DWC Z - Axis Movement off by Factor 10
1.3k
    Frederik
    Hello together,
    I just finished my very first 3d Printer build.
    Its a 400x400x400 CoreXY Kit from Ratrig.
    it´s running a duet 3 board with a Raspberry 3b+ with the original SD Image from Duet.
    I Updated the Reprap Firmware to 3.1.1 and got some Problems with the configuration.
    I don´t know if it is in the right Category.
    i want to configure the steps per mm, as I noticed that the steps in the DWC are off by the Factor of 10 for the Z-Axis movement.
    I use 0.9° Stepper on X, Y, and E.
    and at the moment 1.8° Stepper on the triple Z Spindel Motors (i will upgrade these to 0.9° Next Week )
    I used the Web Config Tool for my first Tests.
    When I am measuring the movement distances, X, Y, and E are really spot on, but the Z Steps are off by Factor 10.
    when i drive 0.01mm -> it moves 0.1
    when i drive 0.1mmm -y it moves 1mm
    and so on....
    I used Standard M8 Spindles with I believe 1.25 Pitch
    I started with 2560 Steps per mm with x16 Microstepping + interpolation.
    If i increase the steps to like 4500... it's not really a difference.
    because it is my first build, I don't know what to do next to solve this problem. ;(
    i also tried the individual z-axis bed leveling, but I don't know if it's funktioning working properly and using the actual measured values.
    And my Last Problem:
    How can I get the Duet Laser Filament Sensor to Pause the Print when it's detecting a Problem?
    I only found in the duzoki the following line:
    M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
    Thanks a lot in Advance
    Regards
    Frederik
    Here a my config Files: config.g, bed.g, homex.g , homey.g, homez.g
    My Config .g :
    ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"Duet 3" ; set printer name
    M669 K1 ; switch to CoreXZ mode and multiply motor movements by 3 for the Z axis
    M569 P0.0 S0 ; physical drive 0.0 goes backwards
    M569 P0.1 S0 ; physical drive 0.1 goes backwards
    M569 P0.2 S0 ; physical drive 0.2 goes backwards
    M569 P0.3 S0
    M569 P0.4 S0
    M569 P0.5 S1 ; physical drive 0.5 goes forwards
    M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5 ; set drive mapping
    M671 X425:200:-25 Y240:-25:240 S1 P1.25 ; leadscrews at front left, rear middle and front right with 1mm per screw compensation
    ; Movement Parameters
    M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
    M92 X160.00 Y160.00 Z4079.68 E873.08 ; set steps per mm
    M203 X12000.00 Y12000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
    M906 X1800 Y1800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X400 Y400 Z385 S0 ; set axis maxima
    M574 X2 S1 P"!io1.in" ; configure active-high endstop for high end on X via pin !io1.in
    M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin !io0.in
    M574 Z2 S2 ; configure Z-probe endstop for low end on Z
    ; Duet Laser Filament Sensor
    M591 D0 P5 C"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
    tolerance 40 to 120%, 3mm comparison length, enabled
    M92 X160.00 Y160.00 Z2560.00 E837.02 ; set steps per mm
    M906 X1800 Y1800 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
    M208 X400 Y400 Z400 S0 ; set axis maxima
    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
    M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X50:400 Y50:400 S50 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M143 H0 S200 ; set temperature limit for heater 0 to 200C
    M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
    M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
    M106 P0 C"Hotend" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
    M950 F1 C"!out4" Q500 ; create fan 1 on pin !out4 and set its frequency
    M106 P1 C"Bauteildüse" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
    M563 P0 S"E3D V6 0.4 Steel" D0 H1 F0:1 ; define tool 0
    T0 ; select first tool
    ; bed.g
    ;M561 ; clear any bed transform
    ;G29 S2 ; Clear bed height map
    ;Probe 3-point
    ;G1 X0 Y0 Z30
    ;G1 X365 Y50 F4000
    ;M401 ; Deploy probe - deployprobe.g
    G30 P0 X340 Y240 Z-9999 P1.25 ; Front Left and compensate 1mm screw with 1.25 pitch
    G30 P1 X200 Y40 Z-9999 P1.25 ; Middle Back and compensate 1mm screw with 1.25 pitch
    G30 P2 X20 Y240 Z-9999 P1.25 S3 ; Front Right and compensate 1mm screw with 1.25 pitch
    ;M402 ; Retract Probe - retractprobe.g
    ; homex.g
    ; called to home the X-axis
    G91 ; relative positioning
    ;G1 H2 Z5 F6000 ; lift Z relative to the current position
    G1 H1 X405 F6000 ; move quickly to X-axis endstop and stop there (first pass)
    G1 X-5 F6000 ; go back a few mm
    G1 H1 X405 F360 ; move slowly to X-axis endstop once more (second pass)
    ;G1 H2 Z-5 F6000 ; lower Z again
    G90 ; absolute positioning
    ; homey.g
    ; called to home the Y-axis
    G1 H1 Y-405 F6000 ; move quickly to Y axis endstop and stop there (first pass)
    G1 Y5 F6000 ; go back a few mm
    G1 H1 Y-405 F360 ; move slowly to Y-axis endstop once more (second pass)
    • list item
    ; homez.g
    ; called to home the Z-axis
    G1 H2 Z5 F1800 ; lift Z relative to current position
    G1 X200 Y200 F6000 ; go to first probe point
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to the current position
    ;G90 ; absolute positioning
    undefined 1 Reply Last reply 19 Nov 2020, 12:21 Reply Quote 0
      BoA @Frederik
      @Frederik
      This looks weird. What screws you have in Z ?
      undefined 1 Reply Last reply 19 Nov 2020, 12:31 Reply Quote 0
        Frederik @BoA
        @BoA Standard M8 Spindles
        undefined 1 Reply Last reply 19 Nov 2020, 12:33 Reply Quote 0
          Veti
          the movement sections is in your config twice
          this line overwrites the first line for example.
          those are not standard. you really need to know
          post the link the the product that you bought.
          undefined 1 Reply Last reply 19 Nov 2020, 12:35 Reply Quote 0
            Veti @Frederik
            @Frederik said in DWC Z - Axis Movement off by Factor 10:
            M8 Spindles have not been used in 3d printers for years because of bad results.
            do you mean tr8 lead screw?
              Frederik @Veti
              @Veti It was a complete Kit from Ratrig. There were no specifications other than M8 400mm
              I will ask the manufacturer
              undefined 1 Reply Last reply 19 Nov 2020, 12:37 Reply Quote 0
                BoA @Frederik
                @Frederik Make a picture. will be faster.
                  Frederik
                  according to the BOM:
                  8mm Metric ACME Lead Screw
                  undefined 1 Reply Last reply 19 Nov 2020, 12:40 Reply Quote 0
                    BoA @Frederik
                    @Frederik If this is Tr8x8 with 1.9deg stepper and 16microsteps it should be 400steps/mm
                    Also seems movement parameters section is doubled for some reason.
                      Frederik
                        Veti
                        thats a 4 start tr8 leadscrew
                        it has an 8mm pitch
                        undefined 1 Reply Last reply 19 Nov 2020, 12:44 Reply Quote 0
                          BoA @Veti
                          @Veti So as I wrote, 1.9deg, 16 microsteps, 8mm pitch - 400steps/mm. Not ~4000 or 2560.
                          And... what kind of extruder You have that E steps/mm are so.. not a round number?
                          undefined 1 Reply Last reply 19 Nov 2020, 13:02 Reply Quote 1
                            Frederik
                            thanks a lot, i will try the new values 😉
                            undefined 1 Reply Last reply 19 Nov 2020, 12:46 Reply Quote 0
                              BoA @Frederik
                              @Frederik And cleanup You config. Seems
                              is duplicated
                              undefined 1 Reply Last reply 19 Nov 2020, 12:52 Reply Quote 1
                                Frederik
                                MY other question is about the LAser FIlament Sensor:
                                I only Found the following Line in the dozuki for RRF 3.x
                                would this work on my duet 3 (connected to io3)
                                M950 J3 C"!^io3.in" ; Input 3, inverted, pullup enabled
                                undefined 1 Reply Last reply 19 Nov 2020, 12:53 Reply Quote 0
                                  Frederik @BoA
                                  @BoA oh, i see, thats a copy and paste error.... in my config its only once
                                    BoA @Frederik
                                    I would remove this one.
                                    undefined 1 Reply Last reply 19 Nov 2020, 12:58 Reply Quote 0
                                      Frederik @BoA
                                      @BoA so only this line :
                                      M591 D0 P5 P"io3.in" R40:120 E3.0 S1
                                      the green light flashes constantly and when i move the filament i respnds with faster blinking.
                                      is this all i need ? no extra pause and resume command ?
                                      undefined 1 Reply Last reply 19 Nov 2020, 13:00 Reply Quote 0
                                        BoA @Frederik
                                        @Frederik Should be fine. But I am guessing when filament monitoring shows some problems pause.g is executed to pause the print.
                                        You can check sensor status by M591 D0
                                          Frederik @BoA
                                          @BoA my extruder Setup:
                                          Original Bondtech BMG with a E3d Volcano with 0.4 mm micro swiss nozzle and titan heatbreak. 40W Heater and Thermistor 100K
                                          0.9° Pancake Stepper
                                          bedheater: 220V AC1.2 kW Keenovo Silicone Pad 400x400
                                          undefined 1 Reply Last reply 19 Nov 2020, 13:04 Reply Quote 0
                                          3 out of 35
