    Constant 'connection interrupted'
    92
    4.9k
      The SSID would be duet according to your image.
      • Fodenundefined
        Foden
        Yes, 'DUET' sorry, does not show, which I presume isn't a good sign
          Does the module light up when in ap mode?
          Fodenundefined 1 Reply Last reply Reply Quote 0
          • Fodenundefined
            Foden @Phaedrux
            @Phaedrux Yes it does
              And nothing shows up on your phone or laptop?
              • Fodenundefined
                Foden
                Nothing new at all
                  Could be a failing module. Do you have the means to replace it?
                  • Fodenundefined
                    Foden
                    Not really, would need hot air soldering tool and at least the WIFI module I guess. Not something I've done before, have soldered quite a lot but don't fancy completely frying the board though. Probably have to live with it until it dies and then figure something out. Do you know off-hand if the WIFI module is still either ESP-12S or ESP-07S (from an old dc42 post)
                    • Fodenundefined
                      Foden
                      OMG - I'm sooooo sorry about the AP test. Seems my brain is stuck in DFU mode as I did NOT send M552 S2 to enable the AP SSID. Oddly enough when I do i can see it. I was able to sign into it briefly too
                      • Fodenundefined
                        Foden
                        Able to sign into in on my laptop, but still get drops
                        I noticed in the diagnostics that i do NOT see what I should, I see
                        WiFi Vcc 3.45, reset reason Unknown
                        rather than
                        WiFi Vcc 3.42, reset reason Turned on by main processor
                        • Fodenundefined
                          Foden
                          Although there weren't any reported issues with either sd card I reformatted my 32Gb one, 64k clusters and did NOT use the quick option and then copied back the files. Left the Duet off overnight, plugged in the sd card and powered it on and left it alone for an hour - 0 drops - ran a couple of G39's to warm up the MCU and again 0 drops
                          (forgot to mention Duet is enclosed in a case with a fan for cooling-https://www.thingiverse.com/thing:2812834)
                          Had more drops now, very few when it's completely idle. Just for shiggles I plugged in a WiFi extender right next to the printer. Once firmware has been updated we'll see if that makes any difference
                            So it seems like an SD card issue?
                            • Fodenundefined
                              Foden @Phaedrux
                              @Phaedrux Sadly no, even when the printer is idle I get drop outs. I have a Wi-Fi extender 12" away from the Duet, and it's connected to it. Still get drop outs. Connection stats for the Duet to the Wi-Fi extender are -21dbm 53Mbps.
                              So.... looks like your initial prognosis was correct 😖 Wi-Fi module is fubar'd and on it's way out and needs to be replaced 😞
                              I will try another, 3rd, SD card to triple check
                                Just to clarify because I may have missed it in some edits, but were you able to get access point mode working? And were the drops still happening?
                                If that was the case, then yes, it's likely the module is failing given that your signal strength is good, no other devices in the area are having issues, and it happens even with the router removed from the equation. We've tried reflashing the wifi server and new SD card.
                                Replacing the wifi module isn't the most difficult process but it's not for beginners either.
                                Here's an example of it being done with an external antenna version, but it's basically the same.
                                https://forum.duet3d.com/topic/2825/converting-the-duet-wifi-to-use-an-external-antenna
                                • Fodenundefined
                                  Foden @Foden
                                  @Foden Same issue with 3 different sd cards, all error checked and formatted FAT32
                                  • Fodenundefined
                                    Foden @Phaedrux
                                    @Phaedrux Yes, was able to get the AP mode working and connected to it, same network drop problem. Will take a look at the link - thanks again
                                    I think this is an indication of an issue "WiFi Vcc 3.45, reset reason Unknown" as it doesn't match the expected output
                                    • Fodenundefined
                                      Foden
                                      I left the Wi-Fi extender, for now, blasting into the ear of the DuetWiFi, as I don't see it hurting anything - other than the folks across the street 😁
                                      In desperation, as I don't really want to have to replace the Wi-Fi module - but will if required, I spent the morning redoing everything from scratch, just in case - no change. UNTIL I changed the "Number of maximum AJAX retries" from 3 to 4. No drops in the last 4 hours, for the first 1 1/2hrs I was re-leveling the bed - I mean why not - to see if raising the MCU temp was an issue - seems it was not.
                                      Usual KOD statement, but looks like the issue, possibly symptom only, was AJAX retry # brought about with a recent upgrade to Duet Wi-Fi 3.1.1. Which I had completely overlooked as a possible culprit. I had upgraded it but then not used the HEVO for awhile as I was using my MakerSelect IIIP.
                                      Will see if I get any more connection drop outs now I have tempted fate again
                                      • Fodenundefined
                                        Foden
                                        Last post on this, I know everyone will be pleased
                                        So, indeed it was the KOD - 30 mins ago back to constant drops again. Best get out the hairdryer, solder and BBQ tongs then......
                                        Can you turn the DuetWifi into a DuetEthernet?
                                          Phaedrux Moderator @Foden
                                          @Foden said in Constant 'connection interrupted':
                                          Yes I believe so. Instead of soldering on a replacement module you could install the socket for the ethernet module.
                                          https://www.duet3d.com/DuetAddons/DuetEthernet_Module
                                          • Fodenundefined
                                            Foden
                                            Hmm, OK that's an option then, except for the hole I'd have to put in my case 😞 Oh well
                                            Thanks again Phaedrux
