    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.6k
    • lord binkyundefined
      lord binky
      I'd pick at least a 0.9 degree step angle (400 steps / revolution) motor an for ungeared extruder. I'm fiddling with an E3D titan still trying to make the pancake motor work because I punish myself, spent a couple hours tweaking the extruder just yesterday to get it to stop skipping steps at just 3mm/s (tested without the nozzle crosses fingers). For an ungeared extruder though I'd probably just go with a Wantai 42BYGHM810 if I want some snappy retracts and didn't consider effects of weight on ringing.
      • lui2004undefined
        lui2004
        Hi
        i have this Steppermotors here,are they good enough as Extruder motor ?
        https://www.omc-stepperonline.com/nema-17-bipolar-45ncm-64oz-in-2a-42x42x40mm-4-wires-w-1m-cable-and-connector.html
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • engikeneerundefined
          engikeneer @lui2004
          @lui2004 Yeah that one looks to have a bit more beef to it! 2.0A & 45Ncm torque vs your pancake motor with 1.0A & 13Ncm (if I trust my German & that Amazon datasheet..). It may be more than you need, and will be noticeably bigger/heavier, but if you can fit it in and don't worry too much about printing at very high speeds, you should be fine.
          Having said that, I would agree with @lord-binky that a 0.9deg stepper would likely be better as it will give you more resolution. TBH there aren't any ones that jump out at me on OMC. Maybe try Farnell or Digikey? TBH I generally just go for the E3D ones (https://e3d-online.com/collections/motors/products/motors) The 'Compact but Powerful' is probably about what you want?
          Have you read this page?
          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
          i3 clone with a bunch of mods
          lui2004undefined 1 Reply Last reply Reply Quote 0
          • lui2004undefined
            lui2004 @engikeneer
            @engikeneer ok i have order the e3d compact but Powerfull.
            Somthing i must change with this Motor in duet config ?
            Thanks
            • Vetiundefined
              Veti
              your extruder motor is a 1A motor and you are running it at 1100ma. it will get very hot.
              but that motor is not powerful enough for an ungeared extruder.
              i use the exact same motor on my ender 3, but with a bmg extruder.
              and this mount
              https://www.thingiverse.com/thing:3354741
              and its working very well.
              • lui2004undefined
                lui2004 @Veti
                @Veti yeah it looks interessting.
                The old Motor habe 1.8 and the New one have 0.9 die i change somthing on duet for the New motor ?
                • Vetiundefined
                  Veti @lui2004
                  @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
                  yes, double the e steps
                    lord binky
                    You'll want to change the motor current to something like 1.4A to start with for that one (M906 E1400) and E-steps in the config (M92 Exxx), doubling what you have will get you in the ballpark. If you don't want to fiddle with the extrusion factor often you will want to fine tune your extruder after the change to dial in the exact steps per mm. (ex: Triffid's E-steps fine tune) since it'll change your flow rate.
                    • lui2004undefined
                      lui2004
                      Thanks for All your Help this forum is super 1a 😉
                      Another to Double the steps is for x16 is it more accurate for extruder to make x128 ?
                      Thanks a lot
                        Phaedrux Moderator @lui2004
                        In some very specific cases where there is very small amounts of extrusion it can help, but in normal cases, no. Stick with x16 and interpolation. Using a 0.9 degree motor and a geared extruder should already get you up to around 800 steps per mm which is a lot of resolution without even changing microsteps which aren't as accurate anyway.
                        • lui2004undefined
                          lui2004 @Phaedrux
                          @Phaedrux my E-Steps is : E137.78 and for the new Steper that i order the E-Step is Double also 275.56, make somthing wrong ? you wrote somthing about 800 steps 😕
                          • Vetiundefined
                            Veti
                            800 steps are for 0.9 + bmg extruder.
                            i would suggest that you start with x16.
                            print a benchy
                            change to x128 and print the same benchy with the same filament and same settings.
                            compare the print and decide for yourself if the print quality has increased.
                              it was just an example, sorry for the confusion.
                              For what it's worth, I use x64 microstepping on my Ender 3 to get the steps per mm up a bit on the stock extruder.
                              • lui2004undefined
                                lui2004 @Phaedrux
                                @Phaedrux no problem
                                I have mount today the New stepper and the prints looks a lot better. 😊
                                I got a free runout filament sensor and i have connect it on E0 stop but i dont know how to make the M591 for RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
                                Ps: i got it i must switch the Red and Black wire
                                Thanks
                                  See here https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors and here https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                                  • lui2004undefined
                                    lui2004
                                    ok thanks i have install it with success !
                                    i connected on E0_stop and insert M591 in my config like this:
                                    ;Filament Sensors
                                    M591 D0 P2 C"!e0_stop" S1 ;Extruder 1(0)
                                    • lui2004undefined
                                      lui2004
                                      Last question 😁
                                      I want convert the x axis with linear rails mgn12 bit i dont found nothing for mounting for micro swiss direct drive, anyone habe a link to stl file?
                                      Thanks in advance 👍🏼
                                      • Vetiundefined
                                        Veti @lui2004
                                        @lui2004
                                        https://printermods.com/products/direct-drive-mod-for-creality-ender-3-cr-10
                                        lui2004undefined 1 Reply Last reply Reply Quote 1
                                        • lui2004undefined
                                          lui2004 @Veti
                                          @Veti
                                          after i have changed the steppermotor this is my first benchy
                                          i have a lot of stringing
                                          my benchy:
                                          this are my Simplify3D settings:
                                          and my config.g
                                          ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                                          G90                                      ; Send absolute coordinates...
                                          M83                                      ; ...but relative extruder moves
                                          M550 P"Ender 5"                          ; Set machine name
                                          M552 S1                                  ; Enable network
                                          M586 P0 S1                               ; Enable HTTP
                                          M586 P1 S0                               ; Disable FTP
                                          M586 P2 S0                               ; Disable Telnet
                                          M569 P0 S1                               ; Physical drive 0 goes forwards
                                          M569 P1 S1                               ; Physical drive 1 goes forwards
                                          M569 P2 S0                               ; Physical drive 2 goes backwards
                                          M569 P3 S1                              ; Physical drive 3 goes forwards
                                          M584 X0 Y1 Z2 E3                               ; set drive mapping
                                          M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z800.00 E278.17             ; set steps per mm
                                          M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
                                          M203 X15000.00 Y15000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                                          M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30                                  ; Set idle timeout
                                          M208 X0 Y0 Z0 S1                         ; Set axis minima
                                          M208 X220 Y220 Z300 S0                   ; Set axis maxima
                                          M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                                          M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                                          M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                                          ;Filament Sensors
                                          M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H3 F60 T6000 A10 R0.75 S0.003            ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X41.2 Y4.5 Z1.785                   ; set Z probe trigger value, offset and trigger height
                                          M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
                                          M671 X28.8:198.8:198:28.8 Y24:24:194:194
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                                          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                        ; map heated bed to heater 0
                                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                                          M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                          M143 H1 S300 								   ; set temperature limit for heater 1 to 300C
                                          M307 H1 B0 S1.00
                                          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                                          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                                          M563 P0 D0 H1                            ; Define tool 0 S3D
                                          ;M563 P0 D0 H1 F0							; Für Prusa Slicer
                                          G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                                          G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                                          M572 D0 S0.15 ; Pressure Advance
                                          M501
                                          • Vetiundefined
                                            Veti
                                            increase the retraction distance until the stringing stops
