    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • lui2004undefined
      lui2004
      Thanks for All your Help this forum is super 1a πŸ˜‰
      Another to Double the steps is for x16 is it more accurate for extruder to make x128 ?
      Thanks a lot
        Phaedrux Moderator @lui2004
        @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
        In some very specific cases where there is very small amounts of extrusion it can help, but in normal cases, no. Stick with x16 and interpolation. Using a 0.9 degree motor and a geared extruder should already get you up to around 800 steps per mm which is a lot of resolution without even changing microsteps which aren't as accurate anyway.
        lui2004undefined 1 Reply Last reply Reply Quote 0
        • lui2004undefined
          lui2004 @Phaedrux
          @Phaedrux my E-Steps is : E137.78 and for the new Steper that i order the E-Step is Double also 275.56, make somthing wrong ? you wrote somthing about 800 steps πŸ˜•
          • Vetiundefined
            Veti
            800 steps are for 0.9 + bmg extruder.
            i would suggest that you start with x16.
            print a benchy
            change to x128 and print the same benchy with the same filament and same settings.
            compare the print and decide for yourself if the print quality has increased.
              it was just an example, sorry for the confusion.
              For what it's worth, I use x64 microstepping on my Ender 3 to get the steps per mm up a bit on the stock extruder.
              • lui2004undefined
                lui2004 @Phaedrux
                @Phaedrux no problem
                I have mount today the New stepper and the prints looks a lot better. 😊
                I got a free runout filament sensor and i have connect it on E0 stop but i dont know how to make the M591 for RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
                Ps: i got it i must switch the Red and Black wire
                Thanks
                  See here https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors and here https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                  • lui2004undefined
                    lui2004
                    ok thanks i have install it with success !
                    i connected on E0_stop and insert M591 in my config like this:
                    ;Filament Sensors
                    M591 D0 P2 C"!e0_stop" S1 ;Extruder 1(0)
                    • lui2004undefined
                      lui2004
                      Last question 😁
                      I want convert the x axis with linear rails mgn12 bit i dont found nothing for mounting for micro swiss direct drive, anyone habe a link to stl file?
                      Thanks in advance πŸ‘πŸΌ
                      • Vetiundefined
                        Veti @lui2004
                        @lui2004
                        https://printermods.com/products/direct-drive-mod-for-creality-ender-3-cr-10
                        lui2004undefined 1 Reply Last reply Reply Quote 1
                        • lui2004undefined
                          lui2004 @Veti
                          @Veti
                          after i have changed the steppermotor this is my first benchy
                          i have a lot of stringing
                          my benchy:
                          this are my Simplify3D settings:
                          and my config.g
                          ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                          G90                                      ; Send absolute coordinates...
                          M83                                      ; ...but relative extruder moves
                          M550 P"Ender 5"                          ; Set machine name
                          M552 S1                                  ; Enable network
                          M586 P0 S1                               ; Enable HTTP
                          M586 P1 S0                               ; Disable FTP
                          M586 P2 S0                               ; Disable Telnet
                          M569 P0 S1                               ; Physical drive 0 goes forwards
                          M569 P1 S1                               ; Physical drive 1 goes forwards
                          M569 P2 S0                               ; Physical drive 2 goes backwards
                          M569 P3 S1                              ; Physical drive 3 goes forwards
                          M584 X0 Y1 Z2 E3                               ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                          M92 X80.00 Y80.00 Z800.00 E278.17             ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
                          M203 X15000.00 Y15000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                  ; Set idle timeout
                          M208 X0 Y0 Z0 S1                         ; Set axis minima
                          M208 X220 Y220 Z300 S0                   ; Set axis maxima
                          M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                          M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                          M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                          ;Filament Sensors
                          M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                          M558 P9 C"^zprobe.in" H3 F60 T6000 A10 R0.75 S0.003            ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X41.2 Y4.5 Z1.785                   ; set Z probe trigger value, offset and trigger height
                          M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
                          M671 X28.8:198.8:198:28.8 Y24:24:194:194
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                        ; map heated bed to heater 0
                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                          M143 H1 S300 								   ; set temperature limit for heater 1 to 300C
                          M307 H1 B0 S1.00
                          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 H1                            ; Define tool 0 S3D
                          ;M563 P0 D0 H1 F0							; FΓΌr Prusa Slicer
                          G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                          G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                          M572 D0 S0.15 ; Pressure Advance
                          M501
                          • Vetiundefined
                            Veti
                            increase the retraction distance until the stringing stops
                            • lui2004undefined
                              lui2004
                              The retraction speed is ok ?
                              In the manual of micro swiss direct drive os wrotten maximum distance 1.5 and max speed 35 ,can i go higher without Problems?
                              • Vetiundefined
                                Veti
                                print this
                                https://www.thingiverse.com/thing:2563909
                                until you get no stringing.
                                stay with that retraction speed for now
                                • lui2004undefined
                                  lui2004 @Veti
                                  @Veti which max distance i should 2.0 or 2.5 ?
                                  • Vetiundefined
                                    Veti @lui2004
                                    @lui2004
                                    go up in 0.25 increments until the stringing stops
                                    • lui2004undefined
                                      lui2004
                                      ok mate thanks
                                      i still print the restraction stl
                                      • lui2004undefined
                                        lui2004 @Veti
                                        @Veti i am now retraction distance of 3,5mm at stringing is always on prints
                                        is 3.5mm to much for direct drive ?
                                        • Vetiundefined
                                          Veti @lui2004
                                          @lui2004
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                                          did you change the thermistor when you switched to the micro swiss?
                                          Are you sure B3950 is correct?
                                          lui2004undefined 2 Replies Last reply Reply Quote 0
                                          • lui2004undefined
                                            lui2004 @Veti
                                            @Veti yes i have changed it like in the docu like this:
                                            i have changed only the bed its a silicon bed with 100k NTC3950
                                            M307 H1 B0 S1.00
