TMC2209 Sensorless Homing
Yes I plan to add stall detection to the TMC22xx driver.
@dc42 so you plan to also upgrade duet maestro with TMC2209 and provide sensorless homing? I believe there should be and hardware change to the pcb, as the DIAG pin of the driver is not connected to the MCU.
Yes we are planning a Duet Maestro replacement with TMC2209 drivers and other improvements. It's currently at the design stage. It may cost a little more than the existing Maestro.
Please add and wifi support! It would be very much appreciated!
@dc42 said in TMC2209 Sensorless Homing:
Oh boy. This is going to drain my wallet
The absolute killer feature would be swappable drivers, the Duet Wifi is slowly becoming ancient right now and the Duet3 is absolute overkill for many applications and also a very steep entry barrier because of the price And the current 1.5A limit of the Maestro is just a tad too low.
I would love new "mid tier" Duet board for my Delta.
@elektronchika said in TMC2209 Sensorless Homing:
It will come in WiFi and Ethernet versions. At least one of them (probably both) will also support direct connection to a Raspberry Pi.
Cherry on top and a slice of Pi(e) on the side as well? (that answered itself:)
@dc42 is there any time estimation when the boards will be available for purchase?
We've only recently started the detailed design, so it will be several months before they are available.
@dc42 any update on duet Maestro with tmc 2209
@poohzaza said in TMC2209 Sensorless Homing:
see
https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement
