    How to enter my own probing point for bed levelling?
    814
    • deonholtundefined
      deonholt @fcwilt
      @fcwilt said in How to enter my own probing point for bed levelling?:
      @Veti said in How to enter my own probing point for bed levelling?:
      see
      He wants to do bed leveling not mesh bed compensation.
      Thanks Frederick. This is exactly what I was looking for ... even though I did not use the purist language. I am learning though.
      deonholtundefined 1 Reply Last reply Reply Quote 0
      • deonholtundefined
        deonholt @deonholt
        @deonholt
        One last question: What command activates the "Define Area for mesh grid compensation"?
        I fill in numbers there but I cannot find the command to use those entered numbers?
        • fcwiltundefined
          fcwilt @deonholt
          @deonholt said in How to enter my own probing point for bed levelling?:
          @deonholt
          For Mesh Bed Compensation you use M557 to define the probing grid and G29 with the appropriate S parameter to create (S0) or load (S1) the height map.
          Remember to use G30 to set the Z=0 Datum prior to creating or loading the height map.
          • deonholtundefined
            deonholt @fcwilt
            @deonholt
            Thank you so much. I am learning all the way.
            I got a pop-up message saying that M557 is not going to be used some time in the future. I opted for that because I cannot get my calculation for auto probing right.
            Bed is: 220 by 220 and I want 9 probes. I want to start at X30:190 and Y30:190
            Can you please assist in calculation this? I cannot find a tutorial on this. 😊
            • Vetiundefined
              Veti
              ok for that see my post
              • deonholtundefined
                deonholt @Veti
                @Veti
                Thanks. That I get. But I battle with the formula to get the correct radius.
                This is what I have entered in config.g but it only probe 4 points with some errors:
                557 X20:200 Y20:200 S90 ; define mesh grid
                I got this error and don't have a clue on how to interpret it so I can fix it:
                Warning: Skipping grid point (200.0, 200.0) because Z probe cannot reach it
                6 points probed, min error -0.053, max error 0.175, mean 0.058, deviation 0.083
                Height map saved to file heightmap.csv
                I want the 4 corners to be the ones right above the adjusting knobs.
                • Vetiundefined
                  Veti
                  X-49.
                  with an offset like that you M557 X minimum needs to be at least 49
                  so try
                  M557 X50:200 Y20:200 P3
                  deonholtundefined 2 Replies Last reply Reply Quote 0
                  • deonholtundefined
                    deonholt @Veti
                    @Veti
                    Thanks. Will quickly do so. Something, to my experience, that the wiki lacks, is to tell newbies like myself: do we need to take the offset into consideration or not. That may be why I am battling. Will quickly try again and get back to you.
                    • Vetiundefined
                      Veti
                      yes the M557 wiki should have a note on that.
                      • deonholtundefined
                        deonholt @Veti
                        X-49.
                        so try
                        I got this error:
                        Warning: Skipping grid point (200.0, 20.0) because Z probe cannot reach it
                        Warning: Skipping grid point (200.0, 110.0) because Z probe cannot reach it
                        Am I correct in saying that P3 tells it to do 3 probes in X & Y?
                        Thanks again.
                        • Vetiundefined
                          Veti @deonholt
                          @deonholt
                          ah sorry i got confused by the direction.
                          try
                          M557 X10:170 Y20:200 P3
                          yes
                          • deonholtundefined
                            deonholt @Veti
                            @Veti thanks.
                            On X it only went as far as 149.
                            I get the impression something is very wrong here. In what file do I set the bed size? X, Y & Z "maxima?"
                            Minute or what later ...
                            Bed maxima was 218. I changed it to 220 and it made 9 probes. Thanks for your help and patience.
                            M29 S? do I use to store the mesh and use it for the next print?
                            Thanks again. You're a Champ.
                            • Vetiundefined
                              Veti @deonholt
                              @deonholt
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
                              G29 S1
                              loads the last mesh
                              add tp your slicer start code after G28
                                Phaedrux Moderator @deonholt
                                Y10.5 (The probe is in front of the probe. Should it not also have been a negative number?)
                                Yes, if 0,0 is in the front left corner and X+ is to the right and X- to the left and Y+ to the back and Y- to the front. Then if the probe i in front, it should have a negative offset.
                                Create yourself a diagram like this. It can help a lot to visualize the layout.
                                deonholtundefined 1 Reply Last reply Reply Quote 1
                                • deonholtundefined
                                  deonholt @Phaedrux
                                  @Phaedrux thank you so much for the diagram-idea. It is brilliant. Thanks again.
                                  • fcwiltundefined
                                    fcwilt @Veti
                                    @deonholt
                                    G29 S1
                                    loads the last mesh
                                    Strictly speakly G29 S1 loads the existing height map.
                                    The "mesh" is what you define with M557 and is used to create the height map.
