    Constant 'connection interrupted'
    92
    5.1k
      From the usb terminal console can you send M997 S1 and report the results?
      It should show the wifi module flash progress.
      When you lose connection, does the wifi module light go out?
      Can you also test the Duet in Access point mode for a while to see if the module works without disconnections in that mode? That would isolate the problem with the router side.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
      • Fodenundefined
        Foden
        Hi
        Just doing a test print on it. After uploading Duet WiFiServer.bin v1.24 (15 mins ago) I have not had a single dropout - which is 100% better already. Likely the kiss of death I know.....
        Will feedback on your requests shortly. Pretty much 100% guarantee it's not the router side - IT rather than 3D is my thing and I've double checked that side
        Hadn't read the part about putting the Duet into AP mode - what is the benefit/purpose to that feature
        • Fodenundefined
          Foden
          M997 S1 shows that it is erasing the firmware and the counts in 5% increments up to 100% at which point it says Upgrade, or update, complete and the WIFI comes back on
          The drop outs have returned sadly
          Not sure if blue WIFI goes out or not - will need to sit at it and glare at it for awhile on that one
          Update (good timing) - just went to glare at it and it dropped out right away
          No - the WiFi light does not go out when it reports
          Connection interrupted, attempting to reconnect...
          HTTP request timed out
          • Fodenundefined
            Foden
            Setting AP mode 'appears' to work but I don't see the SSID 'DUETTEST'
              The SSID would be duet according to your image.
              • Fodenundefined
                Foden
                Yes, 'DUET' sorry, does not show, which I presume isn't a good sign
                  Does the module light up when in ap mode?
                  Fodenundefined 1 Reply Last reply Reply Quote 0
                  • Fodenundefined
                    Foden @Phaedrux
                    @Phaedrux Yes it does
                      And nothing shows up on your phone or laptop?
                      • Fodenundefined
                        Foden
                        Nothing new at all
                          Could be a failing module. Do you have the means to replace it?
                          • Fodenundefined
                            Foden
                            Not really, would need hot air soldering tool and at least the WIFI module I guess. Not something I've done before, have soldered quite a lot but don't fancy completely frying the board though. Probably have to live with it until it dies and then figure something out. Do you know off-hand if the WIFI module is still either ESP-12S or ESP-07S (from an old dc42 post)
                            • Fodenundefined
                              Foden
                              OMG - I'm sooooo sorry about the AP test. Seems my brain is stuck in DFU mode as I did NOT send M552 S2 to enable the AP SSID. Oddly enough when I do i can see it. I was able to sign into it briefly too
                              • Fodenundefined
                                Foden
                                Able to sign into in on my laptop, but still get drops
                                I noticed in the diagnostics that i do NOT see what I should, I see
                                WiFi Vcc 3.45, reset reason Unknown
                                rather than
                                WiFi Vcc 3.42, reset reason Turned on by main processor
                                • Fodenundefined
                                  Foden
                                  Although there weren't any reported issues with either sd card I reformatted my 32Gb one, 64k clusters and did NOT use the quick option and then copied back the files. Left the Duet off overnight, plugged in the sd card and powered it on and left it alone for an hour - 0 drops - ran a couple of G39's to warm up the MCU and again 0 drops
                                  (forgot to mention Duet is enclosed in a case with a fan for cooling-https://www.thingiverse.com/thing:2812834)
                                  Had more drops now, very few when it's completely idle. Just for shiggles I plugged in a WiFi extender right next to the printer. Once firmware has been updated we'll see if that makes any difference
                                    So it seems like an SD card issue?
                                    • Fodenundefined
                                      Foden @Phaedrux
                                      @Phaedrux Sadly no, even when the printer is idle I get drop outs. I have a Wi-Fi extender 12" away from the Duet, and it's connected to it. Still get drop outs. Connection stats for the Duet to the Wi-Fi extender are -21dbm 53Mbps.
                                      So.... looks like your initial prognosis was correct 😖 Wi-Fi module is fubar'd and on it's way out and needs to be replaced 😞
                                      I will try another, 3rd, SD card to triple check
                                        Just to clarify because I may have missed it in some edits, but were you able to get access point mode working? And were the drops still happening?
                                        If that was the case, then yes, it's likely the module is failing given that your signal strength is good, no other devices in the area are having issues, and it happens even with the router removed from the equation. We've tried reflashing the wifi server and new SD card.
                                        Replacing the wifi module isn't the most difficult process but it's not for beginners either.
                                        Here's an example of it being done with an external antenna version, but it's basically the same.
                                        https://forum.duet3d.com/topic/2825/converting-the-duet-wifi-to-use-an-external-antenna
                                        • Fodenundefined
                                          Foden @Foden
                                          @Foden Same issue with 3 different sd cards, all error checked and formatted FAT32
                                          • Fodenundefined
                                            Foden @Phaedrux
                                            @Phaedrux Yes, was able to get the AP mode working and connected to it, same network drop problem. Will take a look at the link - thanks again
                                            I think this is an indication of an issue "WiFi Vcc 3.45, reset reason Unknown" as it doesn't match the expected output
