RRF and Heaters – Duet 2 WIFI 3.1.1
Can't see anything wrong with what you have in your config. (assuming you made the changes to the M308 we discussed earlier)
If you sendM98 P"config.g"
What comes up?
@jay_s_uk said in RRF and Heaters – Duet 2 WIFI 3.1.1:
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
Manually I did this
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C202.3 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ;No luck
yes you can use those values
no you can not. they will lead to the result you are seeing.
delete C570.5 and C202.3
@Veti What do I put in place?
nothing
@Veti like this?
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ; -
@MJCT
yes -
@Veti Yes!!!!
Now, two questions
Why didn’t the RRF created a M140 and M143 codes for the H1 (I did it manually)?
Can (should) I run a new M307 for each thermistors? If so, do I need to erase 0:/sys/config-override.g or should I just leave it alone? -
@MJCT run M303 for each heater.
Once complete run M500 and it will over write the values in config-override -
@MJCT said in RRF and Heaters – Duet 2 WIFI 3.1.1:
i think there is a bug regarding this in the configurator
yes its required on rrf3 (at least for the bed)
currently its not used because there is not M501 in your config.g
this also means you can not save values with M500 -
@Veti Sorry , I meant to say M303 not M307
yes you run M303 and put the values into the config with M307.
i understood what you meant. -
@Veti After both tests and M500's got this
; config-override.g file generated in response to M500 at 2020-11-13 11:54
; Heater model parameters
M307 H0 A135.2 C635.5 D0.6 S1.00 V23.6 B0
M307 H1 A600.5 C163.9 D10.4 S1.00 V24.0 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00do I need to add any M501 at config-override or at config.g?
at the end of config.g
@Veti Just like this?
M501 -
thats you config-overwrite not your config
@Veti Sorry
M140 H1 ; map heated bed to heater 0
M143 H1 S290 ; set temperature limit for heater 0 to 110C; Fans
M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
T0 ; select first tool
M501 -
@MJCT
yes
