RRF and Heaters – Duet 2 WIFI 3.1.1
@MJCT said in RRF and Heaters – Duet 2 WIFI 3.1.1:
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C570.5 ; configure sensor 0 as thermistor on pin
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C202.3 ; configure sensor 1 as thermistor on pin e0tempas i told you in the other thread
your thermistor settings are incorrect B4138 is the default but you also specified a c value.
find the correct values in your thermistor documentation -
@Veti said in RRF and Heaters – Duet 2 WIFI 3.1.1:
find the correct values in your thermistor documentationHi there Veti, thanks again for your attention
Can I specify the values that I had previously in my old config in the RRF, so that It automatically generates de heaters code for me?
Should I erase the data from the 0:/sys/config-override.g?
yes you can use those values
And I believe you have to retune your heaters when moving from RRF2 to RRF3 anyway -
What does retune mean exactly?
Tried M303
Got
M303 H1 S265
Error: M303: heater 1 reported error 'sensor open circuit' at start of auto tuning -
That means you have issues with your thermistor.
What is showing in DWC? -
@jay_s_uk said in RRF and Heaters – Duet 2 WIFI 3.1.1:
What is showing in DWC?Both my thermistors where working perfectly before the update and I didn’t touched the wirings so…..
By DWC you mean this? (Sorry I'm just an end user)
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
Used output buffers: 3 of 24 (20 max)
Static ram: 27980
Dynamic ram: 93884 of which 60 recycled
Exception stack ram used: 304
Never used ram: 8844
Tasks: NETWORK(ready,332) HEAT(blocked,504) MAIN(running,1848) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:21:01 ago, cause: power up
Last software reset at 2020-11-12 16:16, reason: User, spinning module GCodes, available RAM 8596 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 46.4, current 48.2, max 48.6
Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-11-13 10:18:09
Cache data hit count 2059511898
Slowest loop: 7.28ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.7ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 42.97ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:01:d4:c6
WiFi Vcc 3.38, reset reason Unknown
WiFi flash size 4194304, free heap 21384
WiFi IP address 192.168.10.62
WiFi signal strength -52dBm, reconnections 0, sleep mode modem
- WiFi -
Can't see anything wrong with what you have in your config. (assuming you made the changes to the M308 we discussed earlier)
If you sendM98 P"config.g"
What comes up?
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
Manually I did this
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C202.3 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ;No luck
no you can not. they will lead to the result you are seeing.
delete C570.5 and C202.3
@Veti What do I put in place?
nothing
@Veti like this?
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ; -
@MJCT
yes -
@Veti Yes!!!!
Now, two questions
Why didn’t the RRF created a M140 and M143 codes for the H1 (I did it manually)?
Can (should) I run a new M307 for each thermistors? If so, do I need to erase 0:/sys/config-override.g or should I just leave it alone? -
@MJCT run M303 for each heater.
Once complete run M500 and it will over write the values in config-override -
i think there is a bug regarding this in the configurator
yes its required on rrf3 (at least for the bed)
currently its not used because there is not M501 in your config.g
this also means you can not save values with M500 -
@Veti Sorry , I meant to say M303 not M307
