    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.3k
    • Vetiundefined
      Veti @shatty
      @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
      M558 P9 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      zprobe in does not normally need to be inverted for the bltouch.
      the offset x and y is missing
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin
      Then Beta value is incorrect, try the beta value from the guide, as creality tends to use the same thermistors
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      you configured both fans to be Thermostatic controled. this way you have no part cooling fan that can be controlled.
      also add a T0 to the end of your config.
      do you have the motor specs for the ender 5 plus?
      but you could test these values and check the motor temperature by hand during printing.
      you might want to increase E800 to E900 as in the guide
      M92 X80.00 Y80.00 Z400.00 E130.00 ; set steps per mm
      checking the marlin example config for the ender 5 plus
      https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Creality/Ender-5 Plus/Configuration.h
      #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 800, 93.02 }
      it seems you need Z800
      shattyundefined 2 Replies Last reply Reply Quote 1
        Have you ever powered on the board with USB or anything yet?
        Part 3 of the guide veti linked above goes over initial commissioning. Moving motors safely to test, that sort of thing. Try taking a look at that.
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
        The duet is pretty hard to kill, but there are a few wiring things you should absolutely double check.
        First is your motor phase pairings. Failure to get the pairs right would probably just lead to an error message and the motors not working, but it could also damage the drivers, so best to get it sorted first. Here's how.
        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
        Second is the fan polarity. Positive and negative must be the right way round or you're likely to damage the fan or the fan mosfet on the board or both, so make sure you've got that sorted out before testing the fans.
        shattyundefined 1 Reply Last reply Reply Quote 0
        • shattyundefined
          shatty @Phaedrux
          @Phaedrux said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
          Yes
          • shattyundefined
            shatty @Veti
            @Veti
            https://www.amazon.com/Aibecy-Creality-Stepping-Accessory-Replacement/dp/B07MVTFL3R/ref=sr_1_1_sspa?dchild=1&keywords=creality+stepper+motor&qid=1605337045&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzUjk2ME9MS0RHTTZJJmVuY3J5cHRlZElkPUEwMTk3MDI4MlRHWlVWQks3QU9ESyZlbmNyeXB0ZWRBZElkPUEwNjcyNDU0WjhHMEo4NEtaM1JVJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
            • shattyundefined
              shatty @Veti
              @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
              I will go back in the configurator and post my fixes. Thanks! Most of what u said is chinese to me but I will do some googling and try
              • shattyundefined
                shatty
                None of these values will autopopulate after I turn it on and auto homes itself and tests itself out?
                • Vetiundefined
                  Veti @shatty
                  @shatty
                  which part did you not understand? please be specific, then we can further elaborate.
                  no.
                    A Former User @shatty
                    @shatty
                    Did you ever learn how to ride a bicycle?
                    If so do you remember the leap of faith you had to make without the safety net of training wheels?
                    Follow the steps to get the printer running, check your wiring multiple times, and trust yourself and take the leap, and flip the switch.
                    shattyundefined 1 Reply Last reply Reply Quote 2
                    • shattyundefined
                      shatty @A Former User
                      @CaLviNx said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                      @shatty
                      LOL. I didnt think it would be this complicated before I installed it. I thought it would be a quick swap. Anyways theres no turning back now.
                      • shattyundefined
                        shatty @Veti
                        @Veti Hows this?
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
                        M550 P"E5Plus" ; set printer name
                        M551 P"xxxxx" ; set password
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P2 S0 ; physical drive 2 goes backwards
                        M92 X80.00 Y80.00 Z400.00 E412.60 ; set steps per mm
                        M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                        M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X350 Y350 Z400 S0 ; set axis maxima
                        M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                        M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
                        M557 X15:190 Y15:190 S20 ; define mesh grid
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 0 as thermistor on pin bedtemp
                        M143 H0 S110 ; set temperature limit for heater 0 to 110C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 1 as thermistor on pin e0temp
                        M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                        I dont see where the Heater for the hot end should max at 280. Also there are 2 fans on the hot end. Shouldnt the values be identical? I got a lot of the fixes from someones 5 Pro config
                          Phaedrux Moderator @shatty
                          Add M143 H1 S280 at the end of the heater block under the M307.
                          Otherwise I don't see any obvious issues.
                          You can send M98 P"config.g" in the console to see if there are any syntax errors.
                          Otherwise it's time to do some testing.
                          • Vetiundefined
                            Veti
                            as i posted earlier the Z steps according to marlin are Z800
                            delete the C4700 thats not the resistance. you can leave R empty and the correct default is choosen.
                            • shattyundefined
                              shatty
                              M143 H1 S280
                              OK so I edited and turned on.
                              Seems ok. Temps are hovering at 22 deg C with heaters off.
                              Motors are F'ed up. Z looks good. Its the X and Y. I got some error codes.
                              11/16/2020, 1:18:45 AM M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                              Board ID: 08DLM-996RU-N8PS0-6J1DJ-3SD6K-KSSHN
                              Used output buffers: 3 of 24 (11 max)
                              Static ram: 27980
                              Dynamic ram: 93672 of which 44 recycled
                              Exception stack ram used: 264
                              Never used ram: 9112
                              Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:04:52 ago, cause: software
                              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8240 bytes (slot 1)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                              Error status: 0
                              MCU temperature: min 24.7, current 25.6, max 26.1
                              Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Date/time: 2020-11-16 01:18:41
                              Cache data hit count 507426640
                              Slowest loop: 6.91ms; fastest: 0.12ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 3.8ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 15.88ms; fastest: 0.00ms
                              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is active
                                WiFi firmware version 1.23
                                WiFi MAC address f4:cf:a2:66:99:4f
                                WiFi Vcc 3.38, reset reason Unknown
                                WiFi flash size 4194304, free heap 23640
                                WiFi IP address 192.168.2.8
                                WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                                11/16/2020, 1:17:30 AM M120 G91 G1 X-1 F6000 G90 M121
                                Error: G0/G1: insufficient axes homed
                                11/16/2020, 1:14:17 AM Connection established
                                11/16/2020, 1:13:42 AM Connection interrupted, attempting to reconnect...
                                11/16/2020, 1:13:32 AM Emergency Stop! Reset the controller to continue.
                                11/16/2020, 1:13:32 AM Emergency stop, attemping to reconnect...
                                11/16/2020, 1:13:31 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                                11/16/2020, 1:13:26 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                                11/16/2020, 1:13:22 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                                11/16/2020, 1:13:17 AM Warning: motor phase B may be disconnected reported by driver(s) 0 1 2
                                11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                                11/16/2020, 1:13:07 AM Connection established
                                11/16/2020, 1:12:52 AM Connection interrupted, attempting to reconnect...
                                HTTP request timed out
                                11/16/2020, 1:12:40 AM Upload of config.g successful after 0s
                                11/16/2020, 1:07:50 AM Connected to 192.168.2.8
                              Vetiundefined 2 Replies Last reply Reply Quote 0
                              • shattyundefined
                                shatty
                                M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                M143 H1 S280 ; 280 deg max on hot end
                                • shattyundefined
                                  shatty
                                  M98 P"config.g"
                                  11/16/2020, 1:23:54 AM M98 P"config.g"
                                  HTTP is enabled on port 80
                                  FTP is disabled
                                  TELNET is disabled
                                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                  I have that little daughter board connected for the bed heat. Looks like a relay board. Bed heat output on D3D connects to smaller board. Looks like the bed heat output triggers that smaller board. But if you think I should connect the bed straight to bed out on D3D I will
                                  • Vetiundefined
                                    Veti @shatty
                                    this indicates that your wiring of the phases are incorrect.
                                    see
                                    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
                                    shattyundefined 2 Replies Last reply Reply Quote 0
                                    • shattyundefined
                                      shatty @Veti
                                      see
                                      I triple checked them. I compared from the stock board to the D3D. I will check again
                                      • shattyundefined
                                        shatty @Veti
                                        @Veti
                                        so just Extruder,x and y? And just the B phase?
                                          As it's only one phase of each driver that's reported as disconnected, a likely cause is a bad crimp connection.
                                          • Vetiundefined
                                            Veti @shatty
                                            @shatty
                                            M584 X0 Y1 Z2
                                            x y z, presumably you have not moved the extruder.
                                            the stock board config does not matter, as each board has different layouts.
                                            did you follow the guide to find the phases of the motors?
