    RRF and Heaters – Duet 2 WIFI 3.1.1
    1.7k
      jay_s_uk
      yes you can use those values
      And I believe you have to retune your heaters when moving from RRF2 to RRF3 anyway
      • MJCTundefined
        MJCT
        What does retune mean exactly?
        • MJCTundefined
          MJCT
          Tried M303
          Got
          M303 H1 S265
          Error: M303: heater 1 reported error 'sensor open circuit' at start of auto tuning
            jay_s_uk
            That means you have issues with your thermistor.
            What is showing in DWC?
            MJCTundefined 1 Reply Last reply Reply Quote 0
            • MJCTundefined
              MJCT @jay_s_uk
              @jay_s_uk said in RRF and Heaters – Duet 2 WIFI 3.1.1:
              Both my thermistors where working perfectly before the update and I didn’t touched the wirings so…..
              By DWC you mean this? (Sorry I'm just an end user)
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
              Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
              Used output buffers: 3 of 24 (20 max)
              Static ram: 27980
              Dynamic ram: 93884 of which 60 recycled
              Exception stack ram used: 304
              Never used ram: 8844
              Tasks: NETWORK(ready,332) HEAT(blocked,504) MAIN(running,1848) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:21:01 ago, cause: power up
              Last software reset at 2020-11-12 16:16, reason: User, spinning module GCodes, available RAM 8596 bytes (slot 0)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 46.4, current 48.2, max 48.6
              Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
              Date/time: 2020-11-13 10:18:09
              Cache data hit count 2059511898
              Slowest loop: 7.28ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.7ms, write time 0.0ms, max retries 0
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
              === MainDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 42.97ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.23
                WiFi MAC address ec:fa:bc:01:d4:c6
                WiFi Vcc 3.38, reset reason Unknown
                WiFi flash size 4194304, free heap 21384
                WiFi IP address 192.168.10.62
                WiFi signal strength -52dBm, reconnections 0, sleep mode modem
                jay_s_uk
                Can't see anything wrong with what you have in your config. (assuming you made the changes to the M308 we discussed earlier)
                If you send
                M98 P"config.g"
                What comes up?
                • MJCTundefined
                  MJCT
                  M98 P"config.g"
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  • MJCTundefined
                    MJCT
                    Manually I did this
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
                    M143 H0 S110 ; set temperature limit for heater 0 to 110C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C202.3 ; configure sensor 1 as thermistor on pin e0temp
                    M140 H1 ;
                    M143 H1 S290 ;
                    No luck
                    • MJCTundefined
                      MJCT
                      • Vetiundefined
                        Veti @jay_s_uk
                        no you can not. they will lead to the result you are seeing.
                        @MJCT
                        delete C570.5 and C202.3
                        • MJCTundefined
                          MJCT @Veti
                          @Veti What do I put in place?
                          • Vetiundefined
                            Veti @MJCT
                            @MJCT
                            nothing
                            MJCTundefined 1 Reply Last reply Reply Quote 1
                            • MJCTundefined
                              MJCT @Veti
                              @Veti like this?
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                              M140 H1 ;
                              M143 H1 S290 ;
                              • Vetiundefined
                                Veti @MJCT
                                @MJCT
                                yes
                                MJCTundefined 1 Reply Last reply Reply Quote 2
                                • MJCTundefined
                                  MJCT @Veti
                                  @Veti Yes!!!!
                                  Now, two questions
                                  Why didn’t the RRF created a M140 and M143 codes for the H1 (I did it manually)?
                                  Can (should) I run a new M307 for each thermistors? If so, do I need to erase 0:/sys/config-override.g or should I just leave it alone?
                                  jay_s_ukundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                    jay_s_uk @MJCT
                                    @MJCT run M303 for each heater.
                                    Once complete run M500 and it will over write the values in config-override
                                    • Vetiundefined
                                      Veti @MJCT
                                      @MJCT said in RRF and Heaters – Duet 2 WIFI 3.1.1:
                                      i think there is a bug regarding this in the configurator
                                      yes its required on rrf3 (at least for the bed)
                                      currently its not used because there is not M501 in your config.g
                                      this also means you can not save values with M500
                                      • MJCTundefined
                                        MJCT @Veti
                                        @Veti Sorry , I meant to say M303 not M307
                                        • Vetiundefined
                                          Veti @MJCT
                                          @MJCT
                                          yes you run M303 and put the values into the config with M307.
                                          i understood what you meant.
                                          • MJCTundefined
                                            MJCT @Veti
                                            @Veti After both tests and M500's got this
                                            ; config-override.g file generated in response to M500 at 2020-11-13 11:54
                                            ; Heater model parameters
                                            M307 H0 A135.2 C635.5 D0.6 S1.00 V23.6 B0
                                            M307 H1 A600.5 C163.9 D10.4 S1.00 V24.0 B0
                                            ; Workplace coordinates
                                            G10 L2 P1 X0.00 Y0.00 Z0.00
                                            G10 L2 P2 X0.00 Y0.00 Z0.00
                                            G10 L2 P3 X0.00 Y0.00 Z0.00
                                            G10 L2 P4 X0.00 Y0.00 Z0.00
                                            G10 L2 P5 X0.00 Y0.00 Z0.00
                                            G10 L2 P6 X0.00 Y0.00 Z0.00
                                            G10 L2 P7 X0.00 Y0.00 Z0.00
                                            G10 L2 P8 X0.00 Y0.00 Z0.00
                                            G10 L2 P9 X0.00 Y0.00 Z0.00
                                            do I need to add any M501 at config-override or at config.g?
