Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
7.2k
    shatty
    Just wired up the Duet 2 Wifi. I just went thru the config wizard online. I am very unsure on what I did. I have an Ender 5 Plus with the Micro Swiss all metal direct drive setup. Thats the only mod I have so far. I need someone that is familiar with an Ender 5 Plus and obviously the software to look at my config.g and whatever else. I am scared to power on the board and possibly blow up my living room. I need someone to dedicate 30 min or so to go over everything with me before I turn it on. The E5+ comes with the BL Touch. Using 3.11 FW. Also have a Paneldue 5i. Please PM me if interested. You will be compensated for your time!!!
    ? undefined 2 Replies Last reply 14 Nov 2020, 17:12 Reply Quote 0
      Veti
      there is a guide for the ender 3 pro
      the ender 5 pro is close enough that most of the guide still applies
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
      the duet wifi uses R4700 for the thermistor instead of R2200
      undefined 2 Replies Last reply 14 Nov 2020, 06:31 Reply Quote 0
        shatty @Veti
        @Veti Wiring is done. I don't want to guess anymore. I just want someone to check it over and help me with issues I might have in the beginning. Its a 5 Plus.....not pro....Plus is 350x350x400.
        undefined 1 Reply Last reply 14 Nov 2020, 06:36 Reply Quote 0
          shatty @Veti
          @Veti I dont know what R4700 or R2200 is.
            Veti @shatty
            @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
            still a cartesian printer and just a bit bigger than the pro.
            post some photos of the wiring and your config.g
              shatty
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Nov 14 2020 01:05:16 GMT-0500 (Eastern Standard Time)
              M550 P"E5Plus" ; set printer name
              M551 P"xxxxx" ; set password
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z400.00 E130.00 ; set steps per mm
              M84 S30 ; Set idle timeout
              M208 X350 Y350 Z400 S0 ; set axis maxima
              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
              M558 P9 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              M143 H0 S110 ; set temperature limit for heater 0 to 110C
              M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
              undefined 1 Reply Last reply 14 Nov 2020, 06:54 Reply Quote 0
                shatty
                  shatty
                  Also, what do you think about putting little heatsinks on the driver chips like the stock board has?
                    Veti @shatty
                    zprobe in does not normally need to be inverted for the bltouch.
                    the offset x and y is missing
                    Then Beta value is incorrect, try the beta value from the guide, as creality tends to use the same thermistors
                    you configured both fans to be Thermostatic controled. this way you have no part cooling fan that can be controlled.
                    also add a T0 to the end of your config.
                    do you have the motor specs for the ender 5 plus?
                    but you could test these values and check the motor temperature by hand during printing.
                    you might want to increase E800 to E900 as in the guide
                    checking the marlin example config for the ender 5 plus
                    https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Creality/Ender-5 Plus/Configuration.h
                    #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 800, 93.02 }
                    it seems you need Z800
                    undefined 2 Replies Last reply 14 Nov 2020, 06:57 Reply Quote 1
                      Have you ever powered on the board with USB or anything yet?
                      Part 3 of the guide veti linked above goes over initial commissioning. Moving motors safely to test, that sort of thing. Try taking a look at that.
                      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                      The duet is pretty hard to kill, but there are a few wiring things you should absolutely double check.
                      First is your motor phase pairings. Failure to get the pairs right would probably just lead to an error message and the motors not working, but it could also damage the drivers, so best to get it sorted first. Here's how.
                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                      Second is the fan polarity. Positive and negative must be the right way round or you're likely to damage the fan or the fan mosfet on the board or both, so make sure you've got that sorted out before testing the fans.
                      undefined 1 Reply Last reply 14 Nov 2020, 06:56 Reply Quote 0
                        shatty @Phaedrux
                        @Phaedrux said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                        Yes
                          shatty @Veti
                          @Veti
                          https://www.amazon.com/Aibecy-Creality-Stepping-Accessory-Replacement/dp/B07MVTFL3R/ref=sr_1_1_sspa?dchild=1&keywords=creality+stepper+motor&qid=1605337045&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzUjk2ME9MS0RHTTZJJmVuY3J5cHRlZElkPUEwMTk3MDI4MlRHWlVWQks3QU9ESyZlbmNyeXB0ZWRBZElkPUEwNjcyNDU0WjhHMEo4NEtaM1JVJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
                            shatty @Veti
                            @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                            I will go back in the configurator and post my fixes. Thanks! Most of what u said is chinese to me but I will do some googling and try
                            undefined 1 Reply Last reply 14 Nov 2020, 07:03 Reply Quote 0
                              shatty
                              None of these values will autopopulate after I turn it on and auto homes itself and tests itself out?
                                Veti @shatty
                                @shatty
                                which part did you not understand? please be specific, then we can further elaborate.
                                no.
                                undefined 1 Reply Last reply 15 Nov 2020, 08:49 Reply Quote 0
                                  A Former User @shatty
                                  @shatty
                                  Did you ever learn how to ride a bicycle?
                                  If so do you remember the leap of faith you had to make without the safety net of training wheels?
                                  Follow the steps to get the printer running, check your wiring multiple times, and trust yourself and take the leap, and flip the switch.
                                  undefined 1 Reply Last reply 15 Nov 2020, 07:48 Reply Quote 2
                                    shatty @A Former User
                                    @CaLviNx said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                                    @shatty
                                    LOL. I didnt think it would be this complicated before I installed it. I thought it would be a quick swap. Anyways theres no turning back now.
                                      shatty @Veti
                                      @Veti Hows this?
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
                                      M569 P2 S0 ; physical drive 2 goes backwards
                                      M92 X80.00 Y80.00 Z400.00 E412.60 ; set steps per mm
                                      M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                      M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:190 Y15:190 S20 ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 0 as thermistor on pin bedtemp
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 1 as thermistor on pin e0temp
                                      M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                                      I dont see where the Heater for the hot end should max at 280. Also there are 2 fans on the hot end. Shouldnt the values be identical? I got a lot of the fixes from someones 5 Pro config
                                      undefined 1 Reply Last reply 15 Nov 2020, 17:05 Reply Quote 0
                                        Phaedrux Moderator @shatty
                                        Add M143 H1 S280 at the end of the heater block under the M307.
                                        Otherwise I don't see any obvious issues.
                                        You can send M98 P"config.g" in the console to see if there are any syntax errors.
                                        Otherwise it's time to do some testing.
                                          Veti
                                          as i posted earlier the Z steps according to marlin are Z800
                                          delete the C4700 thats not the resistance. you can leave R empty and the correct default is choosen.
                                          7 out of 141
