @Phaedrux
                                          rats nest:
                                          https://drive.google.com/file/d/1XQcPBchHubw7k9XG6YlcQA89s1ovAu4-/view?usp=sharing
                                          new VIN
                                          https://drive.google.com/file/d/1PnsclKfqTyVa3TaVUyYYShSjggaT2_Y3/view?usp=sharing
                                          the IDE is already as short as possible. in given circumstances.
                                          is this just too much for Duet and will i have to use some other platform?
                                          if you notice that Duex is not as it should be, it's because i fried two of them already and i am NOT frying another original until this is done. Money does not grow on trees. I am a landscape architect, i would know such tree... 😉
                                          • MaracMBundefined
                                            MaracMB @dc42
                                            even with split Z axes, it fails.
                                            G1 H2 Z5 F600
                                            M584 Z5 A6 P7				;split
                                            G1 Z-405 A-405 F900 H1
                                            M584 Z5:6 P6
                                            this is M122 after Z homing fails:
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.02 or later + DueX5
                                            Board ID: 08DGM-9T6BU-FG3SN-6J9F6-3SN6L-KUWVG
                                            Used output buffers: 3 of 24 (24 max)
                                            Static ram: 24028
                                            Dynamic ram: 103532 of which 64 recycled
                                            Exception stack ram used: 560
                                            Never used ram: 2888
                                            Tasks: NETWORK(ready,123) HEAT(blocked,294) DUEX(blocked,36) MAIN(running,451) IDLE(ready,19)
                                            Owned mutexes:
                                            Last reset 00:04:22 ago, cause: software
                                            Last software reset at 2020-11-05 11:22, reason: User, GCodes spinning, available RAM 2880, slot 2
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                            Error status: 0x04
                                            MCU temperature: min 38.3, current 38.6, max 39.1
                                            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: position 0, standstill, SG min/max not available
                                            Driver 1: position 0, standstill, SG min/max not available
                                            Driver 2: position 4800, standstill, SG min/max not available
                                            Driver 3: position 0, standstill, SG min/max not available
                                            Driver 4: position 0, standstill, SG min/max not available
                                            Driver 5: position 0, standstill, SG min/max 0/178
                                            Driver 6: position 0, standstill, SG min/max 0/118
                                            Driver 7: position 0, standstill, SG min/max not available
                                            Driver 8: position 0, standstill, SG min/max not available
                                            Driver 9: position 0, standstill, SG min/max not available
                                            Driver 10: position 0
                                            Driver 11: position 0
                                            Date/time: 2020-11-05 11:27:01
                                            Cache data hit count 412734709
                                            Slowest loop: 17.58ms; fastest: 0.19ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card longest read time 1.3ms, write time 3.1ms, max retries 0
                                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 251856ms
                                            === MainDDARing ===
                                            Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                            === AuxDDARing ===
                                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 201.99ms; fastest: 0.11ms
                                            Responder states: HTTP(2) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                            HTTP sessions: 1 of 8
                                            • WiFi -
                                              Network state is active
                                              Failed messages: pending 0, notready 0, noresp 1
                                              WiFi firmware version 1.24beta2-05b1
                                              WiFi MAC address 84:f3:eb:83:45:0d
                                              WiFi Vcc 3.43, reset reason Power up
                                              WiFi flash size 4194304, free heap 23288
                                              WiFi IP address 192.168.0.125
                                              WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                                              Clock register 00002002
                                              Socket states: 4 2 0 0 0 0 0 0
                                              === DueX ===
                                              Read count 3, 1.85 reads/min
