    Pucking up plastic with my nozzle.
    759
    • ziggymanpopoundefined
      ziggymanpopo
      Mosquito hotend and bmg-m dd extuder
        ziggymanpopo
        Is it possable my fanduct is Some how involved??
          ziggymanpopo
          This post is deleted!
            ziggymanpopo
              ziggymanpopo
              ![0_1605401214632_16054011707117591609653755072099.jpg](Uploading 100%)
              • fcwiltundefined
                fcwilt
                PLA with additives, like your gold PLA, cause problems with all-metal hotends like the M.
                Try, as an experiment, setting your retraction to 0.
                  ziggymanpopo
                  I had an microseiss it didnt do it but ill take your word for it. So the pla isnt the issue its the plastic on the nozzle . I know it has somthing to do with. The pla because it doesnt do it with other filaments?? I mentioned the pla be ause it mught give someone an idea whats going on its one minor
                  Left out item .... i think ????
                    ziggymanpopo
                    its the small bits left on the print wher they dont belong there..![0_1605401972780_16054019487955853668630931210140.jpg](Uploading 100%) )the nozzle.pickes up the peices untill its covered all the way to the thereads of the nozzle 😳😳 no clue on why
                    • mrehorstdmdundefined
                      mrehorstdmd @ziggymanpopo
                      @ziggymanpopo covered all the way to the threads sounds suspicious. Are you certain that the nozzle is screwed tightly to the heater block? If not, plastic can leak from the threads because of the pressure inside the hot-end.
                        ziggymanpopo
                        yes im sure that was my fist thought too
                          ziggymanpopo
                          Ive also spent.hours watching it.slowly build up from the tip of the nozzle
                          • jens55undefined
                            jens55
                            PETG is well known to collet nozzle crap that way. PLA has much less of an issue that way.
                            Sorry, I haven't got an answer/suggestion for you.
                              ziggymanpopo
                              don't be the suggestion is appriciated,, it's try somthing else besides pteg,good call,, its just that i tried pla and was told it doesnt like all metal hotends W/additives
                              fact being with a high end hot end i should be able to run it no problem and my microswiss ate anything i gave it... that was my thought...ive even ran petg on my anycubic that cost 200$
                              so I'm pretty sure that it's a setting or a combo of settings hate being a newbie 😅 😄 lmao... im close to being able to tune this stuff to this degree
                                mrehorstdmd
                                I've had problems with PETG building up on the nozzle. I have largely eliminated the problems by 1) reducing extrusion to 95% and 2) eliminating lift on retract. I also recently bought some filament that seems better than stuff I was previously using, but it could be that the other changes had more effect than switching filament brands.
                                jens55undefined 1 Reply Last reply Reply Quote 1
                                • jens55undefined
                                  jens55 @mrehorstdmd
                                  @mrehorstdmd , those are the two things that I find necessary for PETG as well but I don't do them for PLA.
                                    ziggymanpopo
                                    Thanks im gonna try some of the suggestions here and i ll leave this poast open.
                                    I would like to add that i have not set all the g code parameters so there could also be an issue with things likenjerk p a or other things i woupd not know ???? Any input is appreciated. thanks all
                                      ziggymanpopo
                                      Had a thought
                                      Could i be pulling filament up before it cools because of too high of retractions... i had it sat at
                                      1.5 mm????
                                        ziggymanpopo
                                        For refreance the 95% extrution solved most of the gunk on the nozzle thanks for the input guys 👍
